Topic: foo_stopafteralbum (Read 24456 times) previous topic - next topic
Re: foo_stopafteralbum.dll
Reply #50
Would it be possible to select a song in a playlist and do some sort of "stop after this track"?
Reply #52
This is a feature of fbuser's wonderful Playlist attributes. The option is called "Stop after focused track".
Good, thanks!
Reply #53
hi, just try 3.6, at first, good idea finally to see that "Repeat (track)" has now priority over stopAA (actually how it logically should be), but when turn "Repeat (track)" off while has stopAA active it just go to the next album after the previous last album track. bummer..
switching back to 3.4
Reply #54
hi
is the last version working for foobar 1.16.17 ?
is there still 3.4 and 3.5 ?
thanks
Reply #58
I've tested with foobar2000 1.16.17 and Stop after album 1.5, released on 2023-04-29 and it works.
Hi Grimes
I have tested too and i'm tring to use right now but there is no a menu , I have a new portable version with only 1 component Stop after album
I haven't it in the drop menu -> file or edit or view or Playback or even Iibrary
in version 2x 32bit i can find it
may i know where is it in foobar2000 1.16.17 ?
beautiful component!
thanks
Reply #60
Screenshot.
Hi Grimes
i have the same screenshot but in v2 i have lots of options ,like timebomb and others ,in v1 and  Stop after album 1.5 , i have only the item ->stop after album and nothing else
