Topic: Replaygain offset (Read 4206 times) previous topic - next topic
Replaygain offset
I'm calculating the average RMS value of a CD (mostly between -8 dB and -14 dB) but I'd like to compare that with what replaygain calculates (without their reference signal), so that 2 results should be pretty close. Can anyone tell me how I can change the replaygain result into the same scale as my average RMS?
Robin
Replaygain offset
You probably won't be able to get much correlation between the two. What replaygain calculates is vastly different than average RMS.
Replaygain offset
I agree, that's what I'd like to show people, that replaygain will give a better correlation to the ear (I'm dealing with audio engineers).
But I'd like to know how I can get both onto the same scale?
Robin
Replaygain offset
Why don't you just replaygain a file then calculate the average RMS of the replaygained file. This will give you the difference in dB between the two methods on this one file.
Replaygain offset
That's not really true as the replaygain calculation uses a reference level (http://replaygain.hydrogenaudio.org/calibration.html) and the replaygain will be the difference between the reference (-20 dBFS pink noise) and the calculated file, where as the average RMS is calculated with a reference of full scale. Any way, I need to display the average RMS (which I'm doing without a problem) and the replaygain BASED ON THE SAME SCALE. I'd like to know how I can do this?
Robin
Replaygain offset
ReplayGain is frequency dependent, RMS is not. Therefore you can tie them together for a given frequency sine wave - but it'll be wrong for all other sine waves, and any multi-frequency signal.
To tie them together, subtract the ReplayGain values from a chosen conversion reference level.
If you want to tie them together based on the loudest frequency RG "hears", use -22-RG value.
If you want to tie them together based on pink noise (a better choice), use -11.86-RG.
e.g.
RG=0
RMS = -11.86=-11.86
RG=-6
RMS = -11.86--6=-5.86
RG=+6
RMS = -14-6=-17.86
This gives RMS relative to 0dB FS (for a full scale sine wave) for the chosen conversion reference level.
Hope this helps.
David.
Replaygain offset
Hi, thanks for the information. I'm trying it with pink noise (-20 dBFS unweigthed),
RMS: -19.91 dB
Replay gain: 5.19 dB
If I do: replaygain = -11.86 - 5.19 dB, I get -17.05 dB which seems close, but when I try it with other recordings it seems that when the RMS goes down, the replaygain goes up. Am I doing it right now, or is there still something wrong?
Robin
Replaygain offset
Without wishing to sound insulting, did you remember that minus a minus is a plus?
Other than that, the correlation between RMS and ReplayGain really isn't very good. However, if you take a track and drop it by 6dB then the ReplayGain should increase by 6dB, and your "RMS-like ReplayGain equivalent" should drop by 6dB.
David.
Replaygain offset
Ow I know that replaygain works like that, but I'd like to use it different. Now I use:
-14.73 - analyzeResult ( A, sizeof(A)/sizeof(*A) );
Which gives both 19.92 dB RMS and Replaygain for my pinknoise signal. Although signals seem to have a higher RG, but now they're equivalent (RMS drops = RG drops).
That's what I wanted to see, I just hope that I'm doing it right!
Kind regards,
Robin
