128kbps Extension Test - OPEN
Reply #65 – 2003-07-24 21:57:45
Here is the sample batch - you need to make an executable from it! /EDIT\ Okay, final, working version! \EDIT/@echo off flac -d --silent -o ..\Sample05\orig.wav ..\Sample05\orig.flac >> NUL: rem Don't forget to randomize names and order of the parts! rem Lossless part copy /Y ..\Sample05\orig.wav ..\Sample05\5.wav >> NUL: rem End rem WMA part flac -d --silent -o ..\Sample05\2.wav ..\Sample05\wma.flac >> NUL: rem End rem MP4 part rem FAAD does support neither silent encoding nor pipes (weird, it should work with pipes...) faad -o ..\Sample05\3.wav ..\Sample05\mp4.mp4 >> NUL: rem End rem MPC part rem Workaround for MPPENC showing its version mppenc --quality 4 --xlevel --silent ..\Sample05\orig.wav ..\Sample05\orig.mpc >> NUL: mppdec --silent ..\Sample05\orig.mpc ..\Sample05\1.wav >> NUL: del ..\Sample05\orig.mpc >> NUL: rem End rem Vorbis part oggenc -Q -q 4.25 ..\Sample05\orig.wav --output=..\Sample05\orig.ogg >> NUL: rem OggDec doesn't support silent decoding... here's a workaround del ..\Sample05\4.wav >> NUL: oggdec -o ..\Sample05\orig.ogg >> ..\Sample05\4.wav del ..\Sample05\orig.ogg >> NUL: rem End rem LAME part lame --alt-preset 128 --scale 1 --silent ..\Sample05\orig.wav ..\Sample05\orig.mp3 >> NUL: lame --decode --silent ..\Sample05\orig.mp3 ..\Sample05\7.wav >> NUL: del ..\Sample05\orig.mp3 >> NUL: rem End rem Blade part bladeenc -q -quiet ..\Sample05\orig.wav ..\Sample05\orig.mp3 >> NUL: lame --decode --silent ..\Sample05\orig.mp3 ..\Sample05\6.wav >> NUL: del ..\Sample05\orig.mp3 >> NUL: rem End rem Cleanup rem You may ommit this if you want, but this increases the security slightly del ..\Sample05\orig.flac >> NUL: del ..\Sample05\wma.flac >> NUL: del ..\Sample05\mp4.mp4 >> NUL: del ..\Sample05\orig.wav >> NUL:
