HydrogenAudio
CD-R and Audio Hardware => CD Hardware/Software => Topic started by: RancelDoom on 2021-02-16 23:01:13
Title: Audio CD without scratches has multiple sync errors and suspicious positions
Post by: RancelDoom on 2021-02-16 23:01:13
when extractng. Using EAC 1.6
Title: Re: Audio CD without scratches has multiple sync errors and suspicious positions
Post by: Porcus on 2021-02-17 07:44:15
There sometimes are pressing errors. Also I don't know how EAC reacts to those pesky defective by design CDs.
But if it verifies AccurateRip - or you can repair it using CUETools - you are all fine.
Post by: RancelDoom on 2021-02-17 08:31:34
How do you use cuetools to repair it? Never done it before.
Post by: Porcus on 2021-02-17 09:18:39
Open the cuesheet or track 1 i CUETools. Select Encode, and under the drop-down select repair, that's the "(7)" here: http://cue.tools/wiki/CUETools_Settings
See if it works. Often it does not - there has to be a parity file in the database for that particular CD release, and you cannot have too many errors (at most half a second in total, actually - but that is more than you think). If a CD has only a doubtful pressing and nothing else, then ... tough luck. If there were several pressings including good ones ... maybe.
