I was wondering if there could be an option either by using Notepad or doing it using a GUI method within Foobar2000 to add additional Internet Lyric databases.
The database I wish to use is on "Anime Lyrics (http://www.animelyrics.com/)".
My Current version of foobar2000 is v.1.1.16 (Stable/Non-beta)
My OS is Windows 7 64-bit.
My playlist contains ONLY flac files with an exception of 3 albums of mp3 and 1 album of m4a files.
I am using the following components
Core (2012-10-27 09:21:54 UTC)
foobar2000 core 1.1.16
foo_albumlist.dll (2012-10-27 09:20:30 UTC)
Album List 4.5
foo_cdda.dll (2012-10-27 09:20:04 UTC)
CD Audio Decoder 3.0
foo_converter.dll (2012-10-27 09:19:44 UTC)
Converter 1.5
foo_dsp_dolbyhp.dll (2010-01-22 13:40:28 UTC)
Dolby Headphone Wrapper 1.4.1
foo_dsp_std.dll (2012-10-27 09:20:22 UTC)
Standard DSP Array 1.0
foo_input_std.dll (2012-10-27 09:20:22 UTC)
Standard Input Array 1.0
foo_playcount.dll (2012-11-10 16:24:17 UTC)
Playback Statistics 3.0.2
foo_rgscan.dll (2012-10-27 09:19:42 UTC)
ReplayGain Scanner 2.1.2
foo_ui_columns.dll (2010-03-20 23:43:13 UTC)
Columns UI 0.3.8.5
foo_clownware.dll (2010-02-05 15:26:56 UTC)
UI Hacks 2010-02-05
foo_ui_std.dll (2012-10-27 09:20:04 UTC)
Default User Interface 0.9.5
foo_uie_biography.dll (2010-04-30 15:49:24 UTC)
Biography View 0.4.2.0
foo_uie_elplaylist.dll (2010-04-03 17:39:02 UTC)
ELPlaylist 0.6.8.2(beta)
foo_uie_esplaylist.dll (2010-04-29 16:01:08 UTC)
EsPlaylist 0.1.0.0
foo_uie_lyrics2.dll (2009-12-22 17:12:56 UTC)
Lyric Show Panel 2 0.4.4
foo_uie_panel_splitter.dll (2009-12-09 16:16:12 UTC)
Panel Stack Splitter 0.3.8.3(alpha)
foo_uie_vis_channel_spectrum.dll (2008-05-17 19:02:12 UTC)
Channel Spectrum panel 0.17.2
foo_uie_wsh_panel_mod.dll (2010-02-28 02:59:14 UTC)
WSH Panel Mod 1.3.2
foo_unpack.dll (2012-10-27 09:19:12 UTC)
ZIP/GZIP/RAR Reader 1.6
Within the DSP Manager I am using
Crossfader
Advanced Limiter
Convert 5.1 to Stereo
Convert Mono to Stereo
Dolby Headphone (Third Party provided by Dolby)
So I was wondering of the possibility about adding additional internet lyrics databases without having to type them manually, as foobar2000 provides only 6 databases. All my songs are in japanese so I was wondering if Anime lyrics could somehow be integrated as a lyric database by even using notepad if needed.
foobar2000 itself doesn't provide lyric databases. These are provided by extra plugin(s). It seems you are using the outdated lyrics2 - and most of its database searching no longer works. Try upgrading to foo_uie_lyrics3 and see if that provides suitable japanese lyrics. If not there is an api for writing your own database lyric searches for foo_uie_lyrics3 (foo_uie_lyrics3 source SDK.zip). See:
http://www.hydrogenaudio.org/forums/index....showtopic=90338 (http://www.hydrogenaudio.org/forums/index.php?showtopic=90338)
http://code.google.com/p/foo-uie-lyrics3/downloads/list (http://code.google.com/p/foo-uie-lyrics3/downloads/list)
