Topic: possibility to read metadata of a track being played (Read 6658 times) previous topic - next topic
This is a wish to have an option to read metadata of a given track being played, so to see the composer or else. Thank you in advance.
Re: possibility to read metadata of a track being played
What track being played?  Do you mean streaming?
No, I am just listening audio files saved on my phone that I tagged myself. I would like to see the tags while listening to check them.
I don't use mobile, but it doesn't seem likely that metadata isn't already displayed.  What metadata in particular?
Here's a screenshot I found on-line showing album art, title of track and album, artist, etc etc:
In the standard skin, the composer is displayed when the genre is classical.
If you want to always display the composer, you need to edit the skin.
It would be useful to have Properties or Track Info.
*if classical
[label]
1900,125,2025,200
centered
[font-artist][composer]
Foobar2000 Mobile:Skin file format
https://wiki.hydrogenaud.io/index.php?title=Foobar2000_Mobile:Skin_file_format
Example skins
https://wiki.hydrogenaud.io/index.php?title=Foobar2000_Mobile:Skin_file_format#Example_skins
White Skin 2023.fbskin → White Skin 2023.zip (Unzip) → White Skin 2023 folder
(Change the extension)
Edit:
landscape-16-10-4000x2500.txt, portrait-10-16-2500x4000.txt
landscape-16-9-4000x2250.txt, portrait-9-16-2250x4000.txt
You might be able to display it by installing @Daiki's Skin.
NewMoon 2.0 and 2.0s
https://hydrogenaud.io/index.php/topic,125642.0.html
SHURE SRH1840, SENNHEISER HD660S2, SENNHEISER HD620S, SENNHEISER HD 490 Pro Plus, beyerdynamic DT 1990 PRO, HiFiMAN Edition XS, HIFIMAN ANANDA, Bowers & Wilkins P7, FiiO FT5, FiiO FT1 Pro, 水月雨 (MOONDROP) 空鳴 - VOID, SONY WH1000XM5 (made a Upgrade/Balanced Cable by myself)
Thank you for the possibility to edit the skin : I didn't know it was possible.
Yes, it would be useful to have Track info or Properties.
