Topic: CBR AAC Encoder (Read 7075 times) previous topic - next topic
Re: CBR AAC Encoder
Reply #50
Using wrong tool for the job. Use sox for the job, then pipe the result to encoder of your choice.
TAPE LOADING ERROR
Re: CBR AAC Encoder
Reply #51
@itisljar You recommend me using sox for which part of the job? If you mean the cutoff point, I can't get a higher cutoff point this way (I need it for some specific bitrates).
Re: CBR AAC Encoder
Reply #52
I don't want to use that low cutoff, this is just for testing): qaac -c 24 -r 22050 --lowpass 2000 sh44m.wav
L:\test>qaac64.exe --ignorelength --no-optimize -c 24 -r 22050 --lowpass 2000 "L:\test\Bird.wav"
qaac 2.82, CoreAudioToolbox 7.10.9.0
Bird.m4a
44100Hz -> 22050Hz
AAC-LC Encoder, CBR 24kbps, Quality 96
[100.0%] 0:29.789/0:29.789 (211.3x), ETA 0:00.000
656861/656861 samples processed in 0:00.141
Overall bitrate: 24.0019kbps
X
korth
Re: CBR AAC Encoder
Reply #53
I don't understand. You do this:
sox input.wav output.wav lowpass 3300 rate 22050
Afterwards, encode the audio with encoder of your choice.
You can tweak lowpass filter with sinc to get more precise lowpass controls.
TAPE LOADING ERROR
Re: CBR AAC Encoder
Reply #54
Bird.m4a
44100Hz -> 22050Hz
[attach type=image]32551[/attach]
I still can't get a lower cutoff with theses two additional commands, should I use the 64-bit version?
I won't be able to get a higher cutoff point with this method, am I wrong?
Re: CBR AAC Encoder
Reply #55
Those were settings already in my script. Shouldn't make a difference.
korth
Re: CBR AAC Encoder
Reply #57
korth
Re: CBR AAC Encoder
Reply #59
As long as you're below half of needed sampling rate. For 22050 that's 11024. You can cutoff wherever you are.
Later on, encode it.
TAPE LOADING ERROR
Re: CBR AAC Encoder
Reply #62
Test and see. You've gotten a lot of information.
TAPE LOADING ERROR
