Topic: oddcast:howTo Set Vol.to 0 not affecting streaming (Read 1989 times) previous topic - next topic
oddsock & foobar: how to set volume to 0% without affecting the streaming volume?
It' s very simple. I'm streaming using the latest foobar2000 (with volume control plugin set to "foobar internal volume control") & oddsock plugin to it.
I want to put volume to 0%, just to hear something another (whatever), without stopping streaming.
When I was using it for the first time, it worked fine: Foobar was streaming in the background and I could work with other sounds on my computer.
Then, I had to re-install Foobar. Now IT DOESN'T WORK!
When I decrease volume, plugin does the same with music that I stream.
Thanks in advance for ANY HELP!
Artur Grossman
http://ar.of.pl
Put the Volume control DSP after the oddcast DSP.  That should solve that.
[EDIT] Strange. Sure didn't see Duble0Syx reply before. Well, no need for the same answer twice. Answer deleted. [/EDIT]
