Topic: [Wishlist] Suggestions/Requests for CUETools, CUERipper, etc. (Read 14204 times) previous topic - next topic
Re: [Wishlist] Suggestions/Requests for CUETools, CUERipper, etc.
CueRipper
I would like to rip the audio tracks and run the encoder in the background
today it's non sense , rip a track ,wait to encode and re-start to spin the drive to rip the second track and so on
it could rip all the tracks in a temp folder maybe chooses/selected by the user (to speed up , maybe a scratch disk) and encode the track in the background
beause rip 1 disk is ok , but if somebody do need to rip 30 cds , well it does become very slow
thanks ,take care
Would be great if the limites were extended"
Error Limits
More than 99 tracks - Exception: [Index] out of range
Track start position ~140 minutes or above - Exception: invalid stride
Especially the last one.
Isn't 99 or 100 tracks the limit of the RedBook CD TOC specification, though?
Where have you seen a CD with more than that?
As for the 140 minute limit, I don't know, but I suspect it's a similar situation.
140 is double of 70, which is the approximate duration of first generation audio CDs. Maybe they were counting on packing double density in the future and made room in the format for that. I don't know, I'm just speculating.
It sounds like you are trying to do out-of-spec stuff. CUETools is a CD-centered software, as far as I know, so it seems reasonable that it should follow the specification.
Indeed, but if it already has a time limit way above of what a physical disc can handle, it could be raised even higher. Same with number of tracks, so that bandcamp releases that exceed those could still be processed for example. EAC already gives up after INDEX exceeding 90-99 minute mark, while CueTools could rip longer "discs" (virtual image+cue), it just so happens that I finally encountered one that is longer than said limit and it would be great if it could process ~150 minute album. Maybe there's something that can be changed (cracked) in the source code manually.
Improve keyboard navigation when manually adding metadata in to CUERipper.
Adding in any metadata and pressing enter does not move down and activate the next field. This makes adding metadata cumbersome because a mouse needs to be used to activate the next field. If in track view pressing enter on the field correctly moves down to the next field and allows that field to be edited.
+1
- add unicode support to cueripper and allow definition of character substitution
Specify filename pattern(s) for a number of files to be copied to the output folder. For example, "*.jpg,*.pdf"
tick box to enable.
I have multiple files with artwork including pdfs of booklets that I would like to copy into the output folder.
Drop free/gnudb in favour of musicbrainz in cueripper (both read and write, of course).
Agree - write MBID tags to encoded flac and MP files if the release is found in MB
Reply #30
This post is intended to provide examples to development of what I meant by REMarking out non-compliant data in the Option to "Force Compliant CUE" sheet for separate tracks suggestion above under General (so users can have compliant CUE sheets for use in programs such as foobar2000 that don't support non-compliant CUE sheets). See also Issue #179 and Issue #268
First an example of a non-compliant CUE as written by CUERipper, EAC and CUETools to preserve gap information in a file-per-track rip.
REM DISCID B50C550D
PERFORMER "Black Stone Cherry"
TITLE "Kentucky"
CATALOG 0819873012757
REM DATE 2016
REM GENRE "Rock"
REM COMMENT "CUERipper v2.1.6 Copyright (C) 2008-13 Grigory Chudov"
FILE "01 The Way of the Future.flac" WAVE
  TRACK 01 AUDIO
    TITLE "The Way of the Future"
    ISRC NLB931600001
    INDEX 01 00:00:00
  TRACK 02 AUDIO
    TITLE "In Our Dreams"
    ISRC NLB931600002
    INDEX 00 03:51:03
FILE "02 In Our Dreams.flac" WAVE
    INDEX 01 00:00:00
  TRACK 03 AUDIO
    TITLE "Shakin' My Cage"
    ISRC NLB931600003
    INDEX 00 03:48:03
FILE "03 Shakin' My Cage.flac" WAVE
    INDEX 01 00:00:00
  TRACK 04 AUDIO
    TITLE "Soul Machine"
    ISRC NLB931600004
    INDEX 00 04:08:22
FILE "04 Soul Machine.flac" WAVE
    INDEX 01 00:00:00
  TRACK 05 AUDIO
    TITLE "Long Ride"
    ISRC NLB931600005
    INDEX 00 03:59:17
FILE "05 Long Ride.flac" WAVE
    INDEX 01 00:00:00
  TRACK 06 AUDIO
    TITLE "War"
    ISRC NLB931600006
    INDEX 00 04:01:59
FILE "06 War.flac" WAVE
    INDEX 01 00:00:00
  TRACK 07 AUDIO
    TITLE "Hangman"
    ISRC NLB931600007
    INDEX 00 04:06:09
FILE "07 Hangman.flac" WAVE
    INDEX 01 00:00:00
  TRACK 08 AUDIO
    TITLE "Cheaper to Drink Alone"
    ISRC NLB931600008
    INDEX 00 03:55:53
FILE "08 Cheaper to Drink Alone.flac" WAVE
    INDEX 01 00:00:00
  TRACK 09 AUDIO
    TITLE "Rescue Me"
    ISRC NLB931600009
    INDEX 00 03:49:21
FILE "09 Rescue Me.flac" WAVE
    INDEX 01 00:00:00
  TRACK 10 AUDIO
    TITLE "Feelin' Fuzzy"
    ISRC NLB931600010
    INDEX 00 03:44:46
FILE "10 Feelin' Fuzzy.flac" WAVE
    INDEX 01 00:00:00
  TRACK 11 AUDIO
    TITLE "Darkest Secret"
    ISRC NLB931600011
    INDEX 00 03:14:18
FILE "11 Darkest Secret.flac" WAVE
    INDEX 01 00:00:00
  TRACK 12 AUDIO
    TITLE "Born to Die"
    ISRC NLB931600012
    INDEX 00 03:59:57
FILE "12 Born to Die.flac" WAVE
    INDEX 01 00:00:00
  TRACK 13 AUDIO
    TITLE "The Rambler"
    ISRC NLB931600013
    INDEX 00 04:30:72
FILE "13 The Rambler.flac" WAVE
    INDEX 01 00:00:00
Below is a compliant version of the CUE written by EAC's sister program "Easy Audio Copy" (by Andre Wiethoff).
INDEX 00 lines are REMarked out and the FILE line does not get placed after the INDEX 00 line.
This CUE works in foobar2000 and gap information is preserved.
REM GENRE Rock
REM DATE 2016
REM DISCID B50C550D
REM COMMENT "Easy Audio Copy 1.0.2.5"
TITLE "Kentucky"
FILE "01 The Way Of The Future.flac" WAVE
  TRACK 01 AUDIO
    TITLE "The Way Of The Future"
    ISRC NLB931600001
    INDEX 01 00:00:00
  TRACK 02 AUDIO
    ISRC NLB931600002
    REM INDEX 00 03:51:03
    INDEX 01 00:00:00
  TRACK 03 AUDIO
    ISRC NLB931600003
    REM INDEX 00 03:48:03
    INDEX 01 00:00:00
  TRACK 04 AUDIO
    ISRC NLB931600004
    REM INDEX 00 04:08:22
    INDEX 01 00:00:00
  TRACK 05 AUDIO
    TITLE "Long Ride"
    ISRC NLB931600005
    REM INDEX 00 03:59:17
    INDEX 01 00:00:00
  TRACK 06 AUDIO
    TITLE "War"
    ISRC NLB931600006
    REM INDEX 00 04:01:59
    INDEX 01 00:00:00
  TRACK 07 AUDIO
    TITLE "Hangman"
    ISRC NLB931600007
    REM INDEX 00 04:06:09
    INDEX 01 00:00:00
FILE "08 Cheaper To Drink Alone.flac" WAVE
  TRACK 08 AUDIO
    TITLE "Cheaper To Drink Alone"
    ISRC NLB931600008
    REM INDEX 00 03:55:53
    INDEX 01 00:00:00
  TRACK 09 AUDIO
    TITLE "Rescue Me"
    ISRC NLB931600009
    REM INDEX 00 03:49:21
    INDEX 01 00:00:00
  TRACK 10 AUDIO
    ISRC NLB931600010
    REM INDEX 00 03:44:46
    INDEX 01 00:00:00
  TRACK 11 AUDIO
    ISRC NLB931600011
    REM INDEX 00 03:14:18
    INDEX 01 00:00:00
FILE "12 Born To Die.flac" WAVE
  TRACK 12 AUDIO
    TITLE "Born To Die"
    ISRC NLB931600012
    REM INDEX 00 03:59:57
    INDEX 01 00:00:00
  TRACK 13 AUDIO
    TITLE "The Rambler"
    ISRC NLB931600013
    REM INDEX 00 04:30:72
    INDEX 01 00:00:00
This is a non-compliant CUE with an actual Hidden Track One Audio (HTOA). There are gaps before Track 5 and Track 12.
REM DISCID 9A0A5B0C
PERFORMER "Sick Puppies"
TITLE "Connect"
CATALOG 5099942321958
REM DATE 2013
FILE "00 (HTOA).flac" WAVE
  TRACK 01 AUDIO
    TITLE "Die to Save You"
    ISRC USUM71307069
    INDEX 00 00:00:00
FILE "01 Die to Save You.flac" WAVE
    INDEX 01 00:00:00
FILE "02 There’s No Going Back.flac" WAVE
  TRACK 02 AUDIO
    TITLE "There’s No Going Back"
    ISRC USUM71305552
    INDEX 01 00:00:00
FILE "03 Walking Away.flac" WAVE
  TRACK 03 AUDIO
    TITLE "Walking Away"
    ISRC USUM71305551
    INDEX 01 00:00:00
FILE "04 Gunfight.flac" WAVE
  TRACK 04 AUDIO
    TITLE "Gunfight"
    ISRC USUM71305557
    INDEX 01 00:00:00
  TRACK 05 AUDIO
    TITLE "Poison"
    ISRC USUM71305558
    INDEX 00 02:54:52
FILE "05 Poison.flac" WAVE
    INDEX 01 00:00:00
FILE "06 Where Did the Time Go.flac" WAVE
  TRACK 06 AUDIO
    TITLE "Where Did the Time Go"
    ISRC USUM71305550
    INDEX 01 00:00:00
FILE "07 Telling Lies.flac" WAVE
  TRACK 07 AUDIO
    TITLE "Telling Lies"
    ISRC USUM71305553
    INDEX 01 00:00:00
FILE "08 Connect.flac" WAVE
  TRACK 08 AUDIO
    TITLE "Connect"
    ISRC USUM71305562
    INDEX 01 00:00:00
FILE "09 Run.flac" WAVE
  TRACK 09 AUDIO
    TITLE "Run"
    ISRC USUM71305546
    INDEX 01 00:00:00
FILE "10 The Trick the Devil Did.flac" WAVE
  TRACK 10 AUDIO
    TITLE "The Trick the Devil Did"
    ISRC USUM71305547
    INDEX 01 00:00:00
FILE "11 Healing Now.flac" WAVE
  TRACK 11 AUDIO
    TITLE "Healing Now"
    ISRC USUM71305548
    INDEX 01 00:00:00
  TRACK 12 AUDIO
    TITLE "Under a Very Black Sky"
    ISRC USUM71305549
    INDEX 00 04:12:19
FILE "12 Under a Very Black Sky.flac" WAVE
    INDEX 01 00:00:00
Andre handles the HTOA in an interesting way with Easy Audio Copy.
All the lines from the first FILE command up to the first INDEX 01 command are REMarked out. A PREGAP command replaces the FILE command for the Hidden track (HTOA) and the INDEX 00 command. The lines associated with the first track are repeated in compliant order.
This CUE works in foobar2000. Gaps and HTOA information are retained. The hidden track remains hidden and will not show up in foobar2000 with this CUE. That is to be expected.
REM GENRE Rock: Alternative Rock
REM DATE 2013
REM DISCID 9A0A5B0C
REM COMMENT "Easy Audio Copy 1.0.1.0"
CATALOG 5099902871325
TITLE "Connect"
  TRACK 01 AUDIO
    ISRC USUM71307069
    REM FILE "00 Hidden track.flac"
    REM   TRACK 01 AUDIO
    REM     TITLE "Die to Save You"
    REM     PERFORMER "Sick Puppies"
    REM     ISRC USUM71307069
    REM     INDEX 00 00:00:00
    PREGAP 01:05:33
    REM FILE "01 Die to Save You.flac" WAVE
    INDEX 01 00:00:00
FILE "02 There's No Going Back.flac" WAVE
  TRACK 02 AUDIO
    TITLE "There's No Going Back"
    ISRC USUM71305552
    INDEX 01 00:00:00
  TRACK 03 AUDIO
    ISRC USUM71305551
    INDEX 01 00:00:00
  TRACK 04 AUDIO
    TITLE "Gunfight"
    ISRC USUM71305557
    INDEX 01 00:00:00
  TRACK 05 AUDIO
    TITLE "Poison"
    ISRC USUM71305558
    REM INDEX 00 02:54:52
    INDEX 01 00:00:00
  TRACK 06 AUDIO
    ISRC USUM71305550
    INDEX 01 00:00:00
  TRACK 07 AUDIO
    ISRC USUM71305553
    INDEX 01 00:00:00
  TRACK 08 AUDIO
    TITLE "Connect"
    ISRC USUM71305562
    INDEX 01 00:00:00
  TRACK 09 AUDIO
    TITLE "Run"
    ISRC USUM71305546
    INDEX 01 00:00:00
  TRACK 10 AUDIO
    ISRC USUM71305547
    INDEX 01 00:00:00
  TRACK 11 AUDIO
    TITLE "Healing Now"
    ISRC USUM71305548
    INDEX 01 00:00:00
  TRACK 12 AUDIO
    ISRC USUM71305549
    REM INDEX 00 04:12:19
    INDEX 01 00:00:00
Currently CUETools cannot parse the gap and HTOA information from an Easy Audio Copy compliant CUE.
Naturally CUETools would need to be able to parse this type of CUE in order to convert a file-per-track rip to a single file Image (keeping the gap information and HTOA audio).
korth
Post a pinned link to the official wiki page
at the top of the thread.
Been using Cuetools for a while and I'm very grateful for the amazing job it does. If the following are not available, might they be considered as options in a future version please?
(1) Option to not pad track numbers in file names and tags (i.e. 1, 2, 3...9 instead of 01, 02, 03...09)
(2) Option to not write the 'Total Tracks' tag.
(3) Option to add Album Artist and Composer tags in the 'Select the best match' window.
Reply #33
Add support for ISRC entry in .cue file and pass it and its value to the encoder
Reply #34
CueRipper:
1. Add the ability to search and pull artwork from Musicbrainz as a source. They already have artwork sized to multiple options to choose from (and the quality is generally higher). Fail back to current provider if no image found. If not possible, maybe add an option to select min and maximum resolution images from current provider, and resize if too large on write.
2. Pull and write Genre Tags from Musicbrainz.
3. The ability to write %album artist% into tag, instead of %artist%.
