HydrogenAudio
CD-R and Audio Hardware => CD Hardware/Software => Topic started by: harto69 on 2012-11-28 09:11:54
Title: Please help me interpreting this EAC-log
Post by: harto69 on 2012-11-28 09:11:54
Few days ago I've bougth a used Iron Maiden Cd, it was not in a very good state of conservation, with many scratches. After some cleaning I tried to rip it with EAC, the resulting log says:
Exact Audio Copy V1.0 beta 3 from 29. August 2011
EAC extraction logfile from 22. November 2012, 8:57
Iron Maiden / Killers
Used drive  : ATAPI  DVD A  DH16ABSH  Adapter: 0  ID: 1
Read mode : Burst
Read offset correction                      : 6
Overread into Lead-In and Lead-Out          : No
Fill up missing offset samples with silence : Yes
Delete leading and trailing silent blocks  : No
Null samples used in CRC calculations      : Yes
Used interface                              : Native Win32 interface for Win NT & 2000
Used output format              : User Defined Encoder
Selected bitrate                : 32 kBit/s
Quality                        : High
Add ID3 tag                    : No
Command line compressor        : C:\Program Files (x86)\foobar2000\flac.exe
Additional command line options : -5 %source%
TOC of the extracted CD
    Track |  Start  |  Length  | Start sector | End sector
        1  |  0:00.32 |  1:45.63 |        32    |    7969
        2  |  1:46.20 |  2:54.30 |      7970    |    21049
        3  |  4:40.50 |  4:18.22 |    21050    |    40421
        4  |  8:58.72 |  3:22.73 |    40422    |    55644
        5  | 12:21.70 |  3:07.05 |    55645    |    69674
        6  | 15:29.00 |  3:52.32 |    69675    |    87106
        7  | 19:21.32 |  5:00.65 |    87107    |  109671
        8  | 24:22.22 |  6:12.20 |    109672    |  137591
        9  | 30:34.42 |  3:20.05 |    137592    |  152596
      10  | 33:54.47 |  4:48.50 |    152597    |  174246
Range status and errors
Selected range
    Filename G:\Musik\Iron Maiden - 1981 - Killers\Iron Maiden - 1981 - Killers.wav
    Timing problem 0:00:07
    Timing problem 0:00:12 - 0:00:14
    Timing problem 0:00:16 - 0:00:17
    Timing problem 0:03:43
    Timing problem 0:04:36
    Timing problem 0:04:45 - 0:04:48
    Timing problem 0:04:57 - 0:05:00
    Timing problem 0:05:02 - 0:05:08
    Timing problem 0:05:51
    Timing problem 0:06:06
    Timing problem 0:06:16
    Timing problem 0:06:18
    Timing problem 0:06:21
    Timing problem 0:06:25 - 0:06:26
    Timing problem 0:06:36 - 0:06:37
    Timing problem 0:06:39
    Timing problem 0:06:41
    Timing problem 0:06:43
    Timing problem 0:06:45 - 0:06:49
    Timing problem 0:06:51
    Timing problem 0:06:58 - 0:06:59
    Timing problem 0:07:30
    Timing problem 0:08:54
    Timing problem 0:09:29 - 0:09:33
    Timing problem 0:09:39 - 0:09:55
    Timing problem 0:09:59
    Timing problem 0:10:03 - 0:10:13
    Timing problem 0:10:15
    Timing problem 0:10:21
    Timing problem 0:10:24
    Timing problem 0:10:30 - 0:10:31
    Timing problem 0:10:36
    Timing problem 0:11:57
    Timing problem 0:11:59 - 0:12:05
    Timing problem 0:12:07 - 0:12:08
    Timing problem 0:12:11
    Timing problem 0:12:13 - 0:12:21
    Timing problem 0:12:26 - 0:12:29
    Timing problem 0:13:11 - 0:13:32
    Timing problem 0:13:45 - 0:13:57
    Timing problem 0:14:01
    Timing problem 0:14:03 - 0:14:07
    Timing problem 0:14:09 - 0:14:12
    Timing problem 0:14:34
    Timing problem 0:15:18
    Timing problem 0:15:22 - 0:15:34
    Timing problem 0:15:36 - 0:15:44
    Timing problem 0:15:46 - 0:15:49
    Timing problem 0:15:55
    Timing problem 0:15:57 - 0:15:58
    Timing problem 0:16:00 - 0:16:01
    Timing problem 0:16:03 - 0:16:04
    Timing problem 0:16:07 - 0:16:10
    Timing problem 0:16:15 - 0:16:21
    Timing problem 0:16:24
    Timing problem 0:16:30
    Timing problem 0:16:32 - 0:16:42
    Timing problem 0:16:48 - 0:16:49
    Timing problem 0:16:51
    Timing problem 0:16:58
    Timing problem 0:17:36 - 0:17:46
    Timing problem 0:18:29
    Timing problem 0:18:31 - 0:18:32
    Timing problem 0:18:58 - 0:19:05
    Timing problem 0:19:11 - 0:19:12
    Timing problem 0:19:15
    Timing problem 0:19:20
    Timing problem 0:19:22
    Timing problem 0:19:42
    Timing problem 0:19:46
    Timing problem 0:19:56
    Timing problem 0:19:58 - 0:20:01
    Timing problem 0:20:43 - 0:20:48
    Timing problem 0:20:50 - 0:20:51
    Timing problem 0:20:53
    Timing problem 0:21:27
    Timing problem 0:22:38
    Timing problem 0:22:50 - 0:22:52
    Timing problem 0:22:54 - 0:22:55
    Timing problem 0:22:57
    Timing problem 0:23:08
    Timing problem 0:23:16 - 0:23:17
    Timing problem 0:23:19
    Timing problem 0:23:21 - 0:23:23
    Timing problem 0:23:27
    Timing problem 0:23:29
    Timing problem 0:23:31
    Timing problem 0:23:35 - 0:23:36
    Timing problem 0:23:39 - 0:23:41
    Timing problem 0:24:23
    Timing problem 0:24:27
    Timing problem 0:24:34
    Timing problem 0:24:39
    Timing problem 0:25:01
    Timing problem 0:25:04 - 0:25:06
    Timing problem 0:25:08
    Timing problem 0:26:21
    Timing problem 0:26:26
    Timing problem 0:26:30 - 0:26:31
    Timing problem 0:28:06
    Timing problem 0:28:21
    Timing problem 0:28:23
    Timing problem 0:28:27
    Timing problem 0:28:38 - 0:28:43
    Timing problem 0:29:26 - 0:29:31
    Timing problem 0:29:33
    Timing problem 0:29:35
    Timing problem 0:29:37 - 0:29:38
    Timing problem 0:29:41 - 0:29:43
    Timing problem 0:29:46 - 0:29:58
    Timing problem 0:30:00 - 0:30:05
    Timing problem 0:30:08 - 0:30:11
    Timing problem 0:30:13 - 0:30:15
    Timing problem 0:30:17 - 0:30:35
    Timing problem 0:31:18 - 0:31:19
    Timing problem 0:31:21 - 0:31:22
    Timing problem 0:31:26 - 0:31:27
    Timing problem 0:31:32 - 0:31:34
    Timing problem 0:31:36 - 0:31:37
    Timing problem 0:32:19
    Timing problem 0:32:24
    Timing problem 0:32:44
    Timing problem 0:33:42 - 0:38:42
    Peak level 99.7 %
    Extraction speed 2.8 X
    Test CRC E435686A
    Copy CRC 46EA545C
    Copy finished
No errors occurred
AccurateRip summary
Track  1  cannot be verified as accurate (confidence 70)  [45915099], AccurateRip returned [AB545ECE]  (AR v2)
Track  2  cannot be verified as accurate (confidence 70)  [43D94978], AccurateRip returned [03286E74]  (AR v2)
Track  3  cannot be verified as accurate (confidence 70)  [70407142], AccurateRip returned [C1BD2C64]  (AR v2)
Track  4  cannot be verified as accurate (confidence 69)  [C11EBAA2], AccurateRip returned [19C240DB]  (AR v2)
Track  5  cannot be verified as accurate (confidence 69)  [7B6D6652], AccurateRip returned [16F79A4F]  (AR v2)
Track  6  cannot be verified as accurate (confidence 69)  [FE39B5E1], AccurateRip returned [89378EE9]  (AR v2)
Track  7  cannot be verified as accurate (confidence 69)  [BC05E306], AccurateRip returned [BB29522F]  (AR v2)
Track  8  cannot be verified as accurate (confidence 69)  [576E524E], AccurateRip returned [49BBA1C1]  (AR v2)
Track  9  cannot be verified as accurate (confidence 69)  [B35D814D], AccurateRip returned [4F5DCCDB]  (AR v2)
Track 10  cannot be verified as accurate (confidence 68)  [87E2CEB4], AccurateRip returned [2F26BC22]  (AR v2)
No tracks could be verified as accurate
You may have a different pressing from the one(s) in the database
End of status report
---- CUETools DB Plugin V2.1.3
[CTDB TOCID: x0EG7SCcp_M0cPDj7jbwzYVQHns-] found, Submit result: discs with pregaps not supported in this protocol version
[fe1a93dc] (162/162) No match
Obviously there were problems in reading the data correctly (timing problems, mismatching crc, failed accuraterip verification), but how shall I interpret the information given by eac: "No errors occurred"?
Many thanks, if someone could help me!
Harald
Post by: korth on 2012-11-28 14:11:16
From the EAC (http://www.exactaudiocopy.de/en/index.php/support/faq/extraction-questions/) site:
Question: When using burst mode, EAC also shows up timing problems, are these really errors or what?
Answer: No, burst mode has no error detection nor error correction. If burst mode brings up a timing problem, the read command needed a lot of time, which could have several reasons, like loosing sync or trying to fix an read error. Of course this is a really poor “error detection” and should not be taken as serious indication.
Did you try using a 'secure' mode?
Post by: Porcus on 2012-11-28 18:28:58
Well I don't think Killers was ever re-released with that pesky copy protection.
Post by: themanintheshadows_2451 on 2012-11-28 18:35:12
2nd that.
Post by: harto69 on 2012-11-29 07:03:23
Clearly my fault, I had to think about that!
Tried to rip the CD in secure mode, it took more than three hours for ripping 10 minutes of the album, then I aborted the operation. I suppose the Cd is so damaged, that an accurate reading is impossible.
Thanks fpr your kind help!
Harald
Post by: Surfi on 2012-11-29 12:33:13
... and you might want to use the latest CTDB Plugin (http://www.cuetools.net/wiki/CTDB_EAC_Plugin) with Exact Audio Copy ...
Regards, ...
