Topic: CUERipper gives different track signature/crc32 from EAC in AccurateRip summary (Read 532 times) previous topic - next topic
I was bored and ripped the same CD twice using EAC and CUEripper. The result are identical, as expected.
However I noticed the signature/crc32 for each track in "AccurateRip summary" for each are different.
EAC:
AccurateRip summary
Track  1  accurately ripped (confidence 2)  [23FA9D4F]  (AR v2)
Track  2  accurately ripped (confidence 2)  [CDA7E211]  (AR v2)
Track  3  accurately ripped (confidence 2)  [187EE0BD]  (AR v2)
All tracks accurately ripped
CUERipper:
AccurateRip summary
Track  1  accurately ripped (confidence 2)  [AA821E85]
Track  2  accurately ripped (confidence 2)  [BCC5CD24]
Track  3  accurately ripped (confidence 2)  [C787E794]
This doesn't make sense to me. Could any explain why does this happen?
The full logs, if needed:
Exact Audio Copy V1.6 from 23. October 2020
EAC extraction logfile from 27. May 2023, 14:41
Various / 『アイドルマスター ミリオンライブ! Blooming Clover』第13巻限定版オリジナルCD
Used drive  : PIONEER BD-RW   BDR-209D   Adapter: 1  ID: 1
Read mode               : Secure
Utilize accurate stream : Yes
Defeat audio cache      : Yes
Make use of C2 pointers : No
Read offset correction                      : 667
Overread into Lead-In and Lead-Out          : No
Delete leading and trailing silent blocks   : No
Null samples used in CRC calculations       : Yes
Used interface                              : Native Win32 interface for Win NT & 2000
Used output format              : User Defined Encoder
Selected bitrate                : 896 kBit/s
Quality                         : High
Add ID3 tag                     : No
Command line compressor         : C:\Program Files (x86)\foobar2000\encoders\flac.exe
Additional command line options : -8 -V %source%
TOC of the extracted CD
     Track |   Start  |  Length  | Start sector | End sector
        1  |  0:00.00 |  3:57.60 |         0    |    17834
        2  |  3:57.60 |  4:11.32 |     17835    |    36691
        3  |  8:09.17 | 42:14.14 |     36692    |   226755
Range status and errors
Selected range
     Filename D:\Various - 『アイドルマスター ミリオンライブ! Blooming Clover』第13巻限定版オリジナルCD.wav
     Peak level 97.6 %
     Extraction speed 7.6 X
     Range quality 100.0 %
     Copy CRC 14A0B853
     Copy OK
No errors occurred
AccurateRip summary
End of status report
---- CUETools DB Plugin V2.2.2
[CTDB TOCID: VSDDdZKNRsb.ozjkCK6Qbme4BpI-] found
Submit result: already submitted
Track | CTDB Status
  1   | (29/29) Accurately ripped
  2   | (29/29) Accurately ripped
  3   | (29/29) Accurately ripped
==== Log checksum 45FC62EF81410ACE6A363C4ED0177CBA68DA59ADE056B262550EE1BFF1EEA836 ====
CUERipper v2.2.3 Copyright (C) 2008-2023 Grigory Chudov
EAC extraction logfile from 27. May 2023, 16:54
Unknown Artist / Unknown Title
Used drive  : PIONEER BD-RW   BDR-209D   Adapter: 1  ID: 0
Read mode               : Secure
Used output format : Internal WAV Routines
Sample format      : 44.100 Hz; 16 Bit; Stereo
Selected range
     Filename D:\Unknown Artist - Unknown Title.wav
     Peak level 97.6 %
     Copy CRC 14A0B853
     Copy OK
No errors occurred
AccurateRip summary
Re: CUERipper gives different track signature/crc32 from EAC in AccurateRip summary
EAC is showing the AccurateRip v2 values; CUERipper/CUETools only use AR v1.
Ah, never knew that's what ARv2 means.
Thanks for the prompt reply!
AccurateRip CRC checksums are not CRC32. AccurateRip-CRC-Calculation
[...] CUERipper/CUETools only use AR v1.
Well that's not entirely accurate.
CUERipper shows the ARv1 CRC but gives a combined confidence value of ARv1+ARv2=value
This may not be the best approach but that's what is happening.
In the same directory as the CUERipper rip, there should be a *.accurip file. This file can be opened with a text editor such as notepad.
This file will show ARv1 AND ARv2 CRCs for your rip and the separate confidence values.
example: from the CUERipper extraction log
AccurateRip summary
Track  1  accurately ripped (confidence 356)  [3DDF6BD8]
Track  2  accurately ripped (confidence 355)  [9645D25D]
Track  3  accurately ripped (confidence 357)  [DCC370D3]
Track  4  accurately ripped (confidence 356)  [6CCEE465]
Track  5  accurately ripped (confidence 359)  [67A97C12]
Track  6  accurately ripped (confidence 359)  [C6604FB6]
Track  7  accurately ripped (confidence 356)  [DAC4631B]
Track  8  accurately ripped (confidence 356)  [0EBE1180]
From the .accurip file
[AccurateRip ID: 000c2e2b-005037da-7d08d408] found.
Track   [  CRC   |   V2   ] Status
 01     [3ddf6bd8|431479ef] (156+200/1165) Accurately ripped
 02     [9645d25d|43ef45d4] (155+200/1165) Accurately ripped
 03     [dcc370d3|cf1e31f1] (157+200/1169) Accurately ripped
 04     [6ccee465|cdda1b5a] (156+200/1165) Accurately ripped
 05     [67a97c12|34a9ada2] (159+200/1167) Accurately ripped
 06     [c6604fb6|073b5603] (159+200/1162) Accurately ripped
 07     [dac4631b|aa1f4d98] (156+200/1161) Accurately ripped
 08     [0ebe1180|b391b2bc] (156+200/1149) Accurately ripped
The CRC column shows the ARv1 CRCs. The V2 column shows the ARv2 CRCs.
nnn+nnn are the confidence values ARv1+ARv2. /nnn is the combined total of all confidence values (including any possible alternate pressings).
Note: only the top section will show ARv2 CRC and confidence. These are the CRCs and confidence values for your rip (after rip offset correction, if any). Any additional results below the top section are possible alternate pressings found at other offsets and only ARv1 CRCs and confidence values are provided.
korth
