Topic: normalizing (Read 4396 times) previous topic - next topic
normalizing
Hi
I have a question about normalizing uncompressed recordings from fm broadcastings, when should I use normalizing? have a few recordings with peakleves around 70% and up, should I normalize these ones or just leave them as they are?
and if I should normalize, what should I set the levels to?
normalizing
I would recommend using Replaygain instead of Normalizing. Normalizing permanently edits the datastream whereas Replaygain only sets a tag value on how should the volume be modified for optimal playback results.
normalizing
[a href="index.php?act=findpost&pid=272970"][{POST_SNAPBACK}][/a]
thanks!
normalizing
Hi
[a href="index.php?act=findpost&pid=272952"][{POST_SNAPBACK}][/a]
Depends on what you want to do with the files. Default is not to change the audio in any way, thus to avoid normalizing. Borisz' suggestion does this.
I know that I know nothing. But how can I then know that ?
normalizing
Hello,
To achieve a true normalization uses some specific software of edition to the of treatment:
Cool Edict Pro 2.0, Wavelab 5.0 MagiX Samplitude 7.. etc..
normalizing
Hello,
[a href="index.php?act=findpost&pid=274638"][{POST_SNAPBACK}][/a]
One doesn't need an expensive wav editor for that simple task, although I'm using CEP.
It should be possible with EAC's (costs: 0€) wav editor, for example.
Normalization in 16bit (audio CD) format is a very simple process; it just multiplies every sample with the same normalization factor. Note that there are no differences in the quality between different programs, unless the audio is dithered.
normalizing
Hello precisionist,
I gave out a personal opinion rightly because I make the mastering audio, and there I believe over to know the finality of the product.
Otherwise, with regard to the price to our time, NET doesn't endure a no reproach.
To make is a thing but well to make differs by far.
normalizing
Hello precisionist,
[a href="index.php?act=findpost&pid=274943"][{POST_SNAPBACK}][/a]
Please stop talking gibberish.
Normalizing is a well understood process and there are no quality differences in it, except if you use dithering, as was already stated above.
normalizing
I apologize Garf, you are perfectly right.
The goal of the forum resides in the sharing of the ideas and no in the "friction of the terms"
To soon Garf
