Hi!
My foobar crashes if I try to select "search in..." "Playlist" or "All Playlists"
Visual Studio Just-In-Time Debugger
An unhandled win32 exception occurred in foobar2000.exe [3228]. Just-In-Time debugging this exception failed with the following error: No installed debugger has Just-In-Time debugging enabled. In Visual Studio, Just-In-Time debugging can be enabled from Tools/Options/Debugging/Just-In-Time.
Check the documentation index for 'Just-in-time debugging, errors' for more information.
OK
Core (2009-06-07 14:28:34)
foobar2000 core 0.9.6.8
foo_abx.dll (2009-06-07 14:25:26)
ABX Comparator 1.3.4
foo_converter.dll (2009-06-07 14:26:38)
Converter 1.2.1
foo_DeleteCurrent.dll (2008-06-30 18:00:02)
FooBar2000 Delete Current Track 1.0.0.0
foo_dsp_std.dll (2009-06-07 14:26:54)
Standard DSP Array 1.0
foo_fileops.dll (2009-06-07 14:25:30)
File Operations 2.1.2
foo_input_std.dll (2009-06-07 14:26:30)
Standard Input Array 1.0
foo_rgscan.dll (2009-06-07 14:26:22)
ReplayGain Scanner 2.0.8
foo_run.dll (2009-03-27 22:49:54)
Run services 0.3.6
foo_texttools.dll (2009-01-31 14:23:38)
Text Tools 1.0.3
foo_ui_columns.dll (2009-04-12 17:47:15)
Columns UI 0.3.6.8
foo_ui_std.dll (2009-06-07 14:27:04)
Default User Interface 0.9.5
foo_uie_bookmarks.dll (2008-07-19 18:29:50)
Bookmarks 0.2.6
foo_uie_quicksearch.dll (2007-05-18 13:31:10)
Quick Search Toolbar 2.8l
