Topic: Metadata in Speex encoded files (Read 5444 times) previous topic - next topic
I can't find anything about metadata-handling in speex files on speex.org, so could someone please enlighten me?
Does Speex use vorbis comments? If not, does anyone know where I can find some information about speex tags?
~ Florian
Hi Florian,
Yes, Speex uses Vorbis Comments.
http://www.vergenet.net/~conrad/sounds/tex...extual_data.txt
1.8 Ogg Vorbis, Speex
  Ogg Vorbis [5] is an audio compression format designed for "mid to
  high quality" recordings of audio and music. Speex [6] is a low bitrate
  voice codec. The normal file storage method for these codecs is an Ogg
  bitstream, for which both make use of "Vorbis comment"[7] packets.
Addition: Ogg FLAC also makes use of Vorbis Comments.
Regards,
Sebastian Mares
Hi Sebastian,
that's fine  Thanks for the information!
Regards,
~ Florian
Speex uses Vorbis comments -like tagging which is stored in packet number 1. Official speexenc encodes the tags incorrectly (no UTF-8) but otherwise it's good source for checking how the tagging works.
Case, thanks for the details - I'll have a look at this.
Case, I've just noticed the speexfile class in foo_speex and want to ask you if I may reuse portions of your code?
~ Florian
~ Florian
Sure. That's why the code is open.
~ Florian
BTW: I've noticed some minor issues and posted some thougths about speexfile at this topic.
