i have a question regarding playlist dropdown.
if it's possible to do what i ask for:
i want a code for Playlist dropdown so that the list will look like this:
the first three playlists are just loose songs, but artist 1-10 are auto playlists.
i just want a code to seperate the autoplaylist section from the rest. the dotted line is what i want to seperate them ....... sorry for the crappy english and the crappy explanation
Mix
Various Artists
Most Played
artist 1
artist 2
artist 3
artist 4
artist 5
artist 6
artist 7
artist 8
artist 9
artist 10
an empty playlist named "........................." is the only way.
yes an empty playlist named just '-' (minus sign) and the dropdown playlist panel will draw a full line.
thanks for the help, what should i put in the sort settings of playlist dropdown ?, cause when add for example, autoplaylist named gravestompers and then a playlist named acdc, it sorts it with gravestompers first, and the line is not where it should be ? if you know what i mean ?, if i make it sorted by %title% the line is put in the wrong spot , how to do
