Topic: [@Case] Mass-copying tags between files (Read 2434 times) previous topic - next topic
is there any way to mass-copy tags from file to file with Tag? For example, I have an album in MPC format, and a FLAC copy for archival (with exactly the same file names). I'd like to copy all tags from the MPCs to the FLAC files (not the APE tag itself of course, I mean APE -> VorbisComment), because re-writing all those "Composer" and "Producer" tags (which, unfortunately, happen to be different from track to track in some cases) would be a pain for several albums.
I tried using --fromfile with wildcards, but that didn't work out.
Thanks in advance ,
Dominic
edit: oops.
While waiting for Tag to have native support for task like this, use copytags. It is simple and uses Tag to do the copying, but it should work
Command syntax: copytags <source dir> <destination dir>.
This is *awesome* service! (w00t)
It works excellent! Thanks a lot, man.
