-V5 --vbr-new -Y - %d
I am using the above line in foosbare with lame 3.97b and it renames my file like so:
Mozart Sull'aria (Le Nozze Di Figaro, Act III).wav
to
1 Mozart Sull'aria (Le Nozze Di Figaro, Act III).mp3
How do I get it to disable the renaming....yes, i am trying to keep it in the same folder...
thanks
Open foobar Preferences > Tools > Converter. At the top of this window are the settings for Output File Names, where it says single tracks you probably have [%list_index% ]%title%, just remove [%list_index% ] and leave %title%.
BTW, in your Lame command line -V5 --vbr-new -Y - %d, -Y is not needed, it is used by defauly in settings -V 3 and below, just use the slider and point it at -V5 and check "Fast mode (--vbr-new).
thanks!
