Topic: foo_dsp_effect (Read 251741 times) previous topic - next topic
foo_dsp_effect
Reply #75
I will fix up the filter dialog for the CD deemph filter.
Constants are hardcoded so the sliders don't make a difference.
foo_dsp_effect
Reply #76
done, updated.
foo_dsp_effect
Reply #77
About foo_dsp_effect 0.7.3 I hope the percentage sliders for high shelf & low shelf will appear again in next plugin release.Thank you in advance !!! I use it in combination with Real Bass Exciter plugin [ http://vipercn.com/soft-download/rbe_english/ ] using AKG K141 MkII headphones with PHILIPS Acoustic Edge PSC 706 soundcard and it gives me a truely tremendous musicality !!! Thank you for your work.Best wishes )
foo_dsp_effect
Reply #78
I found that modding Q factors for those filters made no real audible difference. Hence why I removed it, since I wanted to simplify things.
foo_dsp_effect
Reply #79
In fact,I realize that no modification can be heard when using High shelf db slider in foo dsp effects 0.7.3 plugin release
foo_dsp_effect
Reply #80
Fixed in 0.7.4.
Enjoy your gain control in high shelf filters.
Oh yeah, you might want to read TOS#8.
foo_dsp_effect
Reply #81
Fixed in 0.7.4.
What's subjective about correctly claiming that the high shelf filter wasn't doing anything?
foo_dsp_effect
Reply #82
That wasn't the issue, since that is not even a TOS issue at all.
How the hell you came to that conclusion is really beyond me, really.
The issue was the blatant discussion of said BS:
If people want shit done, they better make objective claims and ABX tests to back anything up. Oh yeah, graphs and crap don't count.
I really have better things to do then entertain people with dealing w/ utter bullshit.
foo_dsp_effect
Reply #83
Awesome ! Thank you so much for your lightspeed response for the plugin release.All my aknowledgment and be sure your work is deeply appreciated !!!
foo_dsp_effect
Reply #84
Heh, sorry.  I even saw that part of the conversation, but got thrown off by the fact that it was a few posts back, so I butted in for absolutely nothing.
foo_dsp_effect
Reply #85
Well thats awfully good to know. You keep doing that. >_>
foo_dsp_effect
Reply #86
Hi Mudlord, thanks for your plugins
Im trying to replicate my vlevel settings [(strenght=0.80, max multi=25, buffer=2s), as it seems its no longer supported] to your "dynamic compressor" dsp, but dont find a satisfaying setting, you can either hear the compressor pumping, or its saturating, etc
Vlevel was much more transparent.
Any tip ?
Of course, vlevel support would be easier (i guess that, sooner or later, it wont work anymore on future foobar versions).
Cheers
foo_dsp_effect
Reply #87
Personally I hardly use the dynamics compressor.
kode54's normalizer DSP should be more to your needs, as it dynamically sets volume level just like vlevel. And its fast too.
foo_dsp_effect
Reply #89
thanks
foo_dsp_effect
Reply #90
Time to remove acropolis' component!
foo_dsp_effect
Reply #92
Because each sub DSP instance is instance and thread safe, you can stack multiple tempo DSP entries to do this.
foo_dsp_effect
Reply #93
Seems "GNU GPL fuckers" problem is gone, once again back
Thanks for the great component.
foo_dsp_effect
Reply #95
is it possible to add cents resolution (0.35 semitones for example) in pitch modification, as Acropolis did in his component ?
thanks in advance
foo_dsp_effect
Reply #96
Indeed, that is planned in the pipeline.
Maybe next release?
edit: Done for 0.9.
foo_dsp_effect
Reply #97
I have a reproducible crash: when in playback rate shift the slider is moved to -100% foobar2000 crashes. Crash report submitted.
foo_dsp_effect
Reply #98
Thanks, acquiring the crash logs now.
EDIT: I see the problem. Didn't read ST's header fully on what rates are allowed for rate/tempo modification.
0.9.1 will fix the issue.
foo_dsp_effect
Reply #99
Hey Mudlord..... I've been having a major problem with the Effect DSP component since i upgraded...... Heres the thing..... I've had 0.6.1 up until today and i downloaded the newest 0.9.1 .dll..... and now..... how do i explain it..... When i listen to music of any kind, the bass or bass kick will hit, but then the volume suddenly drops..... then turns back up...... i dont know why its doing this, but its bugging me so much... Could you please help? I just want my music to sound normal with no sudden volume drops....
