Topic: Unintended/accidental AVX requirement of 64-bit version (Read 1191 times) previous topic - next topic
Dear userbase,
I just noticed that foobar2000 64-bit crashes when using ReplayGain scanner on old computers without AVX instruction set.
This is completely unintended and caused by a bug in latest Microsoft compiler, which produces AVX opcodes even if configured not to in 64-bit mode.
If you are affected by this problem, please either stick with older foobar2000 or use 32-bit version on your computer.
I'm working on a workaround (it's not my bug...) and will revert to older compiler if necessary.
Re: Unintended/accidental AVX requirement of 64-bit version
Yes, @Peter, I am affected, that's why I still use Foobar2000 2.1 x64 (2023-12-18).
• Join our efforts to make Helix MP3 encoder great again
• Opus complexity & qAAC dependence on Apple is an aberration from Vorbis & Musepack breakthroughs
• Let's pray that D. Bryant improve WavPack hybrid, C. Helmrich update FSLAC, M. van Beurden teach FLAC to handle non-audio data
If this is the same thing...
https://developercommunity.visualstudio.com/t/Cannot-disable-AVX-and-AVX2-in-VS-2022/10497078?space=21&scope=follow&sort=newest
... it's supposedly fixed in VS2022 17.10 - currently preview so could be tested.
Known.
I'm waiting till VS2022 17.10 before attempting any "fixes" in fb2k 2.2 series, hoping for the problem to fix itself without having to revert C++20 use in new code.
This isn't the first time stuff like this happens, as older versions of VS were known to produce SSE opcodes when configured not to.
Fixed version:
https://www.foobar2000.org/downloads/foobar2000-x64_v2.1.4-VS2019.exe
If nothing broke from compiler downgrade, I'll keep using VS2019 for foobar2000 2.1.x series updates.
Thanks! This version fixes the issue together with my intel j5005.
