Hi Guys,
Hope you can help me with this problem. I'm having a problem Ripping a CD Securely with Accurate Rip by any good reputable software like EAC, DBPoweramp, Foobar2k etc with the CD titled SLAPSHOCK: PROJECT 11-41 By EMI Philippines Copyright 2002. I can say this CD has NO COPY PROTECTION as it was not indicated in the CD packaging. There is only 1 session in it as seen by ISOBUSTER which has the Track Files so no 2nd sessions or data files. I bought 3 copies of this CD only to find out it has the same errors when ripping and tried 2 different CD Rom Drives. I also found out the gaps on the disc are weird or unusual. I have ripped a lot of my CDs securely, Test & Copy, comparing with Accurate Rip successfully. I also have no problems whatsoever with my settings as Ive followed every set up guide for each Ripping Software. My problem is only with this particular disc. Hoping for your help guys. Thanks.
On this screenshot, it shows the gap on the Disc.
This is the Cuesheet generated by EAC, Multiple WAV Files With Gaps...Non Compliant
REM GENRE Metal
REM DATE 2002
REM DISCID BB11370E
REM COMMENT "ExactAudioCopy v1.0b3"
FILE "Slapshock-Project 11-41-CD-FLAC-2002-gil\01-Slapshock-Wake Up.wav" WAVE
TRACK 01 AUDIO
INDEX 01 00:00:00
TRACK 02 AUDIO
INDEX 00 04:06:48
FILE "Slapshock-Project 11-41-CD-FLAC-2002-gil\02-Slapshock-Satellite Kid.wav" WAVE
INDEX 01 00:00:00
FILE "Slapshock-Project 11-41-CD-FLAC-2002-gil\03-Slapshock-Countdown.wav" WAVE
TRACK 03 AUDIO
INDEX 01 00:00:00
TRACK 04 AUDIO
INDEX 00 04:51:04
FILE "Slapshock-Project 11-41-CD-FLAC-2002-gil\04-Slapshock-Queen Paranoia.wav" WAVE
INDEX 01 00:00:00
TRACK 05 AUDIO
INDEX 00 04:30:01
FILE "Slapshock-Project 11-41-CD-FLAC-2002-gil\05-Slapshock-Swallow.wav" WAVE
INDEX 01 00:00:00
TRACK 06 AUDIO
INDEX 00 03:57:45
FILE "Slapshock-Project 11-41-CD-FLAC-2002-gil\06-Slapshock-Mother's Eye.wav" WAVE
INDEX 01 00:00:00
TRACK 07 AUDIO
INDEX 00 04:07:56
FILE "Slapshock-Project 11-41-CD-FLAC-2002-gil\07-Slapshock-Get Down.wav" WAVE
INDEX 01 00:00:00
TRACK 08 AUDIO
INDEX 00 04:27:29
FILE "Slapshock-Project 11-41-CD-FLAC-2002-gil\08-Slapshock-Windshield.wav" WAVE
INDEX 01 00:00:00
FILE "Slapshock-Project 11-41-CD-FLAC-2002-gil\09-Slapshock-Numb.wav" WAVE
TRACK 09 AUDIO
INDEX 01 00:00:00
TRACK 10 AUDIO
INDEX 00 05:39:37
FILE "Slapshock-Project 11-41-CD-FLAC-2002-gil\10-Slapshock-Sunday Shivers.wav" WAVE
INDEX 01 00:00:00
TRACK 11 AUDIO
INDEX 00 04:50:55
FILE "Slapshock-Project 11-41-CD-FLAC-2002-gil\11-Slapshock-Anino Mo.wav" WAVE
INDEX 01 00:00:00
FILE "Slapshock-Project 11-41-CD-FLAC-2002-gil\12-Slapshock-Enemy.wav" WAVE
TRACK 12 AUDIO
INDEX 01 00:00:00
TRACK 13 AUDIO
INDEX 00 05:14:50
FILE "Slapshock-Project 11-41-CD-FLAC-2002-gil\13-Slapshock-Bleed.wav" WAVE
INDEX 01 00:00:00
TRACK 14 AUDIO
INDEX 00 04:20:24
FILE "Slapshock-Project 11-41-CD-FLAC-2002-gil\14-Slapshock-Fuck You (Remix).wav" WAVE
INDEX 01 00:00:00
LOGFILE
Exact Audio Copy V1.0 beta 3 from 29. August 2011
EAC extraction logfile from 15. February 2014, 10:44
Slapshock / Project 11-41
Used drive : TSSTcorpCDDVDW SH-222BB Adapter: 1 ID: 0
Read mode : Secure
Utilize accurate stream : Yes
Defeat audio cache : No
Make use of C2 pointers : No
Read offset correction : 6
Overread into Lead-In and Lead-Out : No
Delete leading and trailing silent blocks : No
Null samples used in CRC calculations : Yes
Used interface : Native Win32 interface for Win NT & 2000
Gap handling : Appended to previous track
Used output format : User Defined Encoder
Selected bitrate : 768 kBit/s
Quality : High
Add ID3 tag : No
Command line compressor : C:\Program Files (x86)\Exact Audio Copy\FLAC\FLAC.EXE
Additional command line options : -8 -V -T "ARTIST=%artist%" -T "TITLE=%title%" -T "ALBUM=%albumtitle%"
-T "DATE=%year%" -T "TRACKNUMBER=%tracknr%" -T "GENRE=%genre%" -T "COMMENT=%comment%" -T
"BAND=%albuminterpret%" -T "ALBUMARTIST=%albuminterpret%" -T "COMPOSER=%composer%"
%haslyrics%--tag-from-file=LYRICS="%lyricsfile%"%haslyrics% -T "DISCNUMBER=%cdnumber%" -T
"TOTALDISCS=%totalcds%" -T "TOTALTRACKS=%numtracks%"
%hascover%--picture="%coverfile%"%hascover% %source% -o %dest%
TOC of the extracted CD
Track | Start | Length | Start sector | End sector
1 | 0:00.00 | 4:06.62 | 0 | 18511
2 | 4:06.62 | 5:22.04 | 18512 | 42665
3 | 9:28.66 | 4:51.44 | 42666 | 64534
4 | 14:20.35 | 4:30.59 | 64535 | 84843
5 | 18:51.19 | 3:58.24 | 84844 | 102717
6 | 22:49.43 | 4:08.63 | 102718 | 121380
7 | 26:58.31 | 4:30.23 | 121381 | 141653
8 | 31:28.54 | 4:48.20 | 141654 | 163273
9 | 36:16.74 | 5:40.30 | 163274 | 188803
10 | 41:57.29 | 4:53.23 | 188804 | 210801
11 | 46:50.52 | 4:59.24 | 210802 | 233250
12 | 51:50.01 | 5:15.35 | 233251 | 256910
13 | 57:05.36 | 4:29.46 | 256911 | 277131
14 | 61:35.07 | 11:52.36 | 277132 | 330567
Track 1
Filename D:\Yan Yan Files\Slapshock-Project 11-41-CD-FLAC-2002-gil\01-Slapshock-Wake Up.wav
Pre-gap length 0:00:02.00
Peak level 100.0 %
Extraction speed 4.5 X
Track quality 99.9 %
Test CRC 629DFAC3
Copy CRC 90FEAED4
Cannot be verified as accurate (confidence 1) [C16D8B90], AccurateRip returned [39459BEB] (AR v2)
Copy OK
Track 2
Filename D:\Yan Yan Files\Slapshock-Project 11-41-CD-FLAC-2002-gil\02-Slapshock-Satellite Kid.wav
Pre-gap length 0:00:00.14
Peak level 100.0 %
Extraction speed 5.2 X
Test CRC 0A63B0A2
Copy CRC 74D8005F
Cannot be verified as accurate (confidence 1) [7A465E2E], AccurateRip returned [449B1006] (AR v2)
Copy OK
Track 3
Filename D:\Yan Yan Files\Slapshock-Project 11-41-CD-FLAC-2002-gil\03-Slapshock-Countdown.wav
Peak level 100.0 %
Extraction speed 6.0 X
Track quality 100.0 %
Test CRC 87915A5F
Copy CRC 87915A5F
Cannot be verified as accurate (confidence 1) [C1E5EB91], AccurateRip returned [40AA2C22] (AR v2)
Copy OK
Track 4
Filename D:\Yan Yan Files\Slapshock-Project 11-41-CD-FLAC-2002-gil\04-Slapshock-Queen Paranoia.wav
Pre-gap length 0:00:00.40
Peak level 100.0 %
Extraction speed 6.4 X
Test CRC 171AF2E9
Copy CRC 171AF2E9
Cannot be verified as accurate (confidence 2) [CFAA1097], AccurateRip returned [F87E051F] (AR v2)
Copy OK
Track 5
Filename D:\Yan Yan Files\Slapshock-Project 11-41-CD-FLAC-2002-gil\05-Slapshock-Swallow.wav
Pre-gap length 0:00:00.58
Peak level 100.0 %
Extraction speed 6.7 X
Test CRC 99EA6E29
Copy CRC 99EA6E29
Accurately ripped (confidence 2) [3DD07D30] (AR v2)
Copy OK
Track 6
Filename D:\Yan Yan Files\Slapshock-Project 11-41-CD-FLAC-2002-gil\06-Slapshock-Mother's Eye.wav
Pre-gap length 0:00:00.54
Peak level 100.0 %
Extraction speed 6.3 X
Test CRC 0D909B7E
Copy CRC 0D909B7E
Cannot be verified as accurate (confidence 2) [44D9A5D6], AccurateRip returned [B5F09C10] (AR v2)
Copy OK
Track 7
Filename D:\Yan Yan Files\Slapshock-Project 11-41-CD-FLAC-2002-gil\07-Slapshock-Get Down.wav
Pre-gap length 0:00:01.07
Peak level 100.0 %
Test CRC 5CC08A0E
Copy CRC 5CC08A0E
Cannot be verified as accurate (confidence 1) [84B4719E], AccurateRip returned [107B98B0] (AR v2)
Copy OK
Track 8
Filename D:\Yan Yan Files\Slapshock-Project 11-41-CD-FLAC-2002-gil\08-Slapshock-Windshield.wav
Pre-gap length 0:00:02.69
Peak level 100.0 %
Extraction speed 4.4 X
Track quality 99.7 %
Test CRC 62CA5556
Copy CRC 58032392
Cannot be verified as accurate (confidence 1) [50DEF1FE], AccurateRip returned [BDC64E94] (AR v2)
Copy OK
Track 9
Filename D:\Yan Yan Files\Slapshock-Project 11-41-CD-FLAC-2002-gil\09-Slapshock-Numb.wav
Copy aborted
Track 10
Filename D:\Yan Yan Files\Slapshock-Project 11-41-CD-FLAC-2002-gil\10-Slapshock-Sunday Shivers.wav
Pre-gap length 0:00:00.68
Copy aborted
Track 11
Filename D:\Yan Yan Files\Slapshock-Project 11-41-CD-FLAC-2002-gil\11-Slapshock-Anino Mo.wav
Pre-gap length 0:00:02.43
Suspicious position 0:00:00
Copy aborted
Track 12
Filename D:\Yan Yan Files\Slapshock-Project 11-41-CD-FLAC-2002-gil\12-Slapshock-Enemy.wav
Copy aborted
Track 13
Filename D:\Yan Yan Files\Slapshock-Project 11-41-CD-FLAC-2002-gil\13-Slapshock-Bleed.wav
Pre-gap length 0:00:00.60
Copy aborted
Track 14
Filename D:\Yan Yan Files\Slapshock-Project 11-41-CD-FLAC-2002-gil\14-Slapshock-Fuck You (Remix).wav
Pre-gap length 0:00:09.22
Copy aborted
1 track(s) accurately ripped
7 track(s) could not be verified as accurate
6 track(s) canceled
Some tracks could not be verified as accurate
There were errors
End of status report
==== Log checksum 5E1FD6063BB9F567554AECC09305D9BDD6899E8428A460D536B9885F82192728 ====
