Topic: Bugged playback time reported by foobar (Read 325 times) previous topic - next topic
This is an error I have had sometimes but had not been able to reproduce it until now (and make captures)
Noticed it because some components or scripts were crashing when the float value was expected to be lower than a safe integer.
The console (%playback_time_seconds%):
- For JSP3: [11:27:24] JSP3 3,1638862116397E+134
- For SMP: [11:20:17] 3.1638862116397002e+134
The status bar (%playback_time%):
- CUI: 3150551671 Wk ...
Playlist: (%playback_time_seconds%):
- CUI: -9223372036854775808
Since the bugged value is provided to CUI and all components and display elements, it is not only a SMP error. I have experienced this at v1.6.17 (win 11)
The file is paused (?) but fb is playing. I am not sure how I reach this point, has happened to me sometimes when playing a file but pausing it too fast (I think).
I don't use any kind of components for loops or things like that.
Re: Bugged playback time reported by foobar
Why are you using old 1.6.x version? I know Peter found null output related bugs in 2023 and 2024, which I assume are fixed in 1.6.18. Definitely fixed in 2.x series. I think it's highly likely your problem is related to null output.
That's a good question  ::) , somehow I missed the update on this system. Didn't bother to check, since I'm using 1.6.18 in the other systems, and thought it was already the last one. Thanks for mentioning it.
I don't really know how to trigger the problem, so meanwhile we can suppose that's the bug you mentioned. If I find it at 1.6.18 I will report it.
