Topic: [Not My Release] EsPlaylist (Read 338903 times) previous topic - next topic
Reply #450
Does this plugin support this function:
$rgb(r1,g1,b1,r2,g2,b2)
Sets the color for text. r1, g1 and b1 are the red, green and blue component of the color for unselected text. r2, g2 and b2 are the red, green and blue component of the color for selected text.
I know it works for $rgb(r1,g1,b1), but with white vs. black, changing the selected text color is important too...
Reply #451
Hey guys, apologies in advance if this question has been answered in the past but my searching hasn't returned anything conclusive.
Basically, I'm trying to set up two instances of EsPlaylist; one that shows my contemporary music, and one that shows my classical. This is due to the difference in tagging style between the two types of music. I cannot seem to find a way to script EsPlaylist to conditionally show tracks based on criteria; the foobar IF statement doesn't seem to allow for this. Am I right in that assumption? Is there a way to enable something like what I'm looking to do?
Here is a screenshot that shows how I have EsPlaylist (and foobar in general) looking at the moment (theme is a slightly modified Metro by fanco86), and may shed some light onto why some alternative solutions would prove cumbersome:
http://img846.imageshack.us/i/sshot2a.png/
(I've fixed up a lot of the tags since this was taken, thank God)
Any help on this would be much appreciated, thanks guys.
Reply #452
Can anyone confirm performance issues in "Browse Library" Mode, especially when monitoring Media Library is on and any File Operation action like "Move" is used.
In this case foobar hangs for 5-10 seconds.
Is it possible make "Browse Library" mode as fast as Foobar2000 internal Album list tree?
Reply #453
EsPlaylist v0.1.3.7.1(2011/03/23) released.
  • some changes of searchbar.
  •     fixed some minor issues.
Download EsPlaylist v0.1.3.7.1
Reply #454
i'm using esplaylist (latest build, foobar 1.0) and i encounter a strange behaviour...dunno if it's intended or a bug...
i set up a the following grouping:
%artist% - %album%
force sorted is unchecked
disabled only on some playlist
in the panel itself i chose "follow the active playlist"
whenever i change to another playlist, the grouping is changed too...
and it's always changed to the same grouping (the first in the context menu @ grouping > )
is this behavior intended? if so, why?
is there any way too prevent esplaylist from behaving like this?
it is very annoying because i believe that whenever i change the playlist it seems that a grouping is chosen which has force-sorted checked, messing up any sorting i did that does not rely on any specific pattern
btw: feature request:
it would be really nice if it was possible to add a vertical scrollbar such that i can add any number of columns without having to squeeze them too much
edit: is there anyway to prevent esplay list to show a specified playlist? "disable on" doesn't do the trick because the grouping gets changed to another grouping
Reply #455
A question, because I'm probably doing something wrong. I'm using EsPlaylist with Facets. I have set artist=%artist% for Facets.
Let's take the example where %albumartist% is something like "A feat. B". Now in %artist%, I set it to "A; B". The expected behaviour for me would be that both A and B show up separately in the ARTIST filter box, which is what I want. Instead, they show up like "A, B", which kind of defeats the purpose. Using the default artist=%<albumartist>% shows "A feat. B" which doesn't help me either. How do I achieve separating all participating artists?
Reply #456
I have just discovered this plugin, i'd like to use it instead of the chronflow which is very unstable.
But i have few question about this dll...
Why is very very slow to show the thumbnails? it shows the embedded image or that in the folder of the tracks?
I've seen that can show many different view of the library...how i can configure them ordering them by artist and album?
I need something similar to the chronflow/graphical browser...i cannot find the bubble cover flow...
Reply #457
Reply #458
Still loving EsPlaylist - this plugin is really an inexpensible part of foobar!  Today, though, I realized something about a small issue that I've mentioned before:
When clicking-and-holding on a playlist item that isn't already selected the default behavior is making a new selection. However, in Windows I am used to being able to grab files and move them around without selecting them first! Because of this I get slightly irritated every time I try to move stuff around in foobar and it doesn't "stick" but get selected instead.
I never use EsPlaylist's method of selecting things as it is not intuitive to me. So -- could you maybe make this behavior optional?
Reply #459
All in all, there's still the issue with items not "sticking" when dragging them with the mouse quickly...
Try grabbing a group header or an item fast and move it to a different playlist - a lot of times it just stays. The deciding factor is the amount of time the mouse stays over the item after holding down the mouse button.
If, for instance, the mouse is moved horizontally across the item for a little while, the chance of it actually ending up being dragged is bigger than if the mouse is moved upwards (exiting the selection more quickly).
Reply #460
Is it possible to change the color of the stars in the rating column?
Reply #461
If you make your own rating column instead of the built in, you can put $rgb(240,240,0) (for instance) before the title formatting. I recommend you install the playback statistics component (nice plugin) and use this tf:
$rgb(240,240,0)[%rating_stars%]
Reply #463
The best plugin for foobar! Thank you, ssenna!
I have a few questions and/or request... I'm not sure if the functions I need are not supported or I just can't manage to activate them
1. On the first page of this topic I saw a layout, looking like this:
How could I put this information at the right side of the cover? When I put additional column, how could I force multiple genre info to be displayed in separate rows, like in the screenshot?
2. Is it possible to implement in future release the $crlf() function in the title field? It would be great to be able to organize the group header in more then one row.
3. When I switch to "layered view", with "Hide non-focused groups" unchecked, the albums are no more grouped by %artist album%, as in "flat view". Is it possible this level of grouping to be kept in "layered view"?
4. Is it possible to have optional level of grouping? I mean for example if there is metatag for %disc number%, a third level of grouping to be active, otherwise - not. I'v tried to put something like this "$if2(%disc number%)" or "[%disc number%]" in "Grouping field", but it didn't worked - the third level always appears (empty when there's no %disc number%, but the line still stands).
Thank you in advance!
Reply #464
Reply #465
EsPlaylist v0.1.3.8(2011/05/02) released.
  • added drawing a border between each column ( ColumnHeader->Column Options->Show Border )
  • changed title position of group header when the preset has multiple grouping layers in Flat view(fixed) mode.
Download EsPlaylist v0.1.3.8
Note: translation from japan EsPlaylist site
Facet and similar features in the new SimPlaylist so it seems possible, given that it played a role, which may be final version. (Barring bugs).
Reply #466
@Senna GREAT PLUGIN!!!
The Best of Times
Reply #467
In Flat view double click on a group title sands the songs to the playback queue. Is there a way to stop this behavior - I want double click on the title just to start play from the first song in the group, without adding the group in the playback queue. Is that possible? I'll be very grateful if someone could tell how exactly to deactivate this function...
Reply #468
^^ preferences/Tools/ES Playlist/Tab: Behaviour
Reply #469
I'v tried this first, but you can't control this behaviour from there - no matter what options are choosed, it still adds the group to the playback queue... or I miss something...
Reply #470
Absolutely amazing plugin!! Thank you!!
There is one importante setting, that could make it best plugin of all - multiline info below the  Album Art..
I had found two comments in this thread about it:
The ability to use $crlf() within the Title field of the album. This would allow me to include the album artist in the title, thus being able to typefind by album artist. I wouldn't have to worry about the album title being truncated, as it would be on a new line. I could also include more information under the album artwork should I choose to. Alternatively, it would be useful to be able to display the Side Info below the album artwork.
Im telling about this (i made it in Graphical Browser):
[a href="http://imageshack.us/photo/my-images/14/multiline.gif/" target="_blank"]
Reply #471
Thanks for the update  (Even though there wasn't anything particularly useful for me ) I didn't understand that last part of your post, though - could you elaborate a bit? I've tried SimPlaylist, but it doesn't seem half as well-designed as EsPlaylist.
You really caught my attention mentioning the word "facet"... the Facets component, while it is still an inexpensible part of foobar, does need either an update or a replacement - it is so sad to see that it (apparently) has been abandoned without the author leaving any source code
Reply #473
Wow....!!!!
Reply #474
Ssenna, you should really consider making a Flattr profile so I can donate to you.
