Topic: Saving the current playlist by "one click"? Possible? (Read 1090 times) previous topic - next topic
What is the shortest way to save the current playlist to some predefined location (like G:\music\playlists), without having to go through menues, naming the playlists, etc.?
Can this be done?
Re: Saving the current playlist by "one click"? Possible?
Ctrl+S?  If not by default, then go to keyboard shortcuts menu in Preferences and bind your own key sequence for saving it there.
Ok, thanks. I have added the command now.
Or, you can just add a new icon and do it with just one click. However location and playlist name you will need to add manually.
Somewhere, there's someone dying in a foreign land
Meanwhile, the world is crying stupidity of man
Tell me why, tell me why
If you mean saving all playlists you create to a location other than the default I'm not sure (is there a setting for this?). Last I saw someone suggested using junctions to relocate playlists.
Thanks, that tip was good. I have added an icon now, works fine.
