Topic: shortcuts ! (Read 2951 times) previous topic - next topic
shortcuts !
I still have no answer for the shortcuts problem. Is there any core developer? I send all WM_KEYDOWN and WM_SYSKEYDOWN to the shortcut_manager, but it does not work.
shortcuts !
Are you sure, that keyboard_short_manager really is called? Because AFAIK you won't get WM_KEYDOWN messages in a dialog procedure... (or I did something wrong)
shortcuts !
Ooops, I passed wrong parameters
Thanks for your answer, I had to check it again and it works
shortcuts !
You may find it more effective (and likely faster, too) to use IRC to discuss development problems.
The fb2k channel's at #foobar2000 on FreeNode.
