I'm a noob with this technical sort of stuff, but I was wondering if the audio processing stuff included in Vista is better or worse than what we had with XP.
Ok, since I am a noob, this is what I have gathered about XP's audio processing--- the k mixer is bad, and it has a degrading effect on the sound unless you decided to take steps to entirely bypass the k mixer. Correct me if I'm wrong about this.
So I'm wondering, are there any improvements over XP's k mixer with what comes standard with Vista?
I don't know what changes Vista includes with regards to this issue, but i can atleast assure you about kmixer.sys on Windows XP dosen't degrade the sound quality in any percievable way, period I know many people/sites says otherwise, but that's just the same old boring BS nonsence you'll hear around the web, like e.g. that one needs to use insanely expensive audio cables to not degrade the audio quality or that there are differences between differen't CD-R brands in sound quality or that lossless dosen't sound just as "full" as PCM The advantage of bypassing kmixer.sys is to loose those extra 30 ms latency which is usefull on recording but dosen't have any advantage whatsoever on playback, besides of course if the WDM drivers over DirectSound output is buggy, but the ASIO drivers or the WDM drivers when used directly through the DirectKS API isn't. Btw, the non-percievable bit-mangling of kmixer.sys happens because of it's volume-control function, but the bit-mangling only occures on the least significant bit, so no-one will ever be able to ABX it on 16bit music playback and if you play 16 bit audio over 24 bit output, then no bit-mangling will occure at all.
Maybe you can explain something to me... I have M-Audio 2496 sound card with bit-perfect playback and when using ASIO or KS in foobar I can passtrough 16/44.1 DTS signal via S/PDIF to my receiver just fine. But when using DS out via kmixer I get only hiss on speakers so obviously kmixer changes digital stream in some way...?
Vista uses a floating point pipeline in their audio subsystem. It also does SRC on each stream and bit depth conversion on the final mixdown, to a frequency and bit depth specified system-wide.
But the change that quashes DTS doesn't have t9o be great enough to be perceived with regular stereo material.
Contrary to popular belief, the kmixer of XP and 2k doesn't change a thing when you move the wave volume slider to the max. DTS encoded wave files can be played through WaveOut/DSound and through the kernel mixer without any loss.
And I should know, I've developed a driver for the C-Media 8738/8768 which just can do that stunt.
The mixing engine of Vista works with 32bit float samples, so there's actually some information lost in the conversion. But there is a so called "exclusive mode" which is available through the WASAPI. It should give you bitperfect output, albeit I haven't seen software which actually support it (yet).
So are you saying that the audio quality that comes standard for XP is superior to what comes standard for Vista?
The thing that concerns me about difference between XP and Vista is that Vista seems more DRM prone, which doesn't come as a surprise (that's another topic though and I am not trying to sidetrack the discussion). Does it really matter though honestly? I mean if you have Foobar2000 with kernel streaming you should be all set right? Just my two cents
Foobar2000 with KS works in Vista.
I was using an Onkyo Envy24 soundcard.
How do I get KS working in Vista? With a Realtek ALC882, no devices are listed for KS output in Foobar - only DS.
Unfortunately that is not case with my card, even with volume slider(s) maxed out in mixer when using DSound in foobar receiver doesn't pick up DTS signal. It briefly switches to DTS but apparently signal is 'week' and receiver reverts back to hissing instantly so IMHO 'contrary to popular belief' kmixer does change signal. It's true that it doesn't effects PCM 44.1 signal but it surely 'destroys' DTS 44.1 stream (at least im my case).
ONLY way I can get unchanged DTS signal to my receiver is when bypassing kmixer via ASIO or KS plugin.
That's the driver then which modifies the data in one way or the other, not the kernel mixer. Like I said, under the conditions that the Wave Volume is maxed out and that no other stream is playing, bitperfect output is possible under XP and 2k using WaveOut/DSound.
No, it's not that easy. For instance, if the kernel mixer of 2k/XP mixes two loud streams, it's much more prone to nasty clipping due to the limitations of the 16bit format. That won't happen in Vista.
But like I said, it is impossible (or I haven't found a way yet) to forward a regular wave stream bitperfectly to the receiver through DirectSound/WaveOut in Vista.
Drivers which are built around the WaveCyclic/WavePCI model can still be used for kernel streaming in Vista, but if you have to use a WaveRT driver, you'll have to wait for WASAPI support to get bitperfect playback in Vista.
For anyone interessted in this bit-mangling issue of kmixer.sys, then here are some interesting quotes about it. Also, my former post about kmixer.sys is based on this info...
Well, a couple of months ago I managed to get mi CMI8738 based card digital input to work.
Using it, and bit-perfect recording the digital output of my Audiophile card at 44.1 KHz mode, I've been able to verify that kmixer indeed does something to the data passed to it. The change is very subtle, so it was not detectable on my analog measurements of the soundcard output. What I've verified that kmixer does to 16-bit audio data, is just mangle the last bit of the data. It does like some kind of re-dithering of the signal, adding a very little amount of spectrally uniform noise to the signal, so that it is no longer bit-perfect. It also adds a very little amount (around -120 dB amplitude) of distortion that can be considered negligible.
I have measured this noise but I don't have the results at hand right now, but with this noise added, the dynamic range of the 16-bit signal is still better than 90 dB.
I haven't been able to do same tests with 24-bit audio, because I can't get a 24-bit recorded data, but I think this is a problem of my testing configuration, because on analog measurements, the analog output of the card with kmixer processing was able to produce an analog signal with better dynamic range than the possible with 16-bit audio. I'm trying to fix this.
When using kernel streaming and ASIO, the output is bit-perfect in 16-bit mode, as it was supposed. There's some evidence that using directsound acceleration (also called hardware mixing) does same thing as using kernel streaming, and enables getting bit-perfect output. However, I haven't been able to verify this, since my Audiophile card doesn't support it.
Note that when kmixer is acting and you play 44.1 KHz data, it can do do two different things depending on the driver implementation. The first is just this relatively bening bit mangling I've talked about in this post. But on some cards and modes (wave output instead of directsound, for example), it will resample the signal to 48 KHz, and this is a greater change to the signal. I haven't done very detailed tests over this resampling, but it worsens a little bit more the SNR of the signal, causes some low-level distortion and causes a very slight HF rollof. At first I don't think this is audible under usual listening conditions, but I haven't done any listening tests.
Note also that there are some professional-oriented cards that use special WDM drivers that don't suffer from any of those kmixer issues. These drivers don't fully conform to the WDM standard, and can't use kernel streaming, but, on the other side, they don't need it. RME cards for example, use this kind of non-standard, kmixer-free, WDM drivers.
Well, I just did a few more tests. I own now both a Revo and an Audiophile, so I can play all types of data on the digital output of the Revo and record them with the digital input of the Audiophile. I just did some RMAA 4.3 measurements, that uses WDM (directsound) drivers, and here are the results:
I will give results without A weighting, I like it better.
1st figure is reference, best possible value. 2nd is kmixer bit-mangled output.
Frequency response is totally flat in all cases, so is omitted.
16 bit, 44.1 KHz:
Noise: -96.4 dB, -93.4 dB
Dynamic range: 94 dB, 90.9 dB
THD: 0.000%, 0.001%
THD+N: 0.003%, 0.004%
IMD+Noise: 0.006%, 0.008%
Crosstalk @1KHz: -94 dB, -90 dB
The distortion product that appears at the THD measurement is at -110 dB, not -120 as I said previously. It is still a negligible value in my opinion. The biggest difference is the slight increase of the noise floor. As you see, even here the difference is quite small.
24 bit, 44.1 KHz:
Noise: -146.3 dB, -141.5 dB
Dynamic range: 139.5 dB, 137.3 dB
THD: 0.000%, 0.000%
THD+N: 0.000%, 0.000%
IMD+Noise: 0.000%, 0.000%
Crosstalk @1KHz: -141.8dB, -137.2 dB
For 32-bit audio, results are slightly better but very similar.
Taking into account that due to real-world constraints of electronics the best hardware available can't have a dynamic range better than around 120 dB, the effect of kmixer bit-mangling in this case is totally negligible.
And, if you play your 16-bit data as 24 bit or 32 bit, the result is that in practice the full 16-bit resolution is retained, even if you don't use kernel streaming, because the bit-mangling effects are much below 16-bit resolution. In a RMAA measurement, the results in this case were identical to the 16-bit reference results. But this will be true just if your card is a true 24-bit card.
Even when the differences are small or very small and quite possibly inaudible even in the the worst case, this bit-mangling will prevent from bit-perfect digital transfers in any case.
Again, note that this measurements are about this kmixer bit-mangling, which I don't think is any kind of resampling. Measurements of real kmixer resampling (that happens at my card when for example both a stream at 48 KHz and 44.1 KHz are played at same time, or when the output is locked at 48 KHz and you play a 44.1 KHz stream), and its effects are much more evident, see link at a previous post. Resampling produces a worse THD & IMD, easy to see at the THD spectrum, and a slight but measurable difference in frequency response. The effects measured here are just due to some kind of partial "re-dithering" of the signal, probably performed at some stage of kmixer software mixing. But it's not resampling.
As I said at a previous post, on some cards (not Revo) resampling will happen whenever you play a 44.1 KHz stream, or when you use waveout instead of directsound... it depends on the card and its drivers, but in better cards this resampling happens just when it's unavoidable (simultaneous playback of both a 48 and 44.1 stream, or lock of the sampling rate at 48 KHz).
So, the bit-mangling measured here, always, always happens when you play 44.1 KHz data on WinXP (and same seems to happen with Win2K), which is something that AFAIK Microsoft doesn't say. It can be avoided just if you use kernel streaming or ASIO audio interfaces, or your card supports hardware mixing (same as directsound acceleration) and it is enabled.
Note that Creative cards support hardware mixing and kernel streaming, but they internally resample all 44.1 KHz data, so in practice the result is probably even worse that if they use kmixer resampling.
Source : http://www.hydrogenaudio.org/forums/index....st&p=109854 (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=5755&view=findpost&p=109854)
KMixer issue resolved
Here's an update to the KMixer issue.
Some of the design goals for the KMixer that affects this issue are:
1) Create a standard interface to the audio device
2) Handle multiple asynchronous streams of audio
3) Handle streams of different sampling rates
4) Efficient, low CPU usage (keep data streams moving, even on slower systems)
5) Volume control
In order to meet these goals, the KMixer can not guarantee bit perfect playback. Hence it does not support non-PCM streams. The DTS CD (masquerading as a PCM stream) is corrupted in the process. DVD and CD players don't need to meet the above requirements, so they simply pass the stream along. DTS really should have standardized their format. Regardless, the bit manipulation occurs because of volume control.
Since most PCM data is 16 bits, on MMX systems the KMixer uses 16 bit math to take advantage of the SIMD parallelism of MMX. 15 bits are used for multiplication and 1 bit for sign. This means that the KMixer can not represent an amplitude of 1.0. The best it can do is 7FFF/8000. So on MMX systems, when the volume is set to 0dB attenuation, KMixer still attenuates the signal slightly - so the bits are changed.
On non-MMX systems, the KMixer uses floating point math to handle volume. This results in higher CPU usage, but allows the KMixer to reach an amplitude of 1.0. The floating point numbers are then converted back to integers (because that's what the sound card is connected with) and ends up dithering the stream in the process.
When bit perfect playback is necessary, Kernel Streaming is recommended.
Essentially, it comes down to the following:
1) The KMixer does not support non-PCM streams (which the DTS CDs are)
2) A 1/8000 volume attenuation is extremely small. Can anyone hear really hear it? Refer back to KikeG's measured ratings:
http://www.avsforum.com/avs-vb/show...886#post2493886 (http://www.avsforum.com/avs-vb/show...886#post2493886)
I recommend continuing to use Kernel Streaming for your DTS CDs. For PCM data, it is not necessary.
Source : http://archive.avsforum.com/avs-vb/showthr...mp;pagenumber=7 (http://archive.avsforum.com/avs-vb/showthread.php?threadid=247101&perpage=20&pagenumber=7)
Btw, Black Magic, from the above quote, i believe is a Microsoft employe, since although he hasen't said so directly, he gave this quote a little later in that thread :
We've dropped the 'Q' from our article names. Search by the the number and it will come up.
I can't comment too much on the other thing, other than it is incorrect information. I'll just stop there.
Also, if anyone is affected by the issue described in the article below, please contact us for the hotfix. The link is in the article. It is scheduled for SP2 if you can wait:
813347 Audio and Video May No Longer be Synchronized After You Issue a
http://support.microsoft.com/defaul...kb;en-us;813347 (http://support.microsoft.com/defaul...kb;en-us;813347)
Source : http://archive.avsforum.com/avs-vb/showthr...666#post2506666 (http://archive.avsforum.com/avs-vb/showthread.php?postid=2506666#post2506666)
Well, I want to be able to use a plugin that only works with Windows Media Player.
But like I said, it is impossible (or I haven't found a way yet) to forward a regular wave stream bitperfectly to the receiver through DirectSound/WaveOut.
you mean just in Vista, right? Becaues just before that you said that in XP you could get bit perfect through DirectSound/WaveOut
Yes, in Vista. I'll edit my original post to fix this.
The kernel mixer of the 64 bit version of Windows XP doesn't seem to be bitperfect (unlike its 32 bit counterpart).
I can use Kernel Streaming in Vista, using a Soundblaster Live (the very old series, one that supports 5.1) with KXProject drivers, and foobar2000.
I don't have any equipment to test if it is "truly" bit perfect or so, all I know is that Foobar2k plays back fine in KS mode.
Well, sidetracking successful. What the hell does "DRM prone" mean?? The amount of uninformed bitching about DRM is really getting to me. Vista lets you do everything XP did, plus a bunch of things hollywood wants restricted, that XP simply can't do at all. (HD-DVD playback for instance). Microsoft isn't "out to get us" with DRM... they build the infrastructure needed to allow us to watch DRM'd stuff, period.
Show me something that worked under XP but doesn't in Vista due to DRM, and i'll take it back.
XP can play HD-DVDs. In fact, even Linux can play HD-DVDs.
Exactly. Just like they allowed us to use the Internet Explorer or the Media Player - how generous! Except it's all a big load of BS, because putting DRM into the core of the system is a technical absurdity, very much like the implementation of the Internet Explorer is.
Unsigned drivers load in XP x64, but driver signing and therefore a DRM implementation is mandatory in the 64 bit version of Vista.
Actually you are able to disable driver signing by displaying and selecting the appropriate item in the boot menu. In the 64Bit version of Vista.
Actually you are able to disable driver signing by displaying and selecting the appropriate item in the boot menu. In the 64Bit version.
Yeah, but that's not viable because
a) it's too complicated for the regular user,
b) you have to do it every time you boot the system.
I'd be glad to accept a diff for the installer of my driver that automates the process and makes it permanent.
I agree with A) but B) there is a command you can enter in the command prompt to disable it fully.
Should have said this in the previous reply.
Actually I agree with you too an extent I was just bringing it up in the context of the discussion. There is far too much bitching about DRM, but there are some cases where DRM is more restrictive and poses a problem. If you understand where I am coming from. It can be annoying if it's too restrictive or not implemented right (like who would want to use an entire operating system where DRM limits you to what you can do with your multimedia), but there are other cases where it's perfectly fine. . Ok back on the topic of discussion now. I am still a firm believer that Windows is not even the right operating system for developing multimedia related stuff, OS/X clearly has an advantage over it at every end of the curve, but most users still use Windows anyway for convenience. That's getting way off topic and we can save that for another discussion.
Jebus: HD DVD works just fine on XP. So does Blu-Ray, for that matter.
The DRM system in Vista is only active if you playback protected content. And as a rule of thumb, everyone concerned about DRM should stay away from any protected content anyway, so i don't see the problem here.
If you don't like DRM, don't use or buy protected (DRM) content, it's as easy as that!
As for Vista's soundsystem giving worse or better sound than XP's i have no idea. I am however sticking with XP a few months more simply because i use alot of audio programs that rely on stable device drivers and such, which is not available for Vista yet (Cubase SX3, FL Studio, Reason 3, ReCycle, Sonar 6 Producer Edition, ProTools 7.3 M-Powered, Ableton Live and Hypersonic 2).
OK, so you can... with the same restrictions as Vista. I requested that someone show me something you can do in XP that you CAN'T in vista, due to "all the DRM they added".
And no, you can't legally watch HD-DVD (or even DVDs) in Linux.
In Windows, staying away from DRM is as hard as staying away from the Internet Explorer.
Besides, both HD-DVD and Bluray aren't "protected" anymore, and even the DRM stuff that Microsoft's very own Zune player employs has been cracked.
That's pure BS. How can you say that? Where do you encounter so much DRM'ed stuff in Windows compared to other operating systems?
iTunes is probably the biggest reason as to why DRM is so spread around as it is today, and hey, it's not a Microsoft product (but it is available on a Microsoft OS however).
The DRM system in Vista is only active IF YOU CHOOSE TO USE PROTECTED CONTENT. You have the choice. On Linux however, you don't even have that choice!
WMP, drivers, kernel architecture etc.
A lot of resources have been wasted on DRM, and a lot of CPU cycles will be burnt due to DRM, no matter if you use it in the end or not.
Yeah, iTunes is an application, Windows is an operating system - there's a tiny little difference.
The intention to implement DRM deep down into the operating system is clear: it's a more "secure" approach than just relying on the security of an application. By doing that, Microsoft tries to compete with Apple/iTunes in terms of security - they want to run their own infrastructure, just like Jebus noticed.
In the end, the idea of locking out the user from his system is pretty bad, no matter how you twist it.
That's both factually wrong.
I see you are really knowledgeable, sire! May I suggest you just give up posting on this thread and move on to a topic you actually know about?
http://www.intervideo.com/jsp/LinDVD.jsp (http://www.intervideo.com/jsp/LinDVD.jsp)
Umm... maybe you haven't seen this paper on Vista (http://www.cs.auckland.ac.nz/~pgut001/pubs/vista_cost.html) by Peter Gutmann yet?
Here is a very small extract...
"device drivers are required to poll the underlying hardware every 30ms for digital outputs and every 150 ms for analog ones to ensure that everything appears kosher. This means that even with nothing else happening in the system, a mass of assorted drivers has to wake up thirty times a second just to ensure that... nothing continues to happen."
"In addition to this polling, further device-specific polling is also done, for example Vista polls video devices on each video frame displayed in order to check that all of the grenade pins (tilt bits) are still as they should be. We already have multiple reports from Vista reviewers of playback problems with video and audio content, with video frames dropped and audio stuttering even on high-end systems."
Kinda makes you think, doesn't it.
Thats a nice thought but 99% of consumers aren't aware of DRM. So is it fair to sell things to an unaware public? And to those that are aware, how can you be sure if DRM is not part of what you are purchasing? i.e. Sony rootkit scandal. No offense but it almost sounds like you work for MS.
DRM is a major problem across the board for consumers. And I can't imagine how bad it would be if there wasn't people "bitching" about it. Anyone remember when MS announced that they were dropping tons of features for their upcoming OS codenamed "longhorn"? Could it be because of all the DRM that was decided to be programmed in? Therefore limiting the time they had to get it all done.
You have to download the KS plugin from the Optional Components link at Foobar2000.com .
People who are slightly technically minded will understand what the internet store tells them. They will understand when they are told "you have the right to play this ten times" or whatever. Not difficult. If the store doesn't tell them then I would think it is doing something which would be illegal in most countries.
People who can't even understand this will know from their friends or the media if they notice problems arising from DRM. So these people will get some relevant information from some channels... not the best channels but the channels they would use to make any decision about what to buy.
No. Windows has a mixer. The mixer has to take what can potentially be several sources and mix them. So no one can be at full volume, even if it is the only thing playing, because then if the system beeps for example you either have the possibiliy of clipping or you have to reduce the volume of what is playing at the same time. Not unreasonably, windows doesn't do this.
That's right.
Ahh, so either I am lying, or I am in a delusional state of mind . Yeah, that must be it.
Seriously, try it yourself if you don't believe me. A cmedia card with digital outputs costs ~15 USD.
Or not. The Realtek drivers use the WaveRT model afaik, so kernel streaming isn't supported at all.
How about something consumers can actually buy rather than something which is available for OEM licensing only. The only reason Intervideo got a CSS license at all for LinDVD was that they agreed that they would only develop it for the OEM market.
Kinda makes me think I'll be switching to another OS mfg rather than upgrading XP...
JXL
Hi Dogbert
Are you saying that the person who wrote the following quote is delusional ? The info is supposed to come from Microsoft itself and i can't really see the point in making this stuff up, personally. Some manufacturers are making drivers which aren't completely WDM compatible(isn't using MS guideliness 100%) and hence, can archieve bit-perfect output through these interfaces also - Could that be the case also with your driver ?
5) Volume control
So what happens if a second application tries to play sound? Is there clipping, or is volume reduced?
If a second application opens and plays a stream, both streams are mixed together - and if the first application is playing a DTS encoded wave stream, for instance, there's generally white noise mixed with the second stream.
Martin H, all I can say for sure is that DTS encoded FLACs play here just fine through DirectSound/WaveOut, without crackling or other pertubations. Possible explanations are that the kmixer might use SSE in favour of MMX, or that the kernel mixer is just forwarding a stream if it's the only one being played.
Yes and when they are mixed together, is the volume of the first reduced or is there sometimes clipping? One of these would have to hold if you are right.
I don't have a scope here, and my hearing is way too bad to decide whether the mixing lowers the volume of both streams.
Doesn't matter. He claimed DVDs can't be legally played on Linux, I proved they can. End of story.
Wrong. They insist on OEM market because they can't be arsed to guarantee compatibility to every single major distro out there. Think about the dependency hell. In the OEM market, they have much better control of the system that will be running LinDVD.
The DVD Forum would actually love to have someone developing a licensed DVD player for Linux. That would pretty much invalidate Linux users' claims that they are using illegal software (libdvdcss) because they have no access to legal alternatives on their platform.
Is it really illegal to watch DVDs using OSS? I was pretty sure it's only the distribution of compiled software that could be an issue.
