Topic: foo_upnp (Read 1210839 times) previous topic - next topic
Re: foo_upnp
Reply #2125
Sorry to bring bad news but bubbleguuum has said this project is abandoned.
Re: foo_upnp
Reply #2127
Hi everybody, this is my first post.
I don't know if this topic has stil some interest (last post more than a year ago) but I make a try because I can't make the thing working even if normally should work.
My aim is simply to play Foobar2000 from my main Windows XP desktop to a DLNA receiver in the kitchen through the wifi network.
The receiver is a DLink Music Everywhere DCH M225, is in the same wifi network and is perfectly running AirPlay and DLNA from a mobile phone. I configured foo_upnp as described on Bubbleguuum main site and as in other internet pages.
Many thanks for the support if still someone use this software.
Alberto
Re: foo_upnp
Reply #2128
Did you try foo_upnp_out, see here? Works well for me.
Re: foo_upnp
Reply #2129
Hi, I tried it but it is different in design.
It's only an output to another device, not a real server.
Anyway it didn't work too, there was an errore message. Today I'll try again and I let you know.
Maybe there are some ports to open in the router?
Thanks,
Alberto
Re: foo_upnp
Reply #2130
Hi, I'm not sure if this goes here or in tech support (where I've also posted this). Can someone please tell me and I'll delete accordingly.
I am wondering if there is code that can be used in the foo_upnp_ml_tree.xml file that will essentially not display any mp3 files if there is a flac file of the same song with the same tag and/or same file me (obviously except for the extension).
I have two folders for my music. My (mostly portable) mp3/lossy folder that contains all of the music that I own and my archive quality flac folder (mostly from my Audio CD rips). Over the last 15 years however I have accumulated many mp3s that I don't have a flac for through various purchases, etc.
I'd like to be able to add both folders to my music library however in specific cases, like when playing a genre (I have made a custom "Ben's Hits" genre with about 2100 songs) I'd like to be able to weed out the mp3s if there is a high quality version available. In this specific case it'll keep my "Bens Hits" genre at 2100 versus about 3200 if both copies are included.
My current genre .xml code:
</SubTree>
   <SubTree label="Genres ALL TRACKS">
      <spec type="object.container.genre.musicGenre">%&lt;genre&gt;%</spec>
   </SubTree>
<SubTree label="Genres (Artist)">
      <spec type="object.container.person.musicArtist">%artist%</spec>
      <spec type="object.container.album.musicAlbum">%album%</spec>
Re: foo_upnp
Reply #2131
Thanks,
Alberto
Alberto...did you ever get this working? A way to check if it is working is setup the server on one PC and then use foobar on another PC to see if you can find the server and play music on the 2nd PC from the 1st foobar music server. Or use the foobar app on an android phone...that will work too. That way you'll know that the foo_upnp server is working before you try to diagnose the DLink.
I personally use the BubbleuPnp app on my phone to play music (and everything else) on my phone or even stream thru my phone from the server to my phone to another destination like my smart TV, my 7.1 receiver connected to my home theater, other computers, my bluray players, etc.
I think there is a free version of BubbleUpnp that you can test out on at least a few songs.
Re: foo_upnp
Reply #2132
I try to use the component in order to stream onto Libratone Zipp device. It seems to work only for formats directly supported by the devince which unfortunately does not support ogg.
Actually, transcoding to mp3 is enabled in the config and it does work when streaming to other renderers, but for some strange reason, I can't get it to work with my Libratone zip (which does however work with other servers such as bubble UPN, also it plays the transcoded http stream from mpd just fine)
Here is the log file:
0.001: foo_upnp::on_init(199)/13532: INFO: foo_upnp: version 0.99.49
0.004: PLT_UPnP::Start(150)/13532: INFO: Starting UPnP...
0.006: media_tree_root_node_t::load_ml_filters_from_file(189)/13532: INFO: file C:\Users\jr\AppData\Roaming\foobar2000\foo_upnp_ml_tree.xml do not exists
0.006: standard_media_tree_root_node_t::load_ml_filters(595)/13532: INFO: loaded default Media Library filters
0.008: PLT_UPnP::AddDevice(224)/13532: INFO: Starting Device...
0.009: PLT_HttpServer::Start(127)/13532: INFO: HttpServer listening on 0.0.0.0:56923
0.012: PLT_UPnP::AddDevice(224)/13532: INFO: Starting Device...
0.013: PLT_HttpServer::Start(127)/13532: INFO: HttpServer listening on 0.0.0.0:1060
initialized in 0.029s
created 7012 path registry entries in 0.125s
0.336: FbMediaServer::CheckAuthentication(401)/10000: INFO: received LAN request: http://192.168.30.23:56923/DeviceDescription.xml (User-Agent: AVM UPnP/1.0 Client 1.0)
0.347: FbMediaServer::CheckAuthentication(401)/11628: INFO: received LAN request: http://192.168.30.23:56923/ContentDirectory/38fb1eca-b337-6b39-a27f-26ea36254941/scpd.xml (User-Agent: AVM UPnP/1.0 Client 1.0)
0.365: FbMediaServer::CheckAuthentication(401)/10500: INFO: received LAN request: http://192.168.30.23:56923/ConnectionManager/38fb1eca-b337-6b39-a27f-26ea36254941/scpd.xml (User-Agent: AVM UPnP/1.0 Client 1.0)
0.379: FbMediaServer::CheckAuthentication(401)/6080: INFO: received LAN request: http://192.168.30.23:56923/X_MS_MediaReceiverRegistrar/38fb1eca-b337-6b39-a27f-26ea36254941/scpd.xml (User-Agent: AVM UPnP/1.0 Client 1.0)
0.393: FbMediaServer::CheckAuthentication(401)/18824: INFO: received LAN request: http://192.168.30.23:56923/Control/38fb1eca-b337-6b39-a27f-26ea36254941/scpd.xml (User-Agent: AVM UPnP/1.0 Client 1.0)
loaded Media Library tree in 0.703s
27.27800: controller_window::set_track_info_string(1112)/13532: INFO: track info display:
27.27800: PLT_UPnP::AddCtrlPoint(266)/13532: INFO: Starting Ctrlpoint...
27.27801: PLT_HttpServer::Start(127)/13532: INFO: HttpServer listening on 0.0.0.0:1082
27.27806: PLT_CtrlPoint::InspectDevice(1269)/3096: INFO: Inspecting device "4d696e69-444c-164e-9d41-b827ebb0ac65" detected @ http://192.168.30.2:8200/rootDesc.xml
27.27806: PLT_CtrlPoint::InspectDevice(1269)/3096: INFO: Inspecting device "4cfdd855-67fd-480d-9147-632c3a9d7153" detected @ http://10.8.0.1:49153/description.xml
27.27807: PLT_CtrlPoint::InspectDevice(1269)/3096: INFO: Inspecting device "95802409-bccb-40e7-8e6c-C80E144F5BF8" detected @ http://192.168.30.1:49000/l2tpv3.xml
27.27807: PLT_CtrlPoint::InspectDevice(1269)/3096: INFO: Inspecting device "123402409-bccb-40e7-8e6c-C80E144F5BF8" detected @ http://192.168.30.1:49000/fboxdesc.xml
27.27808: PLT_CtrlPoint::InspectDevice(1269)/3096: INFO: Inspecting device "75802409-bccb-40e7-8e6c-C80E144F5BF8" detected @ http://192.168.30.1:49000/igddesc.xml
27.27810: PLT_CtrlPoint::InspectDevice(1269)/3096: INFO: Inspecting device "75802409-bccb-40e7-9f6c-C80E144F5BF8" detected @ http://192.168.30.1:49000/igd2desc.xml
27.27998: PLT_CtrlPoint::InspectDevice(1269)/3096: INFO: Inspecting device "3e5d42cf-9370-4fba-a07e-030a61a85517" detected @ http://192.168.30.98:49152/description.xml
28.28321: PLT_CtrlPoint::ProcessGetDescriptionResponse(1394)/19384: INFO: Device "4cfdd855-67fd-480d-9147-632c3a9d7153" is now known as "Mediatomb"
28.28364: PLT_CtrlPoint::ProcessGetDescriptionResponse(1394)/9988: INFO: Device "95802409-bccb-40e7-8e6c-C80E144F5BF8" is now known as "Digitalsarg"
28.28366: PLT_CtrlPoint::ProcessGetDescriptionResponse(1394)/13320: INFO: Device "4d696e69-444c-164e-9d41-b827ebb0ac65" is now known as "ReadyMedia auf Raspberrypi"
28.28368: PLT_CtrlPoint::ProcessGetDescriptionResponse(1394)/16144: INFO: Device "75802409-bccb-40e7-8e6c-C80E144F5BF8" is now known as "Digitalsarg"
28.28370: PLT_CtrlPoint::ProcessGetDescriptionResponse(1394)/12576: INFO: Device "75802409-bccb-40e7-9f6c-C80E144F5BF8" is now known as "InternetGatewayDeviceV2 - Digitalsarg"
28.28378: PLT_CtrlPoint::ProcessGetDescriptionResponse(1394)/16524: INFO: Device "123402409-bccb-40e7-8e6c-C80E144F5BF8" is now known as "Digitalsarg"
28.28443: LinnDsRendererController::Create(117)/13532: INFO: couldn't find urn:av-openhome-org:service:Product:1 service
28.28513: LinnDsRendererController::Create(117)/13532: INFO: couldn't find urn:av-openhome-org:service:Product:1 service
28.28528: LinnDsRendererController::Create(117)/13532: INFO: couldn't find urn:av-openhome-org:service:Product:1 service
28.28529: PLT_CtrlPoint::ProcessGetDescriptionResponse(1394)/9844: INFO: Device "3e5d42cf-9370-4fba-a07e-030a61a85517" is now known as "Heikes Lauti"
28.28541: LinnDsRendererController::Create(117)/13532: INFO: couldn't find urn:av-openhome-org:service:Product:1 service
28.28704: LinnDsRendererController::Create(117)/13532: INFO: couldn't find urn:av-openhome-org:service:Product:1 service
28.28704: RendererController::Create(25)/13532: INFO: Created UPnPAv Controller for device: Heikes Lauti
31.31163: PLT_CtrlPoint::InspectDevice(1269)/18772: INFO: Inspecting device "bdbb0834-469f-4e64-a8a6-63768bf6653a" detected @ http://127.0.0.1:2869/upnphost/udhisapi.dll?content=uuid:bdbb0834-469f-4e64-a8a6-63768bf6653a
31.31675: PLT_CtrlPoint::ProcessGetDescriptionResponse(1394)/5980: INFO: Device "bdbb0834-469f-4e64-a8a6-63768bf6653a" is now known as "TOMMY"
31.31786: LinnDsRendererController::Create(117)/13532: INFO: couldn't find urn:av-openhome-org:service:Product:1 service
32.32211: controller_window::set_track_info_string(1112)/13532: INFO: track info display: Stopped
32.32211: PLT_CtrlPoint::Subscribe(1562)/13532: INFO: Subscribing to service "urn:upnp-org:serviceId:RenderingControl" of device "Heikes Lauti"
32.32218: PLT_CtrlPoint::ProcessSubscribeResponse(1666)/17148: INFO: Creating new subscriber "uuid:795f126c-1dd2-11b2-8f76-d9f3c7015134" for service "urn:upnp-org:serviceId:RenderingControl" of device "Heikes Lauti" (timeout = 300)
32.32226: UPnPAVRendererController::OnEventNotifyCallback(413)/13532: INFO: <<<< Heikes Lauti: EVENT Volume=40
32.32227: UPnPAVRendererController::OnEventNotifyCallback(413)/13532: INFO: <<<< Heikes Lauti: EVENT Mute=0
32.32227: UPnPAVRendererController::OnEventNotifyCallback(413)/13532: INFO: <<<< Heikes Lauti: EVENT PresetNameList=FactoryDefaults
32.32235: UPnPAVRendererController::set_transport_state(232)/13532: INFO: No local playing item
32.32235: controller_window::set_track_info_string(1112)/13532: INFO: track info display: Stopped
41.41752: RendererController::GetNearestResource(188)/13532: INFO: matching resource url to target ip 192.168.30.98: http://192.168.30.23:56923/content/5dd0e90ac53f19019ca1570895fcdc81.mp3?profile_id=0&convert=mp3
41.41773: FbMediaServer::CheckAuthentication(401)/15732: INFO: received LAN request: http://192.168.30.23:56923/content/5dd0e90ac53f19019ca1570895fcdc81.mp3?profile_id=0&convert=mp3 (User-Agent: Lavf/55.19.104)
41.41773: PLT_HttpHelper::ToLog(432)/15732: INFO: FbMediaServer::ProcessFileRequest
GET /content/5dd0e90ac53f19019ca1570895fcdc81.mp3?profile_id=0&convert=mp3 HTTP/1.1
Accept: */*
Connection: close
Host: 192.168.30.23:56923
transferMode.dlna.org: Streaming
46.46859: upnp_server_conf::get_profile(943)/15732: INFO: using default profile (User-Agent:Lavf/55.19.104)
opened 'file://H:\data\music\Achim Reichel\Regenballade\09 John Maynard.ogg' for streaming, profile: Default, MP3 / VBR -V2, replaygain: off, DSP chain: off
46.46862: PLT_HttpServerSocketTask::Write(465)/15732: WARNING: NPT_CHECK failed, result=-20401 (NPT_ERROR_CONNECTION_ABORTED) [(SendResponseBody(response, *output_stream, abort))]
51.51323: PLT_CtrlPoint::Subscribe(1588)/13532: INFO: Unsubscribing subscriber "uuid:795f126c-1dd2-11b2-8f76-d9f3c7015134" for service "urn:upnp-org:serviceId:RenderingControl" of device "Heikes Lauti"
51.51324: PLT_SsdpSearchTask::DoRun(484)/3096: WARNING: PLT_SsdpSearchTask got an error (-20021) waiting for response
51.51324: PLT_SsdpSearchTask::DoRun(484)/18772: WARNING: PLT_SsdpSearchTask got an error (-20021) waiting for response
52.52279: PLT_HttpListenTask::DoRun(491)/16856: WARNING: PLT_HttpListenTask exiting with -20021 (NPT_ERROR_CANCELLED)
52.52281: PLT_UPnP::Stop(191)/13532: INFO: Stopping UPnP...
52.52332: PLT_HttpListenTask::DoRun(491)/10492: WARNING: PLT_HttpListenTask exiting with -20021 (NPT_ERROR_CANCELLED)
52.52440: PLT_HttpListenTask::DoRun(491)/1276: WARNING: PLT_HttpListenTask exiting with -20021 (NPT_ERROR_CANCELLED)
52.52459: PLT_HttpServerSocketTask::Read(195)/6092: WARNING: NPT_CHECK failed, result=-20021 (NPT_ERROR_CANCELLED) [(res)]
It seems that "NPT_CHECK failed, result=-20401 " is where things start going wrong, but I hav no idea what it means and what I can do about it. Can someone drop me a hint?
Re: foo_upnp
Reply #2133
For comparison, I have inspected the log of a successful streaming to another device, and it still says "NPT_CHECK failed" and "NPT_ERROR_CANCELLED". Here is end of the file. It looks quite similar, only that in this case, playback actually works.
76.76547: upnp_server_conf::get_profile(943)/13044: INFO: using default profile (User-Agent:Kodi/17.3 (X11; Linux armv7l) LibreELEC/8.0 HW_RaspberryPi/1.0 App_Bitness/32 Version/17.3-Git:147cec4)
opened 'file://H:\data\music\Achim Reichel\Regenballade\04 Regenballade.ogg' for streaming, profile: Default, MP3 / VBR -V2, replaygain: off, DSP chain: off
76.76560: controller_window::set_track_info_string(1112)/9108: INFO: track info display: Achim Reichel - John Maynard | MP3 | ? kbps | ? Hz
76.76622: controller_window::set_track_info_string(1112)/9108: INFO: track info display: Achim Reichel - John Maynard | MP3 | ? kbps | ? Hz
77.77681: controller_window::set_track_info_string(1112)/9108: INFO: track info display: Achim Reichel - Regenballade | MP3 | ? kbps | ? Hz
78.78498: FbMediaServer::OnAction(295)/17760: INFO: received action 'Browse', args = { ObjectID=0/1/0, BrowseFlag=BrowseDirectChildren, Filter=res@resolution,res@nrAudioChannels,res@sampleFrequency,res@bitrate,dc:creator,res@dlna:cleartextSize,dc:date,upnp:genre,res,res@duration,res@size,upnp:albumArtURI,upnp:originalTrackNumber,upnp:album,upnp:artist,upnp:author, StartingIndex=570, RequestedCount=30, SortCriteria= }
78.78498: upnp_server_conf::get_profile(943)/17760: INFO: using default profile (User-Agent:Linux/3.16.0-61.beehive4tv.3 UPnP/1.0 LGE WebOS TV LGE_DLNA_SDK/1.6.0/04.05.56 DLNADOC/1.50)
78.78500: FbMediaServer::OnAction(323)/17760: INFO: action 'Browse' response: args = { ObjectID=0/1/0, BrowseFlag=BrowseDirectChildren, Filter=res@resolution,res@nrAudioChannels,res@sampleFrequency,res@bitrate,dc:creator,res@dlna:cleartextSize,dc:date,upnp:genre,res,res@duration,res@size,upnp:albumArtURI,upnp:originalTrackNumber,upnp:album,upnp:artist,upnp:author, StartingIndex=570, RequestedCount=30, SortCriteria=, NumberReturned=30, TotalMatches=862, UpdateID=0 }
78.78738: controller_window::set_track_info_string(1112)/9108: INFO: track info display: Achim Reichel - Regenballade | MP3 | ? kbps | ? Hz
79.79794: controller_window::set_track_info_string(1112)/9108: INFO: track info display: Achim Reichel - Regenballade | MP3 | ? kbps | ? Hz
80.80851: controller_window::set_track_info_string(1112)/9108: INFO: track info display: Achim Reichel - Regenballade | MP3 | ? kbps | ? Hz
81.81544: FbMediaServer::OnAction(295)/6724: INFO: received action 'Browse', args = { ObjectID=0/1/0, BrowseFlag=BrowseDirectChildren, Filter=res@resolution,res@nrAudioChannels,res@sampleFrequency,res@bitrate,dc:creator,res@dlna:cleartextSize,dc:date,upnp:genre,res,res@duration,res@size,upnp:albumArtURI,upnp:originalTrackNumber,upnp:album,upnp:artist,upnp:author, StartingIndex=600, RequestedCount=30, SortCriteria= }
81.81545: upnp_server_conf::get_profile(943)/6724: INFO: using default profile (User-Agent:Linux/3.16.0-61.beehive4tv.3 UPnP/1.0 LGE WebOS TV LGE_DLNA_SDK/1.6.0/04.05.56 DLNADOC/1.50)
81.81547: FbMediaServer::OnAction(323)/6724: INFO: action 'Browse' response: args = { ObjectID=0/1/0, BrowseFlag=BrowseDirectChildren, Filter=res@resolution,res@nrAudioChannels,res@sampleFrequency,res@bitrate,dc:creator,res@dlna:cleartextSize,dc:date,upnp:genre,res,res@duration,res@size,upnp:albumArtURI,upnp:originalTrackNumber,upnp:album,upnp:artist,upnp:author, StartingIndex=600, RequestedCount=30, SortCriteria=, NumberReturned=30, TotalMatches=862, UpdateID=0 }
81.81905: controller_window::set_track_info_string(1112)/9108: INFO: track info display: Achim Reichel - Regenballade | MP3 | ? kbps | ? Hz
82.82963: controller_window::set_track_info_string(1112)/9108: INFO: track info display: Achim Reichel - Regenballade | MP3 | ? kbps | ? Hz
84.84021: controller_window::set_track_info_string(1112)/9108: INFO: track info display: Achim Reichel - Regenballade | MP3 | ? kbps | ? Hz
84.84610: FbMediaServer::OnAction(295)/17760: INFO: received action 'Browse', args = { ObjectID=0/1/0, BrowseFlag=BrowseDirectChildren, Filter=res@resolution,res@nrAudioChannels,res@sampleFrequency,res@bitrate,dc:creator,res@dlna:cleartextSize,dc:date,upnp:genre,res,res@duration,res@size,upnp:albumArtURI,upnp:originalTrackNumber,upnp:album,upnp:artist,upnp:author, StartingIndex=630, RequestedCount=30, SortCriteria= }
84.84611: upnp_server_conf::get_profile(943)/17760: INFO: using default profile (User-Agent:Linux/3.16.0-61.beehive4tv.3 UPnP/1.0 LGE WebOS TV LGE_DLNA_SDK/1.6.0/04.05.56 DLNADOC/1.50)
84.84613: FbMediaServer::OnAction(323)/17760: INFO: action 'Browse' response: args = { ObjectID=0/1/0, BrowseFlag=BrowseDirectChildren, Filter=res@resolution,res@nrAudioChannels,res@sampleFrequency,res@bitrate,dc:creator,res@dlna:cleartextSize,dc:date,upnp:genre,res,res@duration,res@size,upnp:albumArtURI,upnp:originalTrackNumber,upnp:album,upnp:artist,upnp:author, StartingIndex=630, RequestedCount=30, SortCriteria=, NumberReturned=30, TotalMatches=862, UpdateID=0 }
85.85076: controller_window::set_track_info_string(1112)/9108: INFO: track info display: Achim Reichel - Regenballade | MP3 | ? kbps | ? Hz
86.86134: controller_window::set_track_info_string(1112)/9108: INFO: track info display: Achim Reichel - Regenballade | MP3 | ? kbps | ? Hz
86.86650: FbMediaServer::OnAction(295)/6724: INFO: received action 'Browse', args = { ObjectID=0/1/0, BrowseFlag=BrowseDirectChildren, Filter=res@resolution,res@nrAudioChannels,res@sampleFrequency,res@bitrate,dc:creator,res@dlna:cleartextSize,dc:date,upnp:genre,res,res@duration,res@size,upnp:albumArtURI,upnp:originalTrackNumber,upnp:album,upnp:artist,upnp:author, StartingIndex=660, RequestedCount=30, SortCriteria= }
86.86650: upnp_server_conf::get_profile(943)/6724: INFO: using default profile (User-Agent:Linux/3.16.0-61.beehive4tv.3 UPnP/1.0 LGE WebOS TV LGE_DLNA_SDK/1.6.0/04.05.56 DLNADOC/1.50)
86.86653: FbMediaServer::OnAction(323)/6724: INFO: action 'Browse' response: args = { ObjectID=0/1/0, BrowseFlag=BrowseDirectChildren, Filter=res@resolution,res@nrAudioChannels,res@sampleFrequency,res@bitrate,dc:creator,res@dlna:cleartextSize,dc:date,upnp:genre,res,res@duration,res@size,upnp:albumArtURI,upnp:originalTrackNumber,upnp:album,upnp:artist,upnp:author, StartingIndex=660, RequestedCount=30, SortCriteria=, NumberReturned=30, TotalMatches=862, UpdateID=0 }
87.87194: controller_window::set_track_info_string(1112)/9108: INFO: track info display: Achim Reichel - Regenballade | MP3 | ? kbps | ? Hz
88.88249: controller_window::set_track_info_string(1112)/9108: INFO: track info display: Achim Reichel - Regenballade | MP3 | ? kbps | ? Hz
89.89305: controller_window::set_track_info_string(1112)/9108: INFO: track info display: Achim Reichel - Regenballade | MP3 | ? kbps | ? Hz
89.89706: FbMediaServer::OnAction(295)/17760: INFO: received action 'Browse', args = { ObjectID=0/1/0, BrowseFlag=BrowseDirectChildren, Filter=res@resolution,res@nrAudioChannels,res@sampleFrequency,res@bitrate,dc:creator,res@dlna:cleartextSize,dc:date,upnp:genre,res,res@duration,res@size,upnp:albumArtURI,upnp:originalTrackNumber,upnp:album,upnp:artist,upnp:author, StartingIndex=690, RequestedCount=30, SortCriteria= }
89.89706: upnp_server_conf::get_profile(943)/17760: INFO: using default profile (User-Agent:Linux/3.16.0-61.beehive4tv.3 UPnP/1.0 LGE WebOS TV LGE_DLNA_SDK/1.6.0/04.05.56 DLNADOC/1.50)
89.89709: FbMediaServer::OnAction(323)/17760: INFO: action 'Browse' response: args = { ObjectID=0/1/0, BrowseFlag=BrowseDirectChildren, Filter=res@resolution,res@nrAudioChannels,res@sampleFrequency,res@bitrate,dc:creator,res@dlna:cleartextSize,dc:date,upnp:genre,res,res@duration,res@size,upnp:albumArtURI,upnp:originalTrackNumber,upnp:album,upnp:artist,upnp:author, StartingIndex=690, RequestedCount=30, SortCriteria=, NumberReturned=30, TotalMatches=862, UpdateID=0 }
90.90359: controller_window::set_track_info_string(1112)/9108: INFO: track info display: Achim Reichel - Regenballade | MP3 | ? kbps | ? Hz
submitted statistics for 'file://H:\data\music\Achim Reichel\Regenballade\04 Regenballade.ogg'
91.91451: controller_window::set_track_info_string(1112)/9108: INFO: track info display: Achim Reichel - Regenballade | MP3 | ? kbps | ? Hz
92.92506: controller_window::set_track_info_string(1112)/9108: INFO: track info display: Achim Reichel - Regenballade | MP3 | ? kbps | ? Hz
92.92754: FbMediaServer::OnAction(295)/6724: INFO: received action 'Browse', args = { ObjectID=0/1/0, BrowseFlag=BrowseDirectChildren, Filter=res@resolution,res@nrAudioChannels,res@sampleFrequency,res@bitrate,dc:creator,res@dlna:cleartextSize,dc:date,upnp:genre,res,res@duration,res@size,upnp:albumArtURI,upnp:originalTrackNumber,upnp:album,upnp:artist,upnp:author, StartingIndex=720, RequestedCount=30, SortCriteria= }
92.92755: upnp_server_conf::get_profile(943)/6724: INFO: using default profile (User-Agent:Linux/3.16.0-61.beehive4tv.3 UPnP/1.0 LGE WebOS TV LGE_DLNA_SDK/1.6.0/04.05.56 DLNADOC/1.50)
92.92763: FbMediaServer::OnAction(323)/6724: INFO: action 'Browse' response: args = { ObjectID=0/1/0, BrowseFlag=BrowseDirectChildren, Filter=res@resolution,res@nrAudioChannels,res@sampleFrequency,res@bitrate,dc:creator,res@dlna:cleartextSize,dc:date,upnp:genre,res,res@duration,res@size,upnp:albumArtURI,upnp:originalTrackNumber,upnp:album,upnp:artist,upnp:author, StartingIndex=720, RequestedCount=30, SortCriteria=, NumberReturned=30, TotalMatches=862, UpdateID=0 }
93.93563: controller_window::set_track_info_string(1112)/9108: INFO: track info display: Achim Reichel - Regenballade | MP3 | ? kbps | ? Hz
94.94457: UPnPAVRendererController::set_transport_state(232)/9108: INFO: No local playing item
94.94458: controller_window::set_track_info_string(1112)/9108: INFO: track info display: Stopped
95.95982: FbMediaServer::OnAction(295)/17760: INFO: received action 'Browse', args = { ObjectID=0/1/0, BrowseFlag=BrowseDirectChildren, Filter=res@resolution,res@nrAudioChannels,res@sampleFrequency,res@bitrate,dc:creator,res@dlna:cleartextSize,dc:date,upnp:genre,res,res@duration,res@size,upnp:albumArtURI,upnp:originalTrackNumber,upnp:album,upnp:artist,upnp:author, StartingIndex=750, RequestedCount=30, SortCriteria= }
95.95983: upnp_server_conf::get_profile(943)/17760: INFO: using default profile (User-Agent:Linux/3.16.0-61.beehive4tv.3 UPnP/1.0 LGE WebOS TV LGE_DLNA_SDK/1.6.0/04.05.56 DLNADOC/1.50)
95.95991: FbMediaServer::OnAction(323)/17760: INFO: action 'Browse' response: args = { ObjectID=0/1/0, BrowseFlag=BrowseDirectChildren, Filter=res@resolution,res@nrAudioChannels,res@sampleFrequency,res@bitrate,dc:creator,res@dlna:cleartextSize,dc:date,upnp:genre,res,res@duration,res@size,upnp:albumArtURI,upnp:originalTrackNumber,upnp:album,upnp:artist,upnp:author, StartingIndex=750, RequestedCount=30, SortCriteria=, NumberReturned=30, TotalMatches=862, UpdateID=0 }
97.97481: PLT_CtrlPoint::Subscribe(1588)/9108: INFO: Unsubscribing subscriber "uuid:a68f68c6-c73c-852e-b68c-f443a13d0f6a" for service "urn:upnp-org:serviceId:RenderingControl" of device "Kodi (LibreELEC)"
97.97682: PLT_HttpListenTask::DoRun(491)/19068: WARNING: PLT_HttpListenTask exiting with -20021 (NPT_ERROR_CANCELLED)
97.97684: PLT_UPnP::Stop(191)/9108: INFO: Stopping UPnP...
97.97785: PLT_HttpListenTask::DoRun(491)/17624: WARNING: PLT_HttpListenTask exiting with -20021 (NPT_ERROR_CANCELLED)
97.97787: PLT_HttpServerSocketTask::Read(195)/6724: WARNING: NPT_CHECK failed, result=-20021 (NPT_ERROR_CANCELLED) [(res)]
97.97787: PLT_HttpServerSocketTask::Read(195)/17760: WARNING: NPT_CHECK failed, result=-20021 (NPT_ERROR_CANCELLED) [(res)]
97.97950: PLT_HttpListenTask::DoRun(491)/1296: WARNING: PLT_HttpListenTask exiting with -20021 (NPT_ERROR_CANCELLED)
97.97972: PLT_HttpServerSocketTask::Read(195)/17996: WARNING: NPT_CHECK failed, result=-20021 (NPT_ERROR_CANCELLED) [(res)]
Re: foo_upnp
Reply #2134
Does anybody have an old version of this plugin? I stream to a Sony device that supports most of the playback formats, but even if configured to not convert or transcode, it still convert ape or dsd files to lpcm. I remember streaming native dsd iso with the old version of the plugin..
Re: foo_upnp
Reply #2135
Does anyone know why my UPNP server is not seen from other foobar2000 installations on my local network computers? Computer discovering is enabled, UPNP service is enabled. What could be the problem?
Re: foo_upnp
Reply #2136
Hello everybody
I set up my foobar2000 with foo_upnp for streaming and downloading over the internet to foobar2000 mobile on my phone. The connection and navigation works fine but there are a few problems I couldn't fix:
The streaming profile is set to: transcode 'never' only if lossless. So if I'm on my phone and want to download a M4A track foobar2000 on my PC would convert the track to WAV.
If it is lossless, the track would be converted to MP3. Just like it set it up. But why is the M4A track converted to WAV at all?
So I set it to: transcode 'always'. This means that FLAC or ALAC and also M4A tracks are getting converted. Okay. But I think M4A doesn't need to be transcoded, a transcode of lossless files would be enough.
Next and bigger problem: if I download some transcoded MP3 files, all the metadata is missing. The metadata is all there in playback, but after downloading it all is gone. Does anyone know how to solve this problems?
Best regards
Re: foo_upnp
Reply #2137
Add Support for:
DSD128, DSD512 (DSF)
The Files are not detect correct.
The UPNP System Play 284400 bit 24bit ????
 :o  :o  :o  :o  :o  :o
Re: foo_upnp
Reply #2138
I have BubbleUNPN setup on my phone and I'm able to stream over the internet to my phone without issue.
Is there a way I can install Foobar on my work laptop and stream that way as well? I've never used F2K as a client for streaming so I don't know how this works at all.
SimplePortal 1.0.0 RC1 © 2008-2018
