Topic: dsp_config_manager : enable DSP fix. (Read 1254 times) previous topic - next topic
Got some updated code for dsp_config_manager::core_enable_dsp. Should append DSPs to the end of the current list instead of overwriting the first element as it does currently in the current SDK if a DSP already exists. This was also needed on my end because of latency from other 3rd party components interfering with mine (pitch ones work best at end of chain)
void DSPEnable(const dsp_preset & data) {
//altered from enable_dsp to append to DSP array
dsp_chain_config_impl cfg;
static_api_ptr_t<dsp_config_manager>()->get_core_settings(cfg);
bool found = false;
bool changed = false;
t_size n, m = cfg.get_count();
for (n = 0; n < m; n++) {
if (cfg.get_item(n).get_owner() == data.get_owner()) {
found = true;
if (cfg.get_item(n) != data) {
cfg.replace_item(data, n);
changed = true;
break;
//append to DSP queue if not present
]if (!found) { if (n>0)n++; cfg.insert_item(data, n); changed = true; }
if (changed) static_api_ptr_t<dsp_config_manager>()->set_core_settings(cfg);
The line in question is:
