Topic: Replaygain target volume (Read 1343 times) previous topic - next topic
  • Ryrynz
The replaygain target volume level setting doesn't take effect until after the player has restarted.
Also 'only increase volume' doesn't work? It's still scanning in negative values and applying them. Am I understanding this setting correctly?
  • Case
  • Developer (Donating)
The setting in advanced preferences only affects file modification functions 'Apply track ReplayGain to file content' and 'Apply album ReplayGain to file content'. Regular ReplayGain target level is 89 dB SPL as the specification states and it can not be altered. If you wish to use a different playback level you adjust the preamp setting accordingly, for example preamp of -6.0 dB gives you the original draft 83.0 dB SPL level.
File modification feature lets you adjust the level differently because it's meant for legacy players/hardware where ReplayGain and preamps are not available.
  • Xerus
Re: Replaygain target volume
Big thanks! I've wondered about that too
Why is this not mentioned in foobar? That would have saved me some hours of wondering and testing...
  • GeSomeone
You seem to have missed that it's under "File content alteration"  :-\
  • kode54
  • Administrator
And just in case anyone else missed it, @Xerus bumped a topic from 2014.
