Topic: MP3 at 128kbps public listening test (Read 53682 times) previous topic - next topic
Reply #125
Hello.
Some last points before I go on a trip (I'll only visit the boards seldomly until Jan 10th).
About VBR vs. CBR:
There are good reasons for either method. They are:
CBR is what newbies use once they start playing with MP3. Only later some of them come to know about VBR and ABR. Also, it's the default mode in most MP3 encoders: Lame, FhG, Xing... (or the only mode in some cases: Radium, Audioactive, iTunes)
Also, CBR is best to avoid criticism on test fairness, since there is no bitrate deviation.
VBR/ABR is what should be used to take the most out of each codec at the chosen bitrate. Lame is known for performing quite better at ABR than CBR, and I believe the same applies to FhG. In this case, Lame, FhG and Xing would use VBR encoding, and Audioactive/Radium and iTunes would use CBR.
No-CBR for Lame only is definitely out of the question. The test would look scandalously biased if Lame was tested at ABR and everything else at CBR.
IMO, the bottom point is if we want the test results to appeal to newbies or enlightened HA users. If we go for newbies, the test should be CBR. If we go for veterans, the test should be ABR.
Any thoughts?
About Lame version:
I think it's closely related to the newbies vs. veterans issue. If the test is done for veterans, Lame 3.90.3 should be featured. If it is for newbies, Lame 3.93.1, since this is the version you'll find in CDex, Winamp, and at Mitiok's site. I think that actually the only popular Lame binary distribution point featuring 3.90.3 is RareWares.
About Audioactive vs. Radium
It is said that both use similar encoding routines, so I would definitely test only one of them. The appeal of Radium is that it is very widely used in DivX rips. The appeal of Audioactive is that it seems to be based on more recent  - and therefore more tweaked - libraries, so quality is probably better.
About FhG version:
I'm inclined to test FhG Current and Legacy Fast from Adobe Audition, both at some VBR mode that comes close to 128kbps (in case we decide to go for VBR). Legacy Slow is - as the name implies - too slow and, from what it is said, fast is actually better (!).
If only one FhG codec is featured (that would be Audition Current), I might as well replace the other with Gogo 3.x
So, the codec list would be as follows:
Lame 3.90.3 or 3.93.1
FhG Current in Audition
FhG Legacy Fast or Gogo 3.x
iTunes 4.2
Audioactive 2.04j or Radium
RealOne MP3 encoder (Xing)
And the settings would depend on the choice for VBR or CBR.
Please post your comments and suggestions.
Best regards;
Roberto.
Reply #126
I'd like to see lame -br 128 as an anchor because all lamers just set their cdex to rip at that bitrate without touching the other setteings. The quality difference (???) between the br-switch and preset might even force some of those nasty pirate gruops to switch to presets. (But on the other hand lame 3.94 will force them to switch to presets but they'll still use stereo instead of joint stereo because they are stupid  )
Reply #127
Good point. But the low anchor is meant to sound bad, and I'm afraid Lame CBR could sound better than iTunes and Radium/Audioactive...
That's why I plan to use Xing as anchor.
Reply #128
Please, leave Xing as anchor.
Regarding Lame, it seems to me that your choice is between 3 versions: 3.90.3, 3.93.1, 3.94
Reply #129
I will, most probably.
But 3.94 is still beta. It's not a good idea to use beta stuff in listening tests, IMO, because people can easily claim the codec performed badly (if that's the case) because if some beta flaw. I personally would prefer to use a release version, either 3.90.3 or 3.93.1
Unless you plan to make Lame 3.94 stable until ~Jan 11th
Reply #130
I'm still in favor of an ABR/VBR test.
I don't agree with you on this point. I think if you're a newbie and you're reading listening test results, that's probably because you want to find out what to use to make your encodings sound as good as possible (with MP3 at that specific bitrate). And if you want your encodings to sound good, you should use ABR/VBR. So I don't think CBR would be interesting for newbies. There is one reason I can think of for using CBR, though. The results of such a test might be useful for people who want to find out the quality of MP3s they didn't encode themselves (I probably don't have to mention where those MP3s come from, usually).
As for the question what Lame version to use, I'd go with 3.90.3, although I don't think it makes much of a difference, because both versions will likely be superceded by 3.94 in the near future.
Reply #131
About FhG version:
If both Legacy Fast and Legacy Slow actually encode with VBR, then they are probably the same codec -- the FhG fast codec, because that's the only one which does VBR.
In Cool Edit Pro 2.1, they had actually removed the FhG slow codec from the library, and made quality settings based on only the fast codec.
If that is really the case, then I would choose legacy slow for the FhG codec.  Remember that you can try blackbird.wav to find out if it has glitches in it or not.  That would indicate whether Legacy Slow really is the FhG slow codec or not.
ff123
Reply #132
hmm, what about LAME 3.92 :confused:
Reply #133
FYI, iTunes supports MP3 VBR encoding. Press "Custom" and it'll pop-up a configuration dialog, and you can check "Use Variable Bitrate Encoding (VBR)"
When in VBR mode, the bitrate you choose is the lowest bitrate the encoder will use. And you can select between these presets:
Lowest
Low
Medium Low
Medium
Medium High
High
Highest
and also select stereo/joint stereo, sample rate and lowpass filter.
Also EncSpot detects the iTunes files as: FhG (fastenc or mp3enc)
myspace.com/borgei - last.fm/user/borgei
Reply #134
As an actual real-life newbie, I'd most want to see comparisons of VBR recordings that average or approximate 128 kbps.  That's what I could best use to make practical decisions.
Reply #135
Very good point. Maybe I'll go with ABR/VBR after all.
oh, I see. I thought Legacy Slow was mp3enc. Thanks for this information. I'll test blackbird.wav when I return home, and if it isn't the FhG Slow codec, I'll replace Legacy Fast with it.
I chose Lame 3.90.3 because it's the HA branch, and 3.93.1 because it's the latest stable release. Since 3.93.1 came after 3.92, I see no point in using a deprecated version.
Ah, that's useful information. Thank-you for mentioning it.
EncSpot is wrong. It has already been proven earlier in this thread (look for a link to the lame mailing list) that iTunes is based on SoundJam, that on it's turn is an independent tweak line from dist10.
Thank-you for your replies so far.
Regards;
Roberto.
Reply #136
OK, I'm getting close to freezing the encoders and settings.
My ideas:
-FhG Audition Current VBR
-FhG Audition Legacy Fast or Slow VBR (more on that later)
-Lame 3.90.3 --alt-preset 128
-iTunes VBR
-Audioactive 2.04 high quality 128kbps CBR
-RealOne (Xing) VBR
I'll test the VBR settings of Audition, Xing and iTunes to find out what comes closer to 128kbps overall.
About FhG Legacy Fast vs. Legacy Slow: I'll use slow if it's not the MP3enc branch. But I need someone to test it using Blackbird.wav (like ff123 suggested). I can't test now because I'm on a trip.
More info on identifying MP3enc: http://ff123.net/identify.html
About Lame version: I plan to test Lame 3.90.3, unless 3.94 is released until the test date (since 3.94 seems to feature major improvements compared to 3.90.X)
If everything goes as planned, the test will start on January 14th.
Please comment.
Best regards;
Roberto.
Reply #137
Ok,
I acquired Adobe Audition 1.0 so I could take a look at the various mp3 codecs in it.
1.
Preset:  VBR - Good Quality Stereo
VBR, MP3
70 - (125-175 Kbps), High Quality
Max Bandwidth 14112 Hz
VBR Quality 70
Changed Codec to Legacy - High Quality (Slow)
Allow Mid-Side Joint Stereo is unchecked
Allow Intensity Joint Stereo is unchecked
Allow Narrowing of Stereo Image is unchecked
Result:  not the super slow codec, as found within fastencc.exe 1.02 using the -hq switch.
2.
Preset:  128 Kbps Stereo (Internet)
CBR, MP3
128 Kbps, 44100 Hz, Stereo (11.0:1)
Max Bandwidth 22050
CBR Bitrate 128 Kbps
Sample Rate 44100 Hz
Allow Mid-Side Joint Stereo is checked
Allow Intensity Joint Stereo is checked
3.
CBR, MP3
Max Bandwidth 22050
Codec:  Current - Best Quality
4.
Preset:  VBR - High Quality Stereo
VBR, MP3
Changed setting to 70 - (125-175 Kbps), High Quality
Max Bandwidth 17660 Hz
VBR Quality 70
So, as I suspected, the super slow code no longer exists in the FhG library.  I would choose either "128 Kpbs Stereo (Internet)" or "VBR - High Quality Stereo" as the base presets.
Using "VBR - Good Quality Stereo" will set the Max Bandwidth too low, in my opinion.  If using High Quality VBR, the default VBR setting is 100 and the default codec is Legacy - Medium Quality (Fast).  You'll probably have to at least change the VBR setting.  Probably either vbr 50 or 60 is closest to 128 kbps.
On main_theme.wav, at least, vbr 50 is an improvement over cbr 128.  It didn't matter whether I used legacy fast or current for the vbr encode.  Either one sounded better than cbr 128 (current).
So my suggestion would be to use the "VBR - High Quality Stereo" preset, and change the VBR setting to either 50 or 60, and change the codec to "Current - Best Quality."  I think that all the codecs within Audition are variations on the Basic FastEnc, so you should just choose one.
ff123
Edit:  Possibly the reason why VBR sounds better on main_theme.wav is because joint-stereo is disallowed (although I didn't verify with EncSpot that this is true for VBR 50).
Reply #138
Thanks for the help, ff123. As usual, I owe a lot to you
So, the updated codec list:
-FhG Audition Current VBR 50-60
-iTunes VBR
-RealOne (Xing) VBR - anchor
Now, the usual request for opinions:
Do you guys prefer that I leave the codec list at that (only 5 encoders featured) or that I replace Audition Legacy with Gogo, or some other encoder?
Also, since this is a mid-bitrate test, it might be a good idea to replace one or two of the samples with problem cases. Do you agree?
Thanks a lot.
Best regards;
Roberto.
Reply #139
I like the idea of a killer-sample. This will show to everybody a good exemple of failure of mp3 at this bitrate. Why not the good old friend of mp3: fatboy?
Reply #140
I'd like to see how much quality was sacrificed for speed with GOGO. IMO it's always been left out in tests, not among the best encoders but not really bad either. Kind of in the middle, almost boring:) The quality is basically (again IMO) estimated (i.e. it SHOULD perform this... and IS LIKELY to sound like that...)
//From the barren lands of the Northsmen
Reply #141
-iTunes VBR
I'd love to have a Lame ABR-CBR comparison, this way we would know, how large the difference (which I think is undisputed) is compared to codec differences. And there are still scenarios where the CBR compatibility is needed.
I'm not sure. Could a few problem cases skew the total ratings? Problem sample rating differences will probably be larger (as more of the scale is used), and hence have more influence on the overall scores. I am not sure if this is a desired effect.
Reply #142
As long as the test is comparing various encoders of one single format, I think that there are no problems to incude a killer-sample. Fatboy for exemple is destroyed by each encoders at this bitrate. It's not a lame-killer only, or a typical fhg-problem sample.
Of course, bad notations will affect the overall scores at the end of the test. On the other side, bad surprises may happen in real life with mp3 at this bitrate; so, I think that introducing a killer in the arena isn't a bad thing.
Reply #143
Why don't we test GOGO 3.12 once and for all, and see if it's really not that good in quality? If it's no good, then we can stop talking about it (until an improved version is released).
Reply #144
It's not a bad idea, but if we include gogo, there will be 6 encoders to rate. Five encoders are enough for a lot of people, maybe too much!
Nevertheless, if Roberto launch a mp3 general test, why not imagine a complete one. After all, will there be enough progress with MP3 to expect any similar test in the next years? I'm not sure.
With 6 challengers, we'll have :
- the good : lame
- the bad : Audioactive Pro
- the ugly : Xing
- the fast : gogo
- the alternative : iTunes (MAC users)
- the expensive : Audition
Good script, no? As sample, why not Morricone?
Reply #145
and mp4pro at 64kbps
I know, that I know nothing (Socrates)
Reply #146
Hmm. Doesn't the 64kbit Test tell you everything you want to know about it? (HE-AAC 64 against Lame 128)
Reply #147
Just wondering what settings you planned for iTunes VBR.  Obviously you should set Quality to "Highest" and leave "Joint Stereo". But the bitrate settings is for the lower bound. I.e. 128 will give an avg. about 140 or so. and 112, produces an avg. around 120 (strangely this is independent of Quality settings). So which one to choose?
guruboolez: iTunes is not for MAC users only - its for PCs, too.
Reply #148
It'd be fun to test Lame 3.90.3/3.93.1 vs 3.94b, but I think this isn't the scope of this test...
(mabe with just plain -b 128 to test the effectiveness of automatic presets)
ruxvilti'a
Reply #149
<nitpick mode>
It's Mac, not MAC. MAC is something your ethernet card has, while Mac is short for Macintosh.
</nitpick mode>
