Topic: [Not My Release] EsPlaylist (Read 338914 times) previous topic - next topic
Reply #175
Hi ssenna,
just two cosmetic questions:
1. Would it be possible to make the edge-style "sunken"? Or to implement an option to choose the style? It seems that it now set to "none" ("1" on the pic).
2. Any chance to disable the rounded frames in the future ("2" on the pic)?
[a href="http://250kb.de/2SCSuqV" target="_blank"]
Reply #176
Hi
this component is really great. One thing I am missing is a new browse library action "Open/Close Group with Double click". What do you think? Could you add this please?
Reply #177
Drag & drop does not work consistently for me. It happens when you click on a track in Esplaylist (marking it) and immediately drag it somewhere. If you time it right (as quickly as possible but slower than a double-click), drag & drop won't work.
Has anyone else experienced this behaviour? Unintentionally it has happened quite a few times to me.
Vista64, Foobar 1.03 here.
Reply #178
Yes I having the same problem, it seems to require you to hold the mouse for a bit before dragging. I also can't seem to drag items from one EsPlaylist to another, but going from anything else to or from EsPlaylist works.
Reply #179
I want to use EsPlaylist solely as album browser. So I set Browse Mode to "Browse Library". But is it possible to just display full music albums but not audiobooks (files with %genre% "Audiobook") and not single tracks that don't have %album%?
For Facets I use this string:
$if($strcmp(%genre%,Audiobook),,[%album%])
But that won't exclude audiobooks in EsPlaylist.
Reply #180
Is it possible to column the date? I mean the Year which is saved in the tag. Or sort by year?
Reply #181
just insert one of the preset columns and right click>edit column. now you can rename it and enter %date% in the format box.
Reply #182
Lol tried it before but didnt work ^^ Now it works ^^ thx
Reply #183
Hello ssenna,
Have you done anything about multifield tag support? The reason I ask is because EsPlaylist parses the tag and transforms the semicolon separator into a coma followed by a space.
Let's say I fill the genre tag of a track with "foo;bar". Album list browser shows this track under these two genres. EsPlaylist shows a "foo, bar" genre, and doesn't list this track neither under "foo" nor under "bar" (these genre groups are not created then).
I know that multifield tag support has already been asked for, but since earlier reports stated that the semicolon separator was completely ignored (rather than parsed into ", "), I was wondering if you have done any modification to that. And since there is no complete changelog for me to view, I have to ask you that.
Regards,
FaintingGoat
Reply #184
I just tried your example and all was shown correct!
In Album List/Genre there where these two genres! Your problem seems to be located anywhere else, but not in esplaylist.
Reply #186
Just to be clear, where are you verifying this? Yes, in the Album List browser things are displayed correctly. It's the (ES)playlist view that behaves the way I described. I just tried this again.
FaintingGoat
Reply #187
... the semicolon separator was completely ignored (rather than parsed into ", ") ...
Hmm.. Here the separator is right... In playlists you can see allways only a ", " as separator.
Reply #188
Sorry, I forgot to clarify that I was talking about EsPlaylist in Browse Library Mode. I figured it wouldn't be necessary since I was making a direct comparison to the default Album List Browser.
Here's the behavior I've been trying to explain:
Notice that I tagged some albums as "Electronic;World/Ethnic", and they are creating a group of their own instead of appearing under both "Electronic" and "World/Ethnic".
But that doesn't matter anymore. By doing some further experimentation, I came to realize that the problem is actually a different one.
It seems that it's necessary to use "%<genre>%" instead of "%genre%" to make a track tagged with "foo;bar" to appear under "foo" and "bar" and to avoid a third "foo;bar" genre entry to appear, this also in the default Album List browser. So, with that in mind, I modified my grouping string to "%<genre>%. Here's what happenened:
When the title field is also modified to %<genre>%, "?" is displayed as the group title.
FaintingGoat
Reply #189
Hi, I'm using this as library viewer (as I have nice playlist view already) and was wondering if it would be possible to automatically activate (but not play) specified playlist after adding some music on it?
Reply #190
Quick question - how can I get the text below the album art as displayed above? Mine always appears to the right side of the art. I'm only using DUI, so I don't know if that's part of my problem?
thanks,
.Mike
Reply #191
I'm also only using DUI.
It's very simple, just uncheck the "Side Info" box on the grouping settings of your view.
Reply #192
ah... yep, overlooked that - thanks much. Big improvement!
Reply #193
EsPlaylist v0.1.1.0 beta 2 (2010/05/29) released.
Changelog:
  • added support for $rgb.
  • removed dynamic format box in column setting.(please use %isplaying% instead)
  • compiled with the latest SDK.
  • fixed some bugs.
Download EsPlaylist v0.1.1.0 beta 2
Reply #194
Thanks for implementing colors!
Reply #195
Would be nice to change the font color to white when the selection is active (highlight) in playlist for a good view (in contast with blue). Thanks Senna.
Reply #196
Question: When I use EsPlaylist as a Library Viewer, is there a way not to show the complete library? I want to exclude certain files using a pattern. Is this possible?
Reply #197
Another Question: Is it possible to completely hide the album art column? If you use grouping setting "none", well it won't show album art but there's still that album art column.
Reply #198
Just drag the column header so it becomes smaller.
Reply #199
Feature Request:
Two different Specified Playlists - One for just displaying selected items from a EsPlaylist in Library Browsing Mode and one for playing. Then we have a real "Now Playing" playlist that can't be overwritten if the user selects other library entries. If the user chooses to play them, they will be sent to the 2nd Specified Playlist (Now Playing list) and the view switches to that list. If the user then selects other stuff, the view switches back to the first Specified Playlist.
