Poll
Which LAME preset do you use for the majority of your encoding?
standard / -V 2
[ 126 ] (66.7%)
-V 1
[ 4 ] (2.1%)
extreme / -V 0
[ 23 ] (12.2%)
insane / 320 CBR
[ 8 ] (4.2%)
something else (medium / -V 3)
[ 28 ] (14.8%)
Total Members Voted: 247
Topic: LAME Encoders - Which alt-preset (Read 25127 times) previous topic - next topic
lame 3.96.1 --preset standard
Optimal compatability and quality is good enough for a lossy encode (except for the lack of gapless playback), less buggy than 3.90.3. I don't see any need to change to a different lossy encode method, next step is lossless.
Lame 3.96.1 --noreplaygain --preset -fast standard
I find it quite good.
Cannot distinguish from -standard to -fast standard so I voted for speed.
Lame 3.96.1 -V4 (a.k.a. --preset medium). I use -V2 (a.k.a. --preset standard) every once in awhile, especially in cases where I've edited a wav file before encoding (for example, on Queen's Bohemian Rhapsody, so that the quiet parts aren't so ridiculously quiet compared to the louder parts).
I decided against using --vbr-new (a.k.a. "fast" preset) because I've noticed it failing (at -V4) on a couple of samples, and because it doesn't spread out the bitrate over frames as much.
-V4 is good enough for my hearing on nearly everything, and saves a fair bit on bitrate.
God kills a kitten every time you encode with CBR 320
--alt-preset insane
No one has ever complained that my mp3s sound too good. It also saves me from having to bother with tedious listening tests.
Don't do much ripping lately but,
3.90.3, alt-preset standard.
lame 3.97 alpha 10, -V 2
LAME version 3.97 (alpha 10, Apr  1 2005 20:16:32) (http://www.mp3dev.org/)
I'm using MP3 format to feed my small portable player, and I used to set LAME with --preset 128...140 for most encodings. In some occasion, I prefer -V5 --vbr-new or -V4 --vbr-new.
EDIT: lame version = 3.97 alpha
Reply #32
Currently I use lame 3.97 alpha 10 --preset standard -Y
--alt-preset insane
[a href="index.php?act=findpost&pid=287487"][{POST_SNAPBACK}][/a]
lossless is your friend
Reply #34
I voted for lame 3.96.1 --preset standard. I reckon that's the most successful lame preset ever made. Files are not very big, sounds not much worse than extreme. Frankly speaking, I would give up lame for OGG Vorbis, if Vorbis was implemented in the hardware I use. I have portable SONY D-NE710. Sounds not bad, but has some problems with some VBR encoded files: determines track time incorrectly and the sound disappeares for a couple of seconds (probably a buffer bug). CBR plays perfect, but no gapless playback provided.
Reply #35
I use -preset extreme, but I'm considering stepping back to -V1. Size is not a HUGE concern, and I somehow feel like I'm buying "insurance" at this bitrate. Generally, output files average <256kbs (rock and electronica), and that's the CBR setting I used to use with older encoders before I discovered LAME. I've ABX'd a number of my own files with -ape and could never tell the difference. So it works for me.
What I CAN tell is the difference between MP3 CD-ROM players, such as comparing my old Panasonic SL-35 with my iRiver iMP-50.  Huge difference in tone and quality, which raises the question of which decoder algorithms different MP3 players use (disk, flash, or HD). But that's a question for a different thread.
Reply #36
--alt-preset insane
[a href="index.php?act=findpost&pid=287583"][{POST_SNAPBACK}][/a]
I definitely have the hard drive space for flac or ape, but I'd have to give up my beloved [a href="http://www.muzicman.com/]audio player[/url] since it only supports mp3 and wav.
The players that support lossless don't have all of the features I'm looking for.
Reply #37
Just started using the settings -V 2 -m j -h for recreating my music library over.  I've finished 1 CD and got about 400 to go
I was using -V 2 -b 192 -m j -h before, but I thought it was time I started taking advantage of VBRs ability to adjust to the sound complexity of a track.
J
Edit: Using EAC .95 pb5 and lame 3.90.3
And do you think those settings should be adequate for use with an iPod? I'm not sure how well it will handle VBR tracks and I use my iPod a ton.  Even got a new car stereo that can controll it a few months back.
Reply #38
Why do you add "-m j -h"? -m j is useless to add, while the -h setting could very well give unwanted effects on quality..
I think it's established around here that you should stick to the default settings
Reply #39
Well I'm not using them anymore...thx for the info.  I'm still kind of looking around before committing to encoding my whole music library over.  Oh and what about setting min and max bitrates?  Is that also something already included in the preset?
J
With the presets doesn't the bitrate decide whether its joint stereo or regular though?  Pretty sure I read that among the tons of pages I've read about Lame tonight.
Reply #40
[a href="index.php?act=findpost&pid=287601"][{POST_SNAPBACK}][/a]
It probably has more to do with the analog circuitry and the DAC stage than different decoders.
Reply #41
Yes, have a look here:
http://www.hydrogenaudio.org/forums/index....showtopic=18091
No, it only "decides" between ms & ss.
Reply #42
--alt-preset insane
umm, actually I've heard RIAA is going to file a complain
Reply #43
Ya, I read through that entire post last night after making this one...sorry for not searching a bit harder.
Thanks for the response I appreciate it.
J
Reply #44
3.96.1 -V4 (--vbr-new)
Transparent to me when I'm not paying too much attention, as is often the case in my car or with my portable. Even when listening more or less closely I have never been annoyed by the quality, so it has just the right quality/size ratio for me.
Reply #45
--preset standard is more than adequate for portable use. If you are low on space, consider stepping down to V3, V4 or even V5. I don't think there should be a problem with VBR files.
