Topic: change default new playlist names? (Read 898 times) previous topic - next topic
I am just wondering if anyone know a way to change the naming scheme for new playlists that you create.
The default is:
  • New Playlist
  • New Playlist (2)
  • New Playlist (3)
  • New Playlist (4)
and so on...
If possible I just want them to be named:
  • 1
  • 2
  • 3
  • 4
and so on...
I always use a keyboard command shortcut to create new playlists.
Best regards
illya
Re: change default new playlist names?
I made a component foo_new_playlist that introduces a new command that uses a custom pattern exposed in advanced configuration to name new playlists.
The pattern in Preferences: Advanced -> Tools -> "New playlist pattern" uses two new title formatting fields to form the titles of new playlists. The counters starts at one and increases until a free name is found.
  • %always_counter%: counts 1, 2, 3, ...
  • %maybe_counter%: counts nothing, 2, 3, 4; suitable for use in [] to not show anything for the preferred title
Hopefully this will do what you want given a format of %always_counter%.
Hi Zao.
Again... :(
New Named Playlist 1.0 (foo_new_playlist-1.0.fb2k-component)
> Could not load component "foo_new_playlist-1.0.fb2k-component": Unsupported format or corrupted file
Can not install. Can not unzip.
SHURE SRH1840, SENNHEISER HD660 S, Beyerdynamic DT 1990 PRO, HIFIMAN HE400i, Ultrasone Performance 880, AKG K712 PRO, Bowers & Wilkins P7 Wireless, SONY MDR-1ABT, Bose QuietComfort 35 wireless, SENNHEISER HD 4.50BTNC (made a Upgrade/Balanced Cable by myself)
I thought I had solved my network problems... bah.
Re-uploaded over VPN.
Thank you for your support in your busy time.  ;)
I made a component
Thank you Zao,
I really appreciate that you took your time to actually create a plugin.
Tested it out, and it works like a charm :)
Now I just need to unlearn seven years of always hitting ctrl + m directly after ctrl +n :D
Edit: Problem solved using $num(%always_counter%,2)
Old post:
Hi again,
just wondering if it would be possible to make it use double or triple digits:
01,02,03,04,05,06,07,08,09,10,11,12...
instead of
1,2,3,4,5,6,7,8,9,10,11,12... (as it does now)
Reason I ask is because I have issues with other plugins that sort the playlists
They sort as: 1,10,11,12,13,14,15,16,17,18,19,2,20,21,22...
If you are free to use title format functions just use $num(%always_counter%,2)
Sometimes you never think about the obvious :)
Thank you.
