Topic: Working with cue sheets (Read 1117 times) previous topic - next topic
Ok trying to clean up the way albums/singles display in my config and one issue I'm having is the ones that use cue sheets to split the album/single. It shows the split tracks under one album/single and they play but next to it is the album/single as the full audio file that also plays.
Is there any filter method that I can set per directory or something that I can set in the component's config page?
I think I might need to reword this but hey someone might know what I mean
(attached the components installed)
Re: Working with cue sheets
Can this be done?
What about Preferences ->Media Library -> File Types -> Exclude -> .cue;.log;.m3u;.jpg  (for example)
I guess you want it the other way around, but this works for me.
I had similar problem. I just put "CUE" keyword in album tag in all referenced files and then I filter them out in facets.
