I want to mix some stereo mp3's to mono to listen with headphones because I only have hearing in one ear. I tried Audacity and Goldwave, and I see they produce different results. Can anyone shed some light on which produces the better mix? Here are screenshots of a couple of files I converted:
Screenshots (https://skydrive.live.com/redir?resid=F185E5FC24535F41!125&authkey=!AD2SR2mLAyRrhj4)
Or if you know of another free program that does a good job, please let me know.
Foobar2000 has a built-in DSP filter called 'Downmix channels to mono'. You can keep the MP3s as they are.
Have you considered a mono mix cord before your 'phones? You wouldn't need to do anything to any program material.
G²
Esp. for 60s stuff (seeing that the example track is) you might want to tailor the mix (i.e. choose the percentage of left and right channels to sum) on a track-by-track basis. Any DAW should allow this, and the better mix is the one that sounds better to you.
