Topic: Tab Width...Can it be adjusted? (smaller) (Read 1326 times) previous topic - next topic
2nd day wrestling with this. Still new to foo. I'm trying to make separate tabs for each alpha character.
A,B,C etc. Problem is I don't have enough screen real estate to get 'em all in. Doing numbers 0-9 too.
Is there a way to decrease the default tab width when it only has to display 1 character?
Thanks in advance
Sounds like you trying to use playlists for a task better suited for a media library viewer.
Using the default Album List or the component Facets you should be able to make more progress.
In facets, using a first facet with a string of -    $caps($left($stripprefix(%album artist%),1))
gives me an a-z list that then filters the second facet by artist.
In the default album list viewer, something like -    $caps($left($stripprefix(%album artist%),1))|%artist%|%album%|%track%
should at least get you started.
EDIT: these are a bit rough. If you provide more detail on what you wish to achieve, someone will be able to help.
terry
[quote name='tpijag' date='May 12 2010, 14:49' post='705061']
I was indeed approaching it from a playlist perspective.  I installed Facets and am redoing pretty
much from scratch. Looks to be another long night.
Thanks for steering me in the right direction!
Regards
