Topic: realplayer radio streams (Read 2553 times) previous topic - next topic
i want to play radio one live through foobar.
The stream is:
http://www.bbc.co.uk/radio/aod/networks/1xtra/live.shtml#
It requires a realplay plugin. Is there a way I can play this directly through foobar and not via my broswer? if so what plugins do i require?
thanks
AFAIK, you cannot play Realaudio from foobar
There's no such plugin. You should try mplayer.
