Topic: Ripping CD With CueTools (Read 3469 times) previous topic - next topic
There seems to be a bit of difficulty ripping a CD to mp3. From the image you can see it just keeps trying and trying. Any ideas on what the issue is?  I placed the Lame.exe and lame_enc.dll in the CUETools_2.1.5 folder.  If anyone can help thanks in advance.
Extraction method
Secure mode = Reads section once, then one retry. If results differ or the drive reports C2 errors, then error correction begins and up to 30 more full or partial read retries are done for that section.
The retries are normal.
CUERipper can't use lame_enc.dll. You don't need an external file to use the lib* encoders. Placing lame.exe in the CUETools_2.1.5 folder should work fine to use the lame.exe external encoder.
korth
