I've got 7 .json files in this folder. How do I find the one, which is used by DBC ?
...\AppData\Roaming\DeskbandControls\DeskbandControls.json
Here you go:
"GeneralSettings": {
"DisplayMode": "Deskband",
"DrawBorders": false
"FloatingWindowSettings": {
"X": 0,
"Y": 0,
"Mode": "Horizontal",
"Opacity": 1.0,
"Color": "#FF6495ED",
"StretchBackgroundImage": false,
"UseTransparencyKey": true
"ModuleId": "00000000-0000-0000-0000-000000000000"
"HideIfNotPlaying": false,
"HideIfFoobar2000IsNotRunning": true,
"InternetSearchFormat": "$if(%artist%,%artist%' - ')%title%",
"InternetSearchUrl": "https://www.google.com/search?q=%q%",
"AlbumArt": {
"Visible": true,
"X": 2,
"Y": 0,
"Width": 70,
"Height": 70,
"StubImagePath": "E:\\m\\p\\f2k\\foo_httpcontrol_data\\kevo\\nocover.jpg",
"DoNotShowStubImage": false,
"PreserveAspectRatio": false
"Buttons": {
"BtnStop": {
"Visible": true,
"X": 75,
"Y": 1,
"Width": 16,
"Height": 16,
"ColorizeColor": "#FFFFFFFF"
"BtnPlayPause": {
"Visible": true,
"X": 90,
"Y": 1,
"Width": 16,
"Height": 16,
"BtnPrev": {
"Visible": true,
"X": 105,
"Y": 1,
"Width": 16,
"Height": 16,
"BtnNext": {
"Visible": true,
"X": 120,
"Y": 1,
"Width": 16,
"Height": 16,
"BtnRandom": {
"Visible": true,
"X": 90,
"Y": 51,
"Width": 16,
"Height": 16,
"BtnStopAC": {
"Visible": true,
"X": 75,
"Y": 51,
"Width": 16,
"Height": 16,
"PositionBar": {
"Visible": true,
"X": 75,
"Y": 20,
"Width": 70,
"Heigth": 10,
"Color": "#FFFFFFFF",
"BackgroundColor": "#00000000",
"UseBackgroundColor": false,
"HideBorders": false,
"PaddingTop": 0,
"PaddingBottom": 0
"VolumeBar": {
"Visible": true,
"X": 75,
"Y": 40,
"Width": 70,
"Heigth": 6,
"PaddingTop": 0,
"PaddingBottom": 0
"Texts": [
"Name": "Default Text",
"Visible": false,
"X": 92,
"Y": 2,
"Width": 158,
"Height": 16,
"FontName": "Segoe UI",
"FontSize": 8,
"FontStyleItalic": false,
"FontStyleBold": false,
"FontColor": "White",
"Format": "%artist% - %title% '('%playback_time%')')",
"PausedFormat": "",
"StoppedText": "**Stopped**",
"HorizontalAlign": 0,
"EnableScroll": false,
"ScrollSpeed": 100,
"ScrollStep": 2,
"ScrollSeparator": " **** "
"Tooltip": {
"Enabled": true,
"Width": 502,
"Height": 652,
"BackgroundColor": "#FF000000",
"UseBorderlessWindow": true,
"ShowDelay": 1500,
"KeepOpenOnMouseOver": true,
"AlbumArt": {
"Visible": true,
"X": 2,
"Y": 2,
"Width": 500,
"Height": 500,
"PreserveAspectRatio": true
"Texts": [
"Name": "Artist",
"Visible": true,
"X": 2,
"Y": 500,
"Width": 500,
"Height": 24,
"FontSize": 12,
"FontStyleBold": true,
"FontColor": "LightGray",
"Format": "[%artist%]",
"PausedFormat": "",
"StoppedText": "",
"ScrollSpeed": 30,
"ScrollStep": 1,
"Name": "Title",
"Visible": true,
"X": 2,
"Y": 524,
"Width": 500,
"Height": 24,
"FontSize": 12,
"Format": "[%title%][ '('%comment%')']",
"PausedFormat": "",
"StoppedText": "",
"ScrollSpeed": 30,
"ScrollStep": 1,
"Name": "Time",
"Visible": true,
"X": 2,
"Y": 560,
"Width": 200,
"Height": 24,
"FontSize": 10,
"Format": "%length% '('%playback_time%/%playback_time_remaining%')'",
"PausedFormat": "",
"StoppedText": "",
"ScrollSpeed": 30,
"ScrollStep": 2,
"Name": "Rating",
"Visible": true,
"X": 410,
"Y": 560,
"Width": 100,
"Height": 24,
"FontSize": 14,
"FontColor": "Gold",
"Format": "$pad($repeat(★,$meta(rating)), 5,✩) ",
"PausedFormat": "",
"StoppedText": "",
"ScrollSpeed": 100,
"ScrollStep": 2,
"Name": "DiscoGS Artist",
"Visible": true,
"X": 2,
"Y": 580,
"Width": 500,
"Height": 16,
"FontSize": 10,
"FontStyleItalic": true,
"FontColor": "RoyalBlue",
"Format": "['DiscoGS http://discogs.com/artist/'%DISCOGS_ARTIST_ID%]",
"PausedFormat": "",
"StoppedText": "",
"ScrollSpeed": 100,
"ScrollStep": 2,
"Name": "DiscoGS Release",
"Visible": true,
"X": 2,
"Y": 595,
"Width": 500,
"Height": 16,
"FontSize": 10,
"FontColor": "SlateBlue",
"Format": "['DiscoGS http://discogs.com/release/'%DISCOGS_RELEASE_ID%]",
"PausedFormat": "",
"StoppedText": "",
"ScrollSpeed": 100,
"ScrollStep": 2,
"Menu": {
"Enabled": true,
"Stop": true,
"PlayPause": true,
"Previous": true,
"Next": true,
"Random": true,
"StopAfterCurrent": true,
"Playlist": true,
"CopyArtistAndTitle": true,
"CopyTitle": true,
"CopyArtist": true,
"OpenContainingFolder": true,
"SearchInInternet": true
"Playlist": {
"NumberOfItemsBeforeCurrent": 3,
"NumberOfItemsAfterCurrent": 5,
"Format": "%artist% - %title% [(%comment%)]"
"ModuleId": "fb3f7ab3-a9f4-4c39-8c13-d9cd1110b579",
"Order": 0,
"Disabled": false,
"Offset": 0,
"Width": 222,
"Height": 75,
along with another error, showing up just now:
Informationen über das Aufrufen von JIT-Debuggen
anstelle dieses Dialogfelds finden Sie am Ende dieser Meldung.
************** Ausnahmetext **************
System.ArgumentException: Ungültiger Parameter.
bei System.Drawing.Image.get_HorizontalResolution()
bei Deskband.Core.Common.ImageHelpers.HQResize(Image image, Int32 width, Int32 height, Boolean preserveAspect)
bei Deskband.Core.Controls.dcPicture.SetImage(Image image)
bei dcmFoobar2000.Code.Controller.UpdateAlbumArt(Image image, Boolean stub)
bei dcmFoobar2000.Code.Controller.HandleAlbumArt(Byte[] imageBytes, Boolean stub)
bei dcmFoobar2000.Code.MessageForm.FireEvent[T](EventHandler`1 eventHandler, T eventArgs)
bei dcmFoobar2000.Code.MessageForm.WndProc(Message& m)
bei System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Geladene Assemblys **************
mscorlib
Assembly-Version: 4.0.0.0.
Win32-Version: 4.6.1099.0 built by: NETFXREL4STAGE.
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll.
Deskband
Assembly-Version: 3.4.1.0.
Win32-Version: 3.4.1.
CodeBase: file:///C:/Program%20Files/DeskbandControls/Deskband.DLL.
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll.
System
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll.
System.Drawing
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll.
Deskband.Core
Assembly-Version: 1.0.0.0.
Win32-Version: 1.0.0.0.
CodeBase: file:///C:/Program%20Files/DeskbandControls/Deskband.Core.DLL.
Ninject
Assembly-Version: 3.2.0.0.
Win32-Version: 3.2.2.0.
CodeBase: file:///C:/Program%20Files/DeskbandControls/Ninject.DLL.
System.Core
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll.
dcmFoobar2000
CodeBase: file:///C:/Program%20Files/DeskbandControls/dcmFoobar2000.DLL.
Anonymously Hosted DynamicMethods Assembly
Assembly-Version: 0.0.0.0.
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/mscorlib/v4.0_4.0.0.0__b77a5c561934e089/mscorlib.dll.
Accessibility
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll.
Newtonsoft.Json
Assembly-Version: 9.0.0.0.
Win32-Version: 9.0.1.19813.
CodeBase: file:///C:/Program%20Files/DeskbandControls/Newtonsoft.Json.DLL.
System.Numerics
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll.
System.Runtime.Serialization
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll.
System.Xml.Linq
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll.
System.Xml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll.
System.Data
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll.
System.Configuration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll.
mscorlib.resources
Win32-Version: 4.6.81.0 built by: NETFXREL2.
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_de_b77a5c561934e089/mscorlib.resources.dll.
System.Windows.Forms.resources
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_de_b77a5c561934e089/System.Windows.Forms.resources.dll.
System.Design
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Design/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Design.dll.
System.resources
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.resources/v4.0_4.0.0.0_de_b77a5c561934e089/System.resources.dll.
System.Drawing.Design
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing.Design/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.Design.dll.
IcarosPropertyHandler
Assembly-Version: 2.2.1.0.
Win32-Version: 2.2.1.0.
CodeBase: file:///C:/Program%20Files/K-Lite%20Codec%20Pack%20x64/Icaros/IcarosPropertyHandler.DLL.
System.Drawing.resources
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing.resources/v4.0_4.0.0.0_de_b03f5f7f11d50a3a/System.Drawing.resources.dll.
************** JIT-Debuggen **************
Um das JIT-Debuggen (Just-In-Time) zu aktivieren, muss in der
Konfigurationsdatei der Anwendung oder des Computers
(machine.config) der jitDebugging-Wert im Abschnitt system.windows.forms festgelegt werden.
Die Anwendung muss mit aktiviertem Debuggen kompiliert werden.
Zum Beispiel:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
Wenn das JIT-Debuggen aktiviert ist, werden alle nicht behandelten
Ausnahmen an den JIT-Debugger gesendet, der auf dem
Computer registriert ist, und nicht in diesem Dialogfeld behandelt.
Thank you for your work/help/time!!
btw: I nailed down some songs, on which the MS Framework Errors occoured, but thats not reproduceable.
So with just listening to music, the errors popped up a lot of time, but when I tried to play that songs again, no error popped up... murphy....
btw²: some errors occured, when I moved a program window from monitor1 to monitor2 and while a song changed to another, but that could also be a random incident ....
btw³: yeah, the errors pop up mostly, when foobar2000 switches to the next song.
