Topic: foo_dsp_lowpass (discussion) (Read 927 times) previous topic - next topic - Topic derived from foo_dsp_lowpass plugin
Lowpass filter.
Can be used before lossy encoding, if your encoder of choice doesn't have lowpass filter with arbitrary frequency.
Download
This is what I was looking for. Many thanks
🇺🇦 Glory to Ukraine!
Re: foo_dsp_lowpass (discussion)
Can u PLEASE implement a -24dB Subsonic Filter (HighPass) too?! I would be VERY pleased, cause thats what i miss "right from beginning"
This lowpass filter is just a part of SoX resampler. This plugin is just truncated resampler plugin.
I don't know how to properly implement subsonic highpass filter.
So far this has been a sort of week-end fun-time a plugin in for me. I load my playlist with sufficiently percussive material, then I set freq to 3500 and width to 1%. The chirpy ringing is really amusing. From here on tweaking phase lets you hear the difference between pre-ringing and post-ringing very clearly.
I suppose the default width of 5% is reasonable when used prior to lossy encoding?
Plugin messes up channel mask for non-standard channels layouts. For example 5.0 becomes 4.1 when passing through plugin.
lvqcl
foobar2000 1.5.4, foo_dsp_lowpass.dll 0.0.4
“default” button inside plugin’s settings does not reset settings
• Join our efforts to make Helix MP3 encoder great again
• Opus complexity & qAAC dependence on Apple is an aberration from Vorbis & Musepack breakthroughs
• Let's pray that D. Bryant improve WavPack hybrid, C. Helmrich update FSLAC, M. van Beurden teach FLAC to handle non-audio data
@lvqcl, could you update foo_dsp_lowpass to x64, please?
@Case: Is it possible to implement a max. lowpass of e.g. 96kHz?
.halverhahn
