When I open the console window, I often get a "database is locked" error. It occurs when foobar2000 is loaded. And while I can't be specific, it often happens when I try to play a particular file.
There seems to be a delay in the operation of foobar2000 when this DB error occurs.
Components loaded in: 0:00.011037
Configuration read in: 0:00.001171
foobar2000 v2.0 beta 11+log x64 [standard]
Playlist #0 loaded in 0:00.159534
User Interface initialized in: 0:00.386367
FFmpeg version: 5.1
Loading foo_discogger
foo_discogger: http_client service ready
Startup time : 0:00.478256
Watching: D:\Music
Library initialized after 0:02.441319
could not compile SQL:
SELECT info, infoBrowse, size, lastModified, infoBrowseTime, created, attribs, attribsValid, playCount, dateAdded, lastPlayed, firstPlayed, rating FROM metadb WHERE name = ?
database is locked
database is locked
database is locked
database is locked
database is locked
