Topic: WSH Panel Mod script discussion/help (Read 1403874 times) previous topic - next topic
Reply #775
Error: WSH Panel Mod (GUID: EAA8D0BB-9EB2-49F1-A631-2B3491B5D26A): Microsoft JScript runtime error:
Object doesn't support this property or method
Ln: 72, Col: 13
<source text only available in compile time>
Reply #776
i'm confused. what you posted shouldn't make the script crash???
can you post the contents of
%appdata%\foobar2000\wsh_settings\autoplaylists
(or foobar dir\wsh_settings\autoplaylists if running portable mode)
anyway, i've uploaded a new script that shouldn't crash (but it won't run the query either )
Reply #778
It's not giving me a script error anymore, but now am just receiving the message: "There was a problem executing that query. Please check your name/query/sort syntax."
As far as I know there should be nothing wrong with that query.
Reply #779
i'm stumped- obviously there's nothing wrong with that text..... :/
what OS are you on?
irrelevant, i've just tested on windows 7 and XP.
Reply #781
are you running the latest WSH panel mod?
Reply #783
glad you sorted it.
however i've just uploaded a new version which breaks compatibility with the one i uploaded last night...
http://cid-649d3bfeaf541fbb.office.live.co...ide/samples.zip
in the old script i was using !! to separate and store stuff internally but i then i thought it could be possible that people might use that in their playlist names or queries which would then break it. i've now changed it to a ¬ instead which hopefully no one will be using.
(%appdata%\foobar2000\wsh_settings\autoplaylists can be opened in notepad and find/replace can be performed with !! and ¬)
Reply #784
Marc, you might use ASCII unit and field delimiters instead http://en.wikipedia.org/wiki/Delimiter . Won't ever run into problems theoretically.
Reply #786
autoplaylists updated again. same link as above.
-added sanity checking to prevent spawning of multiple text input windows and deletion of favourites when they are being edited.
Reply #787
another update for autoplaylists
-now with scrolling support. mouse wheel is quickest but there are clickable buttons also....
Reply #788
your autoplaylists script looks beautiful, but it creates a new playlist every time i click the "execute" button. is there a way to use the autosend playlist instead?
Reply #789
do you mean send to the same playlist if one with the same name already exists? i'm not sure if that's possible although i should be able to delete old one before creating the new one. i'll have a play around....
Reply #790
new version of autoplaylists
-added restore menu for deleted items. this only remains for the current session. also, anything that causes the script to re-initialise (such as cut/pasting the panel in layout editing mode or editing the script itself) will lose the history.
-added option to remove playlists with duplicate names (it's on by default, use the context menu to turn it off)
Reply #791
wow, thanks! good solution
i have a question for anyone who has a moment.
i'm trying to replace my standard toolbar with a wsh toolbar.
i managed to modify the SimpleThemedButton sample to call functions from the main menu, but i'm wondering if it's possible to do something similar with the context menu?
i want a button that will run "ReplayGain/Scan selection as albums (by tags)" on the selected items. any hints on how to accomplish this would be appreciated
Reply #792
also marc2003, there is a script you published here, but it doesn't work with the lastest version of wsh_panel_mod.
http://www.hydrogenaudio.org/forums/index....mp;#entry685807
'settings_path' is undefined
Ln: 14, Col: 1
can you help me to fix it?
thanks again!
Reply #793
replace lines 2&3 with
// @import "%fb2k_profile_path%marc2003\common.js"
// @import "%fb2k_profile_path%marc2003\tooltip_buttons.js"
Reply #794
thank you!
Reply #796
although it is possible to fetch the item count for a given playlist i won't implement it because it could be too misleading. let's say i modify an active autoplaylist with a different query, you wouldn't want the favourite with the old query saved to show this new item count.
Reply #798
-mouse wheel bugfix
-new option to add favourites to beginning or end of list
-new option to do nothing or execute query when adding/editing favourites
Reply #799
Marco, i seem to be having problems with autoplaylist. I just installed the latest autoplaylist.txt, and all i am getting is a blank playlist.
This is how i created the playlist:
Query: %LASTFM_LOVED% IS 1
Sort: None
I am on windows xp, and i have the latest WHS panel.
