iTSfv - iTunes Store file validator
Reply #373 – 2008-03-09 22:40:19
hi all, 1st post long time listener, 1st time caller i've been following the forums on and off for years, ever since r3mix.net died and i had to look for alternatives thx for all the valuable info and hi ~*McoreD*~ i've been following this thread (again, on and off) since it started all i have to 'say' is: great app, great attitude towards the users, great job! now, for the annoying part eheh i was excited to 'hear' that the new beta supported grabbing artwork for albums that aren't in the library, but, bad luck, i can't get it to work here, an error shows up. i'm using vista + itunes 7.6.1.9 + itsfv 5.47.2.1 error: details:See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.MissingMethodException: Method not found: 'System.Windows.Forms.FileDialogCustomPlacesCollection System.Windows.Forms.FileDialog.get_CustomPlaces()'. at iTSfv.mBwJobsIT.mfExportArtworkIT(IITOperationStatus job) at iTSfv.frmMain.bwApp_RunWorkerCompleted(Object sender, RunWorkerCompletedEventArgs e) at System.ComponentModel.BackgroundWorker.OnRunWorkerCompleted(RunWorkerCompletedEventArgs e) at System.ComponentModel.BackgroundWorker.AsyncOperationCompleted(Object arg) ************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.312 (rtmLHS.050727-3100) CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll ---------------------------------------- iTSfv Assembly Version: 5.0.0.0 Win32 Version: 5.47.2.1 CodeBase: file:///C:/***/iTSfv/iTSfv.exe ---------------------------------------- Microsoft.VisualBasic Assembly Version: 8.0.0.0 Win32 Version: 8.0.50727.312 (rtmLHS.050727-3100) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll ---------------------------------------- System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.312 (rtmLHS.050727-3100) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.312 (rtmLHS.050727-3100) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.312 (rtmLHS.050727-3100) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- System.Runtime.Remoting Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.312 (rtmLHS.050727-3100) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll ---------------------------------------- McoreIndexer Assembly Version: 2.9.7.0 Win32 Version: 2.9.7.0 CodeBase: file:///C:/***/iTSfv/McoreIndexer.DLL ---------------------------------------- System.Configuration Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.312 (rtmLHS.050727-3100) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.312 (rtmLHS.050727-3100) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- 6yfslyj1 Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.312 (rtmLHS.050727-3100) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- McoreSystem Assembly Version: 1.12.1.1 Win32 Version: 1.12.1.1 CodeBase: file:///C:/***/iTSfv/McoreSystem.DLL ---------------------------------------- Interop.ITDETECTORLib Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/***/iTSfv/Interop.ITDETECTORLib.DLL ---------------------------------------- Interop.iTunesLib Assembly Version: 1.10.0.0 Win32 Version: 1.10.0.0 CodeBase: file:///C:/***/iTSfv/Interop.iTunesLib.DLL ---------------------------------------- Accessibility Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.312 (rtmLHS.050727-3100) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll ---------------------------------------- System.Web Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.833 (QFE.050727-8300) CodeBase: file:///C:/Windows/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll ---------------------------------------- taglib-sharp Assembly Version: 2.0.3.0 Win32 Version: 2.0.3.0 CodeBase: file:///C:/***/iTSfv/taglib-sharp.DLL ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box. any thoughts? p.s. i'm assuming i meet the 'Microsoft .NET Framework 2.0 or higher' requirement since i'm using vista and the app itself loads and works just fine
