Topic: How to tag multi-disc albums? (Read 12701 times) previous topic - next topic
What's the preferred / best method for tagging albums with multiple discs (musicals, live albums, ...) to them? I found a thread about directory structure but nothing conclusive about tagging.
I thought about posting this in the tag standard discussion thread, but I have a few special requirements which might make a good solution for me undesirable as a "standard". I try to keep my collection in .flac for lossless and .mp3 for lossy. Most probably foobar2000 uses native tags for the .flacs, for the .mp3s I use the ID3v2 plugin. Before you start flaming - neither my Squeezebox nor my portable read APEv2 tags, and ID3v1 garbles my Japanese unicode tags, on top of being unflexible.
There's DISC, there's PARTINSET, the Squeezebox even uses DISCC for the number of discs - is there any one way of tagging that will work with most/all players? (I'd be fine with a method that works for the iPod, the iAudio U2, the Squeezebox ond foobar2000, though )
The DISC-tag is the standard.
- Lyx
- Lyx
[a href="index.php?act=findpost&pid=277257"][{POST_SNAPBACK}][/a]
I thought it was DISCNUMBER, like TRACKNUMBER.
- Lyx
[a href="index.php?act=findpost&pid=303691"][{POST_SNAPBACK}][/a]
IMHO, a real standard cannot exist in this case.
I was just using (Disc X) after the album name, but I've just swtiched to the DISC tag.
Xiph.org suggests DISCNUMBER in the Vorbis specs. Personally, I use DISCNUMBER to number the discs.
[a href="index.php?act=findpost&pid=303696"][{POST_SNAPBACK}][/a]
Hmm. I can't find DISCNUMBER in the latest version of the spec. The Wayback Machine doesn't show any version which mentions DISCNUMBER either.
I might have picked it up from Jonathan Walter's tagging proposals or other similar proposals then.
For Mp3 with ID3v2 tags go for PARTINSET with x/x syntax. It gets recognized by itunes.
i just use DISC=1, DISC=2, etc etc
Wasn't there a VOLUME or something like that :S
hi
This way you can tag Enya's A Box of Dreams boxed set like this:
ALBUM=A Box of Dreams
DISCNUMBER=1
DISC=Oceans
DISCNUMBER=2
DISC=Clouds
DISCNUMBER=3
DISC=Stars
I actually like that, works for James Morrison - Three Minds to.
ALBUM=Three Minds
DISCNUMBER=1
DISC=Hot
ALBUM=Three Minds
DISCNUMBER=2
DISC=Swing
ALBUM=Three Minds
DISCNUMBER=3
DISC=Cool
I've been using %DISC NAME% for that kind of tagging. Perhaps I should also convert to using DISCNUMBER and DISC.
Are there remappings (from/to DISC to something else) in place in fb2k? If yes, which ones?
I am talking about something different. As far as i know, there are some remappings in place in fb2k, which are not visible "on the surface" and also not part of the tagz-fieldremappings.
For example, RGain is stored differently depending on the fileformat - but you dont notice that in tagz.
Do you mean, like APEv2 "TRACK" for Musepack being remapped to "TRACKNUMBER" for TAGZ with 0.8.3?
I'm not aware of anything concerning %disc%.
As a side note, IMHO %__replaygain_track_peak% etc are tech info fields, which IMHO don't necessarily need to match the physical descriptions.
Ok, so before I stored it i the album tag just as (Disc X) but now I've converted to DISC, but my playlist (Columns UI) is sorting it wierdly:
-track 1, disc 1
-track 1, disc 2
-track 2, disc 1
-track 2, disc 2
You get the picture. How do I solve this?
You want to add DISC somewhere in the sort string (Playlist->Sort->Sort by...) and probably also in the prefs Core->Sort incoming files by:
for example my string is:
$if2(%ALBUM ARTIST%,%ARTIST%) - %DATE% - %ALBUM% - %DISC% - $num(%TRACKNUMBER%,3) - %TITLE%
But that doesn't sort the tracks as soon as they are added to the playlist (by the albumlist panel)
DISCNUMBER=1
DISC=Oceans
DISCNUMBER=2
DISC=Clouds
DISCNUMBER=3
DISC=Stars
[a href="index.php?act=findpost&pid=303721"][{POST_SNAPBACK}][/a]
I like this. It works with Ani's album Revelling/Reckoning well
Album=Revelling / Reckoning
Discnumber=01
Disc=Revelling
so id just use
$if3(%disc%,%album%,%location%)
for my album list.
ALBUM = In The Mix
DISC = 1
DISCNAME = Sundown
ALBUM = In The Mix
DISC = 2
DISCNAME = Sunrise
Is how I do it.
[a href="index.php?act=findpost&pid=303773"][{POST_SNAPBACK}][/a]
if you set it in the prefs (Core->Sort incoming files by:) it does
Thank you very much
DISCNUMBER=1
DISC=Oceans
DISCNUMBER=2
DISC=Clouds
DISCNUMBER=3
DISC=Stars
Note that the different "parts" of an album do not always correspond with individual discs. As examples I could name lots of classical opera's, but I also recall Kyuss' album "Welcome to Sky Valley", 1 CD in 3 parts I, II, III covering a total of 10 tracks.
Hence I don't use DISC/DISCNAME to name these parts, I use PART, or rather ... I used to do that - my current, simple system is embedding all info in the title fields:
I: Gardenia
  ...  Asteroid
  ...  Supa Scoopa
II: 180°
  ...  Space Cadet
  ...  Demon Cleaner
III: Odyssey
  ...  Conan Troutman
  ...  N.O.
  ...  Whitewater
Nearly every classical CD has such "parts", and often they don't correspond with DISCS (e.g. 2 parts spread over 3 discs).
