Topic: qaac in CBR mode (Read 6877 times) previous topic - next topic
qaac in CBR mode
Hi guys,
is it normal for AAC to have small variance (+/- some kbps) with the bitrate when using CBR mode? Never observed this with LAME. Maybe it's different whit other AAC encoders.
I was testing different encoded AAC files (320 kbps CBR) and remember some of them not playing correctly. Later i remembered that some of them had their Album Art not removed, so this was probably the only problem why this happened.  But i won't be able to test it until this weekend. Tested on a JVC audio player.
I would even prefer just a variable bitrate ~256 kbps ("-v256 -q2"). But than again i don't know if the decoder will support bitrates above 320 kbps, which occur with this settings. Guess i will have to test it out.
MediaInfo output:
General
Writing application                      : qaac 2.47, CoreAudioToolbox 7.9.9.4, AAC-LC Encoder, CBR 320kbps, Quality 96
Audio
Format                                  : AAC
Format/Info                              : Advanced Audio Codec
Format profile                          : LC
Codec ID                                : 40
Duration                                : 3mn 29s
Bit rate mode                            : Variable
Bit rate                                : 320 Kbps
Maximum bit rate                        : 330 Kbps
Channel(s)                              : 2 channels
Channel positions                        : Front: L R
Sampling rate                            : 44.1 KHz
Compression mode                        : Lossy
Mr. Gelpke
qaac in CBR mode
Don't mix up MP3 and AAC - they're different codecs. LAME is MP3. QAAC is AAC.
So-called CBR in iTunes/QAAC is more like Constrained VBR (CVBR). Bitrate tends to increase for transients and similar situations, but the overall bitrate is fairly consistent. AAC decoders should be OK with >320kbps.
MP3 is different and has fixed choices of frame size, so LAME can produce true CBR (although in practice use of bit reservoir acts a bit like CVBR). Compliant MP3, unlike AAC, doesn't support >320kbps frame sizes.
qaac in CBR mode
Thanks for the explanation, this makes sense now. I am pretty sure that the player just doesn't like album art. I meant MP3 when i mentioned LAME, just forgot to make it clear.
qaac in CBR mode
So-called CBR in Apple/qaac is CBR.
https://github.com/nu774/qaac/wiki/Command-Line-Options
-a, --abr <bitrate>    AAC ABR mode / bitrate
-V, --tvbr <n>         AAC True VBR mode / quality [0-127]
-v, --cvbr <bitrate>   AAC Constrained VBR mode / bitrate
-c, --cbr <bitrate>    AAC CBR mode / bitrate
qaac in CBR mode
Hi eahm,
"--ignorelength -s --no-optimize -c 320 -o %d -"
This is the command line i used in foobar2000.
Even if foobar2000 says that the file is CBR, it still is not the same as CBR in MP3.
If i add "--stat" to the command line, this bitrate statistics are created:
Big Barn Bed.stat.txt
I guess it shows the bitrate per frame.
qaac in CBR mode
Of course is not, one is MP3 and the other is MP4. Is this what you're trying to say? I don't know the specifics of the encoding and I don't really care, you have to ask some expert for that but I am pretty sure that -c with qaac creates a CBR AAC file.
qaac in CBR mode
I don't doubt either that qaac creates correct AAC CBR files.
I just answered because compared to MP3, CBR in qaac is a little like Constrained VBR with +- some kbps. Like Dynamic explained. So yes, i was just comparing the two, and of course they are not the same. I thought you meant that it would produce CBR like in MP3, so thats why i posted the pastebin. Yeah, just some misunderstandings from me.
