Topic: Amount of Compression for ALAC and FLAC (Read 5343 times) previous topic - next topic
I read the sticky thread above about all the lossless formats and was confused about one thing. When it says FLAC has 58,70% compression and ALAC compresses at 58,50% what does the 58 mean? and does the percentage mean that FLAC for example is 70% of the original wav or it takes away 70% of the wav file making it 30% of the size.
Bottom line: if the WAV file=100mb
                      FLAC=?
                      ALAC=?
% of original wav
example:
0.587 x 1411kbps = 828k
0.585 x 1411kbps = 825k
50% of 1000 is 500. 58.70% of X is Y, where
  X            Y
100%     58.70%
so
Y = (X * 58.70) / 100
being X the number of bytes a wav ocupies, and Y how much it would ocupy as encoded
% of original wav
example:
[a href="index.php?act=findpost&pid=327272"][{POST_SNAPBACK}][/a]
Ok so are you saying it will display as 828k for both flac and alac but be very different in file sizes since one is specified to be 70% and one 50% of the original size?
and oh, which is smaller flac or alac? that was one of my questions
  X            Y
100%     58.70%
so
[a href="index.php?act=findpost&pid=327275"][{POST_SNAPBACK}][/a]
Yes I get it but why is there 2 percentage values for flac 58 and 70% for example. is it variable depending on the song sort of like a tiff file for images?
[a href="index.php?act=findpost&pid=327281"][{POST_SNAPBACK}][/a]
They're roughly the same. Usually not much more than 1-3mb difference on an entire album to one or the others advantage.
[a href="index.php?act=findpost&pid=327284"][{POST_SNAPBACK}][/a]
OK, just wondering what the 70% for flac and 50% for alac meant... insignificant??? so they are probably both just around 58% compression then?
Donunus, I think your confusion is in the fact that the numbers are using a European formatting where a comma is the decimal separator and a period is the thousands separator.
US: 1,234,567.89
Euro: 1.234.567,89
So...
Euro: 58,70% = US: 58.70%
Euro: 58,50% = US: 58.50%
[span style=\'font-size:8pt;line-height:100%\']I wouldn't know a subtle hint if it stood on my desk in a purple dress dancing and singing, "Subtle hints are here again!"[/span]
US: 1,234,567.89
Euro: 1.234.567,89
So...
[a href="index.php?act=findpost&pid=327287"][{POST_SNAPBACK}][/a]
AAAARGH.... EUREKA!!! Thanks a lot. Thats the first time i've heard of that. I guess i learn something everyday. so the sticky is european... and i thought it had 2 values
US: 1,234,567.89
Euro: 1.234.567,89
So...
[a href="index.php?act=findpost&pid=327288"][{POST_SNAPBACK}][/a]
Wow, me too, I've ran into this many times reading different threads here and most times I thought I was seeing either a ratio or two values!...Thanks to Fenterbug for taking the time to point this out  !
Those wacky Europeans...
US: 1,234,567.89
Euro: 1.234.567,89
So...
Actually, the European formatting (not British) would be
1 234 567,89
I recently switched back to Windows after being on a Mac for two years, so I've actually been converting my ALAC files to FLAC -q5. As others have said, FLAC -q5 and ALAC are very similar, with FLAC being a little bit smaller most of the time (at least for the hundered or so albums I've converted).
That being said, I personally wouldn't use ALAC unless you are on a Mac or use an iPod, though; FLAC has much better hardware and software support ATM.
