Topic: foo_coverflow_mod playlist friendly (Read 7128 times) previous topic - next topic
Re: foo_coverflow_mod playlist friendly
Thanks for the mod (and mainly the compiling!) This problem also happened in the unmodded version, but for some reason a lot of albums without a cover display as a low-res cover of another album. Is there a way to fix this?
Sorry for the late response...
Have you tried simplifying the search pattern under fb2k > Preferences > Display > Album art ?
A new release is now available...
Change log:
    Source mode stored/restored for each UI element.
    Legacy image viewer replaced by ImageGlass
    New script function enableCarousel.
Notes:
    Foobar 2000 v2 required.
    Configuration files are not backward compatible.
    Back up the current configuration before installing this release.
    Previous non-built-in scripts require recompilation after including:
function enableCarousel(){ return true }
Chronflow Mod v0.5.2.mod.17
Thanks for reporting @mjm716
Are you running foobar 2000 v1.6.16 ? The latest release requires fb2k v2.
whoops sorry, yes I am, I must have missed the update requirement. Thanks for letting me know!
First of all thanks for your work
FB crashes at start with Chronflow Mod v0.5.2.mod.17
foobar2000_v2.1_preview_2023-08-11
Columns UI2.1.0-beta.3
Chronflow Mod v0.5.2.mod.16 works perfect
Reply #32
@DaywalkerXXX
Ouch!
I was able to replicate that start-up CUI crash, but unfortunatelly I am a DUI user and a bit lost testing this infertace.
Would you mind giving a try to this quick fix?
Thanks you also for your reports and testing.
Cronflow Mod 0.5.2.18.beta:
X
Change log:
- Fix CUI component start-up crash.
@da yuyu
Wow that was very quickly, thank you
No crash with Cronflow Mod 0.5.2.18.beta
The only problem that at every start the "album art (build in)
appears against the settings in (cover display-default configuration
Reply #34
I have checked everything again.
Old Chronflow ( Mod v0.5.2.mod.16 ) removed from FB.Also the file from -Profile/configuration-. Then installed Cronflow Mod 0.5.2.18.beta. Result everything runs perfectly until now  :D
Reply #35
With V16, the interplay of Chronfloh and Smooth playlist manager was very good.
With the setting (Active Playlist as Source), every playlist was immediately displayed in Chronflow.
Unfortunately, this is no longer possible
Reply #36
@DaywalkerXXX
Happy to hear it is working again so far  :)) ,
Lamentably, a second beta test is ready  ;D
Change log:
General:
- 'Follow library selections' revisions.
CUI:
- Source playlist guid overwriting playlist name.
- Enable multiple instances.
Chronflow Mod v18 beta 2:
X
Reply #37
@da yuyu
No crash I installed it directly :))
When I change the playlist, i always have to change the setting (playlist covers) in the Chronflow context menu.
From (Active Playlist as Source) to (Set Current Playlist as Source) and the other way around.
Otherwise the cover display does not change.
But maybe I only have the problem. :(
Thank you for your efforts
Reply #38
@DaywalkerXXX
It might be...
v17 contained a significant amount of changes, and few people have courage enough to attempt to round the edges.
This release should fix Active Playlist as Source (although not getting activated on Foobar start-up).
Thanks for your feedback!
Chronflow Mod v18 beta 3:
X
Reply #39
@da yuyu
The problem when switching the playlist is fixed. :D thanks for that
But when starting FB or when changing the playlist, the previously selected album is not displayed.
Shows FB directly at the start
Reply #40
@DayWalkerXXX
Previous selections should work again  ;D !
Also included a patch fixing the 'Open Image Viewer' context menu option failing to open Unicode paths.
Thanks again for reporting  :)
Chronflow Mod v18 beta 4
X
Reply #41
@da yuyu
Previous selection works very well. Thank you very much.  :D
I tested everything and it is going very well so far.
I still noticed two small problems
If I start foobar in the (Resume Panel State), no cover is displayed.
With Chronflow Mod V16 it worked well.
I noticed when I go to an empty playlist, for example (Library Playback) and then choose another playlist it doesn't work properly.
But that was already at version 16
Best regards
Reply #42
@DaywalkerXXX
I can't replicate neither of them here...
About the first issue, I tried:
- Enable fb2k > Preferences > Playback - Other: Save playback state and resume on the next start-up
- Enable chronflow panel "Active Playlist as Source'
- Quit and restart Foobar.
If the test is ok, it might help troubleshooting...
- The issue is consistent or occurs only sometimes
- Component is embedded in a foo_flowin panel or the general layout
- Is foo_ui_hacks installed
- Also fails running the component in a portable fresh installation
About the second issue...
Is it moving from and empty playlist to the 'Library Viewer Selection' when the component is running in Library mode?
... another fix will be included in next release (v18):
- Mouse click on adjacent covers not working when the 'Set Selection' option is disabled.
Reply #43
@da yuyu
I tried your suggestion with (Preferences> Playback).
Unfortunately does not work.
1: The Issue is consistent
2: Component is embedded in the general layout
3: foo_ui_hacks is installed
4: The Component is Running in A Portable Fresh Installation
Perhaps it is also due to the theme (Eole-Foobar-Teme-Mod).
Setting see GIF
As I said, no problems with the Chronflow Mod V16
I just installed FooBar2000 V2.1 Preview 2023-08-18 (Portable)
No problems  :D
Everything is still beta. So thank you very much for your effort
Reply #44
@DaywalkerXXX,
I´ve sent you a PM.
Final v18 is now available.
Change log:
- Component renamed Coverflow (foo_coverflow).
- Includes the latest v18 Beta updates.
For a full change log, installation details and downloads...
Coverflow 1.18.0
Reply #45
Until Chronflow Mod 0.5.2.mod.16, when the mouse wheel was rotated after clicking the Chronflow Mod cover, the playlist view was followed, but since mod17, it does not work with CoverFlow 1.18.0. Please let me know if there is a solution.
Reply #46
@Mahler07
Panel context menu > Folow Now Playing check/0n
Panel context menu > Playlist Covers > Show playlist tracks check/0n
Panel context menu > Playlist Covers > Active Playlist as Source check/0n
Panel context menu > Playlist Covers > Show playlist tracks check/0ff
SHURE SRH1840, SENNHEISER HD660S, Beyerdynamic DT 1990 PRO, HIFIMAN HE5se, Ultrasone Performance 880, AKG K712 PRO, SONY MDR-1AM2, Bowers & Wilkins P7 Mobile Hi-Fi, Bose QuietComfort 45, SONY WH-1000XM3 (made a Upgrade/Balanced Cable by myself) Shall I write more?
Reply #47
@Air KEN
I tried your suggestion.
If you click the cover, the playlist view album will not be selected.
Reply #48
I thought it would be OK if the Source became a Playlist.
It will be set to Preferences > Display > Coverflow > Behaviour tab and Album Source tab.
Reply #49
Hi @Mahler07, you are welcome!
I could not find any difference related to scrolling/selections comparing both versions.
Please turn on the Playlist Selections > Set Playlist Selection option and Playlist Covers > Highlight cover tracks (both in the UI context menu).
Do playlist tracks belonging to that album/cover get highlighted in the playlist view?
If your layout includes a Selection Properties panel, does its content change while scrolling the playlist covers?
