Topic: Display filename instead of title tag in specific cases (Read 1830 times) previous topic - next topic
Hi guys.
I have a very specific file formatting question that someone here can probably answer. I've been looking at title formatting syntax reference, but I can't for the life of me wrap my head around the functions.
How would I go about modifying this string to make it so that if the file is midi, display filename with extension, and for everything else display title (as it is now).
$get(head)Title: $get(info)[%title%]$char(10)
made of radiation
Maybe something like this:
$if($strstr(%filename_ext%,'.mid'),%filename_ext%,$get(head)Title: $get(info)[%title%]$char(10))
Thanks very much. It was almost perfect, I needed to modify it a little though. Turns out the $get(info) was used to fetch colors for the text, so I had to cut&paste that in the right place.
This ended up being perfect.
$get(head)Title: $get(info)$if($strstr(%filename_ext%,'.mid'),%filename_ext%,[%title%])$char(10)
Thanks again.
made of radiation
I don't think there's any need for the square brackets around %title% since it falls back to the file name. It might also be better to use the codec instead of the file name since there are a number of different extensions for midi files.
$get(head)Title: $get(info)%title%$if($stricmp(%codec%,mid),.$ext(%filename_ext%),)$char(10)
That's a good point about the different extensions. I ended up combining the two into this. Seems to be working splendidly for midis and hasn't broken anything else I've thrown at it.
$get(head)Title: $get(info)$if($stricmp(%codec%,mid),%filename_ext%,%title%)$char(10)
made of radiation
