Topic: Toggle on/off songs in the playlist (Read 1039 times) previous topic - next topic
I saw a functionality in iTunes that some songs can be toggled on/off.
So I may have songs in playlist but the player won't play them if they are toggled off.
Does somebody know the trick?
I am intermediate user who has experience with customizing Foobar.
http://www.foobar2000.org/components/view/foo_quicktag
http://www.foobar2000.org/components/view/foo_skip
You can use foo_quicktag to...quickly tag fields like RATING=1 or SKIP=1.
You can bind these commands to a key using file/preferences/keyboard shortcuts.
Then you can set up a pattern using foo_skip that dictates which files get skipped automatically. I think RATING =1 is the default setting.
if you wanted a way to do this directly from within a playlist, you could use playback statistics (foo_playcount) to store ratings. then you could use either simplaylist or EsPlaylist with their clickable rating columns. it will still require foo_skip like the tagging suggestion above.
Thank you guys, I will try it.
