Topic: [Bug report] Resume playback after app restart Not effect (Read 1550 times) previous topic - next topic
today ,i upgrade Foobar v1.4 to v1.52 on My machine.
then discovered this problem “Resume playback after app restart ”Not effect
I use this APP on my car ,Similar to a PAD.
OS is andriod 4.3
machine power off when i open the door
not like phone is kill the process.
tested working fine on my phone.
This feature is probably unable to balance between mobile phones and pad,The best way is to launch a car infotainment version
Have other users also encountered this situation,
please help.
Re: [Bug report] Resume playback after app restart Not effect
Your device is probably not getting enough time from power down to close the app resources correctly. If the shutdown intent is given enough time to set all of the restart flags, Foobar has nowehere to start from.
There is no way to close the process on my car.
Only power turned off
https://hydrogenaud.io/index.php/topic,124842.0.html
v1.4.1 option“Resume playback after app restart ” is adding
I can only use app v1.4
Resume playback from power outage ?
Not sure if development can work around this issue. No different than a power failure on a many other device. If the app has. I chance to formally shut down, there is no way to create a recovery point.
You're right.
After testing, the playback progress can be saved, but the playback status cannot be saved.
Hope developers can fix the playback status lost due to sudden power outage.
o(╥﹏╥)o
Hello everyone
When it was used normally today, it resumed playing again.
That's strange.
