Topic: Disabling Process system media key events doesn't disable media keys (Read 1101 times) previous topic - next topic
Hi!
I am trying to get Spotify to run through the foobar2000 DSP chain, which I have succeeded in. The only problem that I'm having is that when I disable the media keys under Advanced -> Tools -> Tools
foobar still reacts to the media keys being pressed (as will Spotify do)
I am trying to disable the keys for Spotify only.
Re: Disabling Process system media key events doesn't disable media keys
Clarification, I am trying to disable the keys for foobar2000 so that Spotify only uses them.
I was hoping this setting would solve my issue (It's basically the same thing - don't want foobar to respond to media keys unless focused on the window itself), but it doesn't.
Seems that if "Integrate with Windows 10 Universal Volume Control" setting under Preferenced -> Advanced -> Display is enabled the media keys are processed regardless of the setting you changed.
That does seem to be the case! Thank you!
